Question about Poulan Pro Chain Saw 46cc 20"
I need chain and bar for my poloun pro 330 - Poulan Pro Chain Saw 46cc 20"
    Brigadier General:
  • 4,088 Answers
Check at your nearest home center, hardware store, or saw dealer for these components. If nothing is near you, check Oregon saw on the web for these parts--they make bars and chains for nearly any saw ever made. Good luck!
Posted on Dec 30, 2010
How do I tighten a chain on a mccllough mac cat 330
Loosen the bar mount nuts about 1 turn, locate the tension-er screw next to the chainsaw's bar and while holding the bar up turn the screw clockwise until the chain is properly tensioned. while still holding the bar up, tighten the bar mount nuts, test the chain for proper tension. It should not be too tight, you should be able to rotate chain by hand, nor too loose where the chain's drive link's are hanging down below the bar's groove on the bottom side.
Oct 05, 2014 | Garden
How to tighten chain on 4620avx poulan pro
First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx. Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
Jul 21, 2014 | Poulan Pro Chain Saw 46cc 20"
Can I fit a 1.3 mm bar and chain to my Bosch AK40-19s chainsaw
as long as the pitch of the chain is the same as the nose wheel of the bar, then the gauge does not matter as you are fitting a bar and chain with 1.3 gauge.
Dec 27, 2012 | Bosch Ake Pro 1.3 mm Chainsaw Sharpening...
Manual for 330 homolite chainsaw
losen the nuts for the clutch cover and tighten the screw on the side of the bar
Mar 23, 2012 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
I have a Poulan 295. I needed to replace the chain. It is a 20" chain. There is bar oil in the resevoir. The chain will not stay on the bar (it seems loose even when fully tightened). I replaced...
If you replaced the bar AND the chain, you'll need to make sure the chain is the correct chain for the particular bar you've used. If you're only replacing the chain, you need to make sure the chain has the same # of drive links as your old chain (maybe one or two more, if you've had some removed because of chain stretch).
On that particular model, for a 20" chain, you could have a 78 OR 80 drive link chain (drive links being the part of the chain that rides in the groove of the bar). The correct drive link count is determined by the bar you've installed and should have been made clear by whoever you purchased the bar from. Some brands use an 80 drive link chain, but MOST use the 78 drive link chain.
If the bar you purchased uses the 78 drive link chain, but you have an 80 drive link chain, then no matter how far out you adjust the bar, you may not get the chain tight enough. PartsBuggy shows a listing of which bars use the 78 drive link chains here.
Aug 29, 2011 | Poulan Pro Chain Saw 46cc 20"
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Where can i get a bar and chain for my poloun pro 330 made in 07. it has a 3/8 by 50 guage by 22" bar
You can buy parts including the bar and chain for the poulan 330 at http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-330/1324/1503220/P0401184/00003
However poulan saws are made by Husqvarna so if you have a Husqvarna dealer near you he will probably have them available.
Dec 30, 2010 | Sport & Outdoor - Others
Pro 330 chain will not runbrake does not work
Hi, I can't be much help here sorry, the brake is an essential safety feature, it must be serviced. Sorry
Jul 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Sprocket won't turn with bar and chain in place. Turns freely with bar off.
It's possible that you have the anti-kick brake on or you have the chain adjusted too tight. The guard in front of the top handle should be all the way back to release the brahe. Hope this helps you
Oct 16, 2009 | NRS Oregon Bar And Chain Set For Echo...
Broken bolt that holds chain bar in place
As you know, your chain saw is obsolete, However, go to this website and they will have what you need:
http://www.cmsmallengines.net/echo-kioritz-c35.html
Good luck.
Jan 13, 2009 | NRS Oregon Bar And Chain Set For Echo...
Poulan Pro Chain Saw 46cc 20" Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
