Question about LG GH22NS50 22X DVDRW SATA Drive OEM DVD-RAM Burner
Whenever i put any cd or dvd inside the drive, the drive indicator green blinker light blink for 30sec to 45sec. But the drive was not reading any cd or dvd . please give me a solution.
    Problem Solver:
  • 4 Answers
Sounds like a bad drive. You may need to switch it out for a new one.
Posted on Dec 31, 2010
Cds wont work on e521 with vista
You're CD drive is defective. See if the CD works in you're DVD player. If so then the CD drive in you're computer is defective.
May 03, 2014 | Dell Dimension E521 PC Desktop
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
My problem is that almost all of my CD's cant be read by my DVD rom drive in my computer, when I insert the cd it keeps on blinking until it stops and nothing happens, I tested it on the laptop and it...
it sounds like the dvd drive without ,,that's kinda what happened to our cd drive last week, I bought a cd drive at walmart,,but they also have good one at best buy
Aug 26, 2011 | Acer (KV.16X04.007) DVD Drive
A while ago, my laptop's DVD drive stopped reading CDs. A after a few attempts , it displays the CD/DVD as an empty one. The CDs are not empty or too scratched because I tried them on a different computer...
Hello there!
Please note that a CD-ROM drive can read and in some cases write to a CD inserted into it. This is done by means of a fragile laser mechanism that scans the surface of the disc as it spins at high speed inside the drive. Drive failure can occure from a scratched laser eye, mechanical failure, overheating, or simply years of use. You will want to ensure the drive is actually broken before buying a new one as replacement or send it for a repair.
Please follow these easy steps:
1. Open the CD drive tray and insert a CD. If you have a tray that opens by pushing a button, push the button. For slot drives, try to slide the CD in. On slot drives, if the CD will not go in fully, the drive is not getting power.
2. Wait and listen for a "whirring" sound from the drive after the CD is in and the drive tray is pushed in. This may take a few seconds.
3. Look at the status light on the front of the drive if one is present. It should be blinking to indicate that the device is reading the CD.
4. Replace the first CD with another one in case the first CD is damaged or unreadable. Repeat steps 1 through 3 with the second CD.
5. Wait to see if anything comes up on the pc screen indicating the CD is being read or run. A notification may appear asking if you want to play the CD or run the software. This indicates a functioning drive.
6. Click on "Start" followed by "My Computer" and locate the CD-ROM drive usually labeled as "D:/" or "E:/". Double click on it. If the CD drive makes no noise or an error message appears on screen indicating the disc can not be read, the drive may be broken.
If an error message appears indicating that the CD-Rom drivers are missing this may indicate a software issue and not a broken drive.
Regards,
fossildude
Mar 15, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
The green light is blinking on the supply unit but it not coming on or booting up , i need to know if the supply unit is bad
Close examination of your power supply may reveal if the psu is bad.
When the power supply is plug in ac socket the green indicator led inside the motherboard will lit steady green. See if by turning on the cpu you will see some sparks in the power supply connector attached to the motherboard. This is a clear indication of a bad or shorted psu.
You can also smell if there is a burning inside the psu.
See if the fan inside the psu is working if not then its a clear indication of a bad psu.
Using a multimeter if you have one measure the dc voltage coming from the supply connector. Insert the black probe to one of the black wires in the connector. And the red probe to the red wire in the connector. the reading should be +12VDC. Put the red probe to the red wire and it should read +5VDC. Any readings below this, means bad psu.
Measure also the output voltage when there is a load in the power supply. Connect a CD-ROM drive or hardisk and measure again the voltage. Dropping of voltage when put some loads is a clear indication of a bad power supply unit (psu).
I hope this will help you.
Thank you for using Fixya!
Jan 11, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
My lg dvd rom is not reading dvds
Try deleting upper and lower filters of your optical drive. To do that, run regedit on start search. Then, follow this path: local machine, system, current control set, control, class, 4D36E965- E325 - 11CE - BFC1- 08002BE10318. then on the window under Name, look for upper and/or lower filters. right click on it and delete. restart pc. then you're good to go.
May 26, 2010 | LG GSA-H55N DVD-RAM Burner
Dvd writer is not reading any cd
try re pluging in the ribbon cable make sure it is in right. then put a know dvd intothe drive and see if it reads it if it don't then the drive is bad the 16 speed has a stand alone driver so you could try reinstalling the drive also check that the DVD player is not disabled in bios.
Sep 15, 2009 | LG GSA-H42N 18x DVD RW DL IDE Drive...
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Jul 08, 2009 | Compaq (CDD480172) CD-RW Burner
DVD writer doesn't read cd's but it reads DVD
sir
its the problem with your DVD ROMS's lens. It has became weak . Due to which it is not able read the DVD. It cannot be repaired but you can do few things to make it work again.
  1. open the DVD ROMS if possible
  2. try to clean dust from inside
  3. and then try again
or if not able to open it
buy a lens cleaner form market and try to clean with it .
thankyou 4 using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | LG GSA-H55N DVD-RAM Burner
My dual layer DVD burner wont read any media
When was the last time you cleaned the dust out of the laser head? Or your PC, for that matter? Just asking.
There are cleaner disks that work sometimes, or you can go in with a cleaner foam swab with a little alcohol on it. Worth a try.
Apr 08, 2017 | LaCie (300978) DVD RW Dual Layer Burner
LG GH22NS50 22X DVDRW SATA Drive OEM DVD-RAM Burner Logo
183 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
