Question about Emerson Microwave Ovens
The microwave appears to work, because when I put a time in everything works on the panel, but the glass plate is not turning at all.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Its a simple problem, you have a defective plate motor, i will assume that the food gets hot...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 30, 2010
Glass plate does not rotate
Here are a couple videos that show you how to replace the turntable motor and diagnose
Feb 10, 2015 | Panasonic Microwave Ovens
One of my glass top plates doesn't work, it goes red and then turns off. How can I fix it?
I have no idea what you're talking about. Glass top plates? In a microwave oven? All I know is the glass turntable tray. And if it's not turning around, you either have that feature turned off (a dedicated button on the control panel), or else the turntable motor is bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 09, 2014 | Microwave Ovens
The motor for the turntable is working fine, but the connection to the glass plate is so poor that it usually slips instead of turning the plate. This happens if anything larger than a glass of water is...
The glass plate has to be correctly seated on the drive spindle before you can have any hope of reliable rotation. Place the plate on the spindle and spin it gently until it seats.
Feb 14, 2018 | GE WES1384SMSS Stainless Steel 1000 Watts...
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
PLMVZ169HCA Turntable slips on the glass plate
hmmm? me's thinking about this one!!!!
the glass plate has drive dogs on the bottom of it, that fit into drive dogs on the turn table, if its not meshed up right it just spins freely and normaly throw's the glass plat off??? are the bearing that are under the glass plate turning freely? thats the big ring that the plate rides on near the out side edge of the plate, and can be taken out for cleaning??? it looks like a hoop with 3 or 4 rollers in it??? if you forgot to put this bit back in the right way up after cleaning it thats the problem???
Oct 23, 2009 | Frigidaire PLMV169DC Microwave Oven
Magic Chef MCO153UWF
Tin foil or steel plates in a microwave will burn it out. I suspect it is or has burnt out. Never put anything steel in a microwave.
Mar 12, 2017 | Magic Microwave Ovens
Turntable won't spin so microwave won't heat
Is it possible to take the glass plate out, if so, please remove the glass plate, switch on the microwave for 10 secs and watch through the door to see if you can see the centre spindle turning round? Try this and get back to me please
Mar 12, 2009 | Goldstar MV-1615 Microwave Oven
Microwave plate doesn't fit on cog?!
I know this is probably DUMB of me to say, But some with this type of turntable arrangement, The ring would only set one way. The ring did not turn, but rather the wheels faced up and rolled with, and supported the turntable.
Jan 25, 2008 | Danby DMW1145 Stainless Steel Microwave...
Jenn-Air Microwave turntable not working, microwave works
It's probably a cracked coupler or a weak, slipping motor.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 03, 2007 | Jenn-Air JMC8130DD Microwave Oven
Not exactly a solution - but info that will help -- had the exact same problem, same model etc. I had two servicing companies come out and look at it. One was the local Jenn-Air dealer techs, the other was an independent repairman. The shaft/coupler thing needs replacing. Guess what? The part is not made anymore!!!! My 2 different techs tried everyone under the sun and I spent a day on the internet and telephone and I'm sorry to inform you that part isn't out there -- even through the company (I forget the name now) that carries out-of-stock parts has everything under the sun, they didn't have this. I am furious with Jenn-Air -- I purchased this oven/micro for almost $3,000 in 2003 and the turntable stopped in 2008. Five years and they don't make the part and have none in stock. Maytag is a cheap poorly-run company. Whirlpool bought them out in 2007 and I have checked -- they don't have the part either. Time to look at those dopey nordicware self-winding turntables. Sorry -- only solution is to land a used model. Now you know.
Oct 03, 2007 | Microwave Ovens
Microwave Ovens Logo
183 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
