Question about Admiral AW22 Top Load Washer
Ok I have an Admiral washer model number LNC6742A80 how do you get the top off to change out the lid switch?
catriver
  • 878 Answers
SOURCE: replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Posted on Apr 15, 2007
  • 3 Answers
SOURCE: LID SWITCH ON WASHER REPLACE.
TEMPORARY FIX for model # LSQ8200HQO (perhaps, other models as well) until you can tear the thing apart: DUCT TAPE. One drawback - you'll have to leave the lid open, tape the lid switch on the outside *away* from the tub. The wires on the model listed are long enough to allow you to do this.
Thanks for helping me figure out what the problem was. Tearing apart will have to wait until Monday ... RUSH CONCERT tomorrow night!!!
Posted on Apr 20, 2008
huuum
  • 750 Answers
SOURCE: need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Posted on Oct 08, 2008
SOURCE: kenmore elite washer lid removal?
how do i remove the washing machine the top
Posted on Nov 04, 2008
  • 333 Answers
SOURCE: How to bypass Lid Switch Admiral Washer
The only way to bypass this switch is fist pill the plug, gain access to the switch from under the hood. put a jumper wire on the 2 wires on the switch. that will do it. I hope this helps you out.
Posted on Nov 28, 2008
It won't turn on
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com Troubleshoot your Admiral Top Load Washer that has these following ... The machine will not complete cycle (fills but won'twash or agitate) I recalibrate it and it ... my washer will not startbecause of lid latch it is an admiral.
Sep 29, 2015 | Admiral Washer Control Panel Frame 35-5733...
Admiral top loader no spin cycle
no i would cheak that switch out that u pushing down on mightbe bad try that 1st ok thx nick
Mar 15, 2008 | Admiral AW22 Top Load Washer
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Willnot spin
You may have a bad lid switch.
Mar 07, 2010 | Maytag Admiral AAV7000A
My Admiral washer will not spin.
Unplug the washer.
Insert a putty knife between the top lid and the front panel,where the top meets the front. About 2 inches in from each side are 2 clips that must be pressed inward to raise the lid.
Once the lid is raised,remove the 2 wires from the lid switch and jump them together with a small jumper wire.
Plug the washer in again and turn the dial to spin and turn it on.
If it spins,replace the lid switch.
Jan 17, 2010 | Washing Machines
Washer wont go into spin mode or discharge the water
Check the lid switch or lid striker that operates the switch. lift the top lid and insert a pen or similar into the hole on the right hand side to operate the switch when in spin mode.
If not try shorting the switch temporary, the top part of the washer needs to be hinged back to gain access, to do this insert a flat blade 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the internals, Isolate the supply and locate the lid switch on the underside of the top panel and remove the 2 wires and short out/ link together. test the spin cycle now should now work and also drain the machine (Draining only works when washer is spinning) If all ok obtain and install a new switch do not leave the switch shorted.
Note this switch only affects the spin and draining parts of the cycle.
Good luck
Jan 02, 2010 | Admiral AW22 Top Load Washer
Admiral washer wont spin or drain
Possible lid switch problem, can be shorted out to prove, open the top complete lid for access. To do this insert a flat blade 4" from each side at the front panel between the front panel and lid to release the clips, lid will now lift and switch is on the underside of the lid RH side, short wires and test spin, replace switch if machine runs, do not leave machine with switch shorted and ensure supply is isolated as necessary.
Dec 20, 2009 | Admiral AW22 Top Load Washer
Opening cabinate? Admiral washer AAV 7000 AWW
Soak the lid around were the rubber bumpers stop the lid from letting it slam down, mine had become almost glued, I really had to pull hard to unstick them good luck. I have never seen a top lid with a lock.
Nov 23, 2008 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
109 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
