Question about Traulsen AHT132W-HHS Stainless Steel
Hot box not getting hot (175 deg f) - Traulsen AHT132W-HHS Stainless Steel
    Sergeant:
  • 183 Answers
I would recommend that you call a serviceman to troubleshoot and fix the hot box.
Posted on Dec 30, 2010
How long to roast 0.88kg pork leg?
1 hour at 350 deg or 175 c
Apr 29, 2016 | Ovens
Toner not stuck well on paper and can be easely erased by hand
Sounds like you have bad toner. or fusing area not getting hot enough to fuse to paper. I would try another toner cartridge. If problem goes away. Bad cartridge.
Feb 21, 2014 | Ricoh Aficio Mp4500 Mp3500 Cl7000 Ap3850c...
My 07 ford e250 4.6 ac system my low side at idle 75 n my high side is 150 wats going on
It depends what temperature is outside and whats been done to ac syst! Preasures should be if 134a low at 32psi to 45 and hi side from 175 to 250psi the hotter weather higher preasures the colder the lower preasures! if around 70 deg out low side 32 n hi 174psi ! you may have a expansion valve clogged or orifice tube clogged! Get more inf 1_3_2014_2_37_21_pm.jpg
Sep 07, 2013 | Cars & Trucks
The lowest setting on the dial of our Imperial oven is 175 degrees F. If we set the dial below the 175 mark, could we get the oven to level out at a lower temperature? We're looking to achieve a stable...
The temperature figures on the dial are a guide only. Play with the dial, you will pick up where the thermostat cuts in and out. 130 deg. is rather low, but it could be achievable. You will only find out through experimentation - nothing will be damaged.
Jan 31, 2011 | Imperial ICV-1 Turbo-Flow Single Oven
My 2004 A4 1.8 Audi's water temperature does not go above 150 degrees F. What can be the problem
Check the engine thermostat!
Thermostat checking:
1. Cold engine. Start up the engine and watch of the water temp indicator. After first value 140 degrees F you still warm up the engine until the lifter (pointer) reach 175 deg. F (second mark after 140 deg. F). At this time you let engine running at idle speed and check with your hand the thermostat plastic housing and hose temperature in bottom left side of the engine. Heed of alternator driving belt and ventilator fan !!!
2. If the thermostat is good the hose must be cold until the water temp indicator reach almost 195 deg. F.
3. The thermostat opening temperature is 188 deg. F.
4. If the hose is already warm the thermostat is out of order.
Replace the thermostat if necessary!
Please do rate my response. Thanks!
Jan 11, 2011 | 2004 Audi A4
My question concerns the electric cooling fan attached to the radiator: Should this fan come on automatically with the A/C compressor? After having some work done on the A/C, the fan comes on with...
With a/c on, fan needs to be on all the time, to reduce pressure it the a/c condenser, or a/c will not cool to it's max, with a/c off, fan will only come on with engine temp. between 215 - 200 deg, when it get's down to about 210 deg. fan will shut off. and come back on when it get's back up to 215 -220 deg.
Aug 16, 2010 | 1996 Dodge Caravan
My trans fluid gets really hot after about 2 miles from 70 deg far to 132 deg f
try changing the trans fluid and filter, if the filter is plugged up it will make the trans work harder to pump the fluid and making it get very hot
Mar 21, 2010 | 2004 Pontiac Grand Prix
Running hot
You either have a head gasket problem or the
coolant system wants bleeding as air is being trapped in it .
Take out thermostat and try bleeding and driving without it in if ok then try the old one or a lower temp one
Let me know how you get on Ron.
Sep 29, 2009 | 1997 Ford Mustang Cobra
Simpson 175 wont take on hot water
Your water inlet valve is bad on the hot water side and needs to be replaced. It is located right after the supply hose for the hot line behind the back plate
Feb 13, 2009 | Whirlpool Washing Machines
Traulsen AHT132W-HHS Stainless Steel Logo
71 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
