Question about Garden
Where can I get a new 12 volt transformer for my Hagen Fluval edge aquarium lights
SOURCE: malibu lv341t transformer. is outout 12 volt dc
I'm gonna bet the output is AC because there is no rectifier circuitry between the transformer and the timer assembly. The lighting this is supposed to power does not require DC so why put in the circuitry if it is not needed. So more than likely it is 12V ac
Posted on Feb 23, 2010
SOURCE: My 600 watt 12 volt
1) Amazon sells 600Watt power pack:
http://www.amazon.com/Malibu-8100-9600-01-Voltage-Power-Transformer/sim/B002ZRPM4A/2
2) I bought new 300Watt Malibu power pack at Home Depot about 2 months ago.
Near the lighting section.
My new power pack has electronic time clock, so no more 'slow clock.'
I think Home Depot had 600Watt.
Lowes carries different brand.
3) Manuals for power packs at Malibu lights.com
http://www.malibulights.com/customer_service/owners_manuals.aspx
4) Tips for buying and taking care of power pack:
-Match up wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
-Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
-Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
-When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
5) How to install power pack.
Before unplugging old power pack, check which bulbs are not working.
Replace bulbs using phillips screwdriver.
Unplug power pack.
Notice how wires are connected to power pack, write down terminal connections.
Some power packs have three terminals ... extra terminal is for additional photoelectric eye.
Use pliers or screwdriver to disconnect wires.
New power pack has has same terminals.
Plug in power pack.
Read instruction manual before connecting wires.
Save instruction manual because a few years that manual won't be around as products change.
Posted on Dec 03, 2010
  • 20 Answers
SOURCE: Two nights ago, there was a major power surge in
It's possible the power surge damaged the panel as well. Disconnect the battery and wait for the AC Loss. You'll get a Low Battery on the keypad. Enter your code + off to silence the beeping. If the panel is damaged, it will shut off and back on when you would normally get the AC Loss. Good Luck.
Posted on Apr 17, 2011
  • 5245 Answers
SOURCE: TDC low voltage transformer model DA 150 12 W reset button trips
There is a short circuit.
Copy following link to identify possible problem and download manual
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Posted on Jul 17, 2012
  • 5245 Answers
SOURCE: malibu 8100-0300-01
Promoters should include useful information. Not just air-head fluff.
Copy following link for actual useful do-it-yourself information such as warranty, troubleshoot, operation tips, manuals.
Posted on Aug 22, 2012
Light switch stopped working on fluval chi
The switch may have failed and will have to be replaced.
Oct 15, 2014 | Hagen Fluval Chi 5 Gallon Aquarium
How do set the temp on a 15 gallon tank
leave the heater unplugged in the aquarium in for several hours.Then plug it in briefly and see if the neon bulb lights up (sort of an orange color). If it is on, turn the temp set knob counter clockwise until it goes out. Then turn the knob clockwise slowly until the light comes on again. Now your heater is set for approximately the current temp of the aquarium water. Now adjust the knob in very small increments, waiting hours between adjustments until the water is at the temp you want.
Jul 29, 2014 | Fluval Hagen M50 Submersible Aquarium...
How to stop fluval accent filter bubbles
How do u get the filter water to come down to the bucket?
Dec 06, 2013 | Fluval Fish
Anyone can tell me about Artificial Grass does it requires any type of maintenance?
No it doesn't require any type of Maintenance like water and pesticides or chemicals. It's purely artificial and never requires mowing. You can visit on this Web Site for more information. http://www.syntheticlawnsflorida.com/
Jun 08, 2013 | Hagen Fluval Chi Lily Pad and Grass...
No bubbles from fluval q1
can't get airpod air pump to blow bubbles
Mar 27, 2013 | Hagen Fluval Q1 Aquarium Air Pump
Fluval chi aquarium light does not turn off, defective switch how do I repair it?
Much too late to help, I'm sure, but the cheapest fix would likely be to add a simple tap switch.When the tap switch is turned off, it cuts the power off and the light will go out. A tap switch is simply an outlet with a switch fitted. Plug the tap switch into the wall, plug the aquarium light into the tap switch and you're set. They're cheap at places like Home Depot, likely half the price of the replacement switch from Hagen, who makes Fluval. Also a great way to make it easy to turn filters on and off without having to pull the cord from the outlet.
Mar 09, 2013 | Fish
How to fix fluval led
on this tank the lights are built into the filter pump housing , if they go bad it might be possible to retrofit a new sealed light bar into the same space , but you will need to have previous knowledge of electronics and specify L.E.D. lights as they don't work like regular light bulbs but require a special kind of power or will be damaged if hooked to wrong type of power I suppose its possible to use batterys but id have no idea how long that would work
Jan 29, 2013 | Fluval LED Edge Aquarium 6-Gallon Aquarium...
I have a new 306 fluval cannister filter-the flow is not strong at all-just wondered, is it supposed to be a strong flow or gentle return back into tank?
A 306 should be quite strong, first check the flow regulator is fully open, check that the filter motor is the right way round on the filter bucket, check hoses, inlets and outlets for obstructions, try running without media in the filter bucket. Best to try this stuff in the bath!!!
Aug 15, 2012 | Hagen Fluval 306 External Filter For...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
