Question about Microwave Ovens
Where can i get the part for the door release
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Dec 30, 2010
Russell hobbs hob sjs21
Usually you have to remove the jacket from the microwave to reach the release mechanism.
Nov 03, 2017 | Russell Hobbs Microwave Ovens
Door release buton does not open the door
You can disassemble the microwave oven and check out the release mechanism. You'll find several hooks that hold the door closed and a linkage mechanism to the door opening button. There may be a broken piece of plastic or maybe just a loose or missing screw that holds linkage together. In the case of a broken plastic part, you can fix it with a 2-part epoxy adhesive, but you'll need to permanently splint across the break with a piece of metal or strong plastic that you've scavenged from somewhere. Before epoxying the splint in place, rough up all plastic surfaces where you want the epoxy to stick well.
Good luck.
Mar 16, 2015 | Panasonic Microwave Ovens
Rc17 commercial microwave, display shows door even when door is closed.what can i do to resolve
Possible that the door lock switch is stuck and so is not releasing even after the door has opened. Look inside after disconnection of power to the microwave at the place where the door locks. Tap into the lock to release the switch . If the switch is jammed or damaged it must be taken out and replaced.
Mar 31, 2011 | Amana RC17 Microwave Oven
The door release button/handle doesn't travel far enough to release the door without pulling on the door
REPLACE THE PUSH BUTTON.SOMETIMES IT GETS WORN OR THE PLASTIC "***" HAS BROKEN OFF;COMMON PROBLEM.HOPE THIS HELPS .PLEASE RATE MY RESPONSE :)
Dec 12, 2009 | Sharp Microwave Ovens
Door will not open. Button release does not release the door latches.
The plastic lever release is more than likely broken. You can order the part from
http://www.repairclinic.com/Appliance-Parts?s=t-KCMS145JSS0-%3d%3dc226g5
It's about twenty dollars.
May 22, 2009 | KitchenAid KCMS145J Microwave Oven
Sharp Microwave R-1480 Door Release Button want open the door.
What usually breaks is the door open lever. Please unplug the oven first.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and order parts by entering your model number at the Sears parts site, but the best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Nov 19, 2008 | Sharp R-1480 Microwave Oven
Microwave
Sounds Like A Part That Releases The Door Has Slipped Outta Its Place were the button is located
Jul 06, 2008 | Microwave Ovens
Panasonic microwave door is stuck. The door is not opening
If you push in on the open door button and it just goes in and does not open the door, then the problem is that the plastic piece that actually opens the door has broken. You can verify this by removing the cover from the microwave and look inside. If you are handy just buy the part from the panasonic parts store in your city and replace it. If not take it in and they will replace it for you.
Good luck
Tom
Jun 12, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
