Question about NEC Lands Phones
I'd like to change the display name on my phone which is nec 22b hf disp aspirephone-bk, model IP1NA-12TXH Tel Bk
3 Suggested Answers
SOURCE: nec 22b hf/disp aspirephone-bk
1. have the first call on the line (do NOT put on hold), (call 1 or 2)
2. press CONF key
3. dial 9 for an outside line and dial the number
4. press CONF **twice** to join calls.
Posted on Jul 24, 2009
SOURCE: I need to know how to use the caller id
Why is the Metro Suburban Recovery Learning Community such a messed up organization?
Posted on Apr 25, 2010
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
Nec 12txd phone not ringing and led indicator not working.
the only other setting that could turn the led off is if you enable blocking mode and you check disable led indicator (found by long pressing blocking mode in the pull down window). do you have any apps that could control the led lights like light manager? if so, try uninstalling it or checking its settings. if you dont have an apps like that, have you tried installing one to see if it works?
Feb 24, 2014 | NEC Aspire 22 Button Ip1na-12txh 0890043...
Phone won't ring
while the phone is hung up, press #725. Then press any line button that isn't solid green until it is. You just have to cycle to "Always"
Apr 05, 2013 | NEC Dsx 22b Display Tel bk Dx7na-22btxh...
How to change name on nec dterm 80
You need to do this from the Admin phones, by default the lowest ext #'s on the system.
This is system programming not the phone itself.
Refer to the Attendant guide for the phone system model your phones run on.
Nov 01, 2012 | NEC Dterm 80 Phone Dth-8d-1 bk Tel 780571...
How do I change the day & date on the NEC aspire system
i have a 22B HF/Disp Aspirephone today I came in and the date is wrong how do I change
Mar 14, 2011 | Lands Phones
I need to know how to use the caller id on the NEC Aspirephone Model IP1NA-12TXH Tel (BK)
i need to know how tosee my call and delete then fron the phone
Aug 24, 2009 | Lands Phones
NEC 22B HF/Disp Aspirephone
http://www.askemergent.com/downloads/aspire-phone-qrg.pdf
http://www.askemergent.com/downloads/aspire-phone-feature-guide.pdf
Dec 26, 2008 | Radio Communications
Nec 22b hf/disp aspirephone-bk
2. press CONF key
Nov 10, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
136 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
