Question about Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER
I have a 11" Solid
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
yes i would remove that washer, if you are talking about the one by the threads. where you screw on the wall pipe..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 30, 2010
Would like a parts schematic for a Bb400 gold tone bass banjo
This is a list of All the parts you need, I don't know about a schematic?
1 Maple Neck ? 1 11" wood rim ? 1 11" notched tension hoop ? 1 Flat head alloy tone ring (Optional bell brass available) ? 1 Resonator (not included in the open back kit) ? 1 11" Remo frosted banjo head ? 1 Arm Rest ? 2 Coordinator rods with hanger bolts (one longer than the other) ? 1 "L" shaped tailpiece bracket (may be attached to coordinator rods) ? 1 5th string nut ? 4 Guitar style tuners (planetary tuners optional) ? 1 Geared 5th string tuning machines ? 24 Shoe style lugs with bolts and washers ? 24 Hooks and nuts ? 1 Nut, pre notched ? 4 Resonator plates ? 4 Brass inserts (brass anchors that are threaded on the inside) ? 4 Resonator bolts (knurled on the outside with a Phillips screwdriver receiver on top) ? 1 5 string bridge ? 1 Gary Price style Tailpiece ? 1 Set of strings ? 22 Pre-cut (ready to install) frets ? 1 Truss rod cover (including three screws)
Mar 06, 2015 | Bass Music
What is the scrap value for brass
Current Price under 100 pounds $1.45
Current Price 100 to 200 pounds $1.48
Feb 12, 2014 | 2282 Satin Brass Push Plate 2-1/4 Inch x...
Cannot remove from wall
There are bolts through the top. Usually lay flush with the cabinet inside. Sometimes they are patched over.
May 20, 2012 | Microwave Ovens
Toilet running and won't stop.....it keeps running into the little overflow tube
When water goes over into overflow tube then that means 2 things.
The rubber flapper at tank bottom is good and does not need replacement at this point.
That leaves 2 possible problems.
1) The flush valve needs to be adjusted so water turns off sooner.
Flush valve lets water into the tank.
For example if you have a float ball on end of brass rod, just bend the brass rod so the float sits lower in the water.
If you have the 'fluidmaster' then a float rides up and down with water level. There is a metal rod with a metal clip. Squeeze the metal clip and move it downward on the metal rod.
2) If water will not turn off after adjusting flush valve, then replace flush valve.
Local hardware store sells the part and can help with instructions.
You need a crescent wrench or large adjustable pliers.
Plumber can also install the flush valve.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plunbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 17, 2011 | Kohler Persuade Two-Piece Elongated Toilet...
After about 3 months of use our Hansgrohe 10" Downpour Air stopped "raining" and began "streaming." Solid streams of water stream down.
do you by any chance have hard water? Calcium or lime buildup around around the spray holes will restrict the openings and result in higher pressure/lower volume streams. A good soaking in CLR should clear up this problem.
May 08, 2011 | Hansgrohe Downpour AIR Showerhead - 10",...
When I turn on the dishwasher, the sprayer does not turn. There is nothing blocking it or restricting the movement.
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Feb 19, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Bathroom stall shower
Most handheld showers use a hose to connect from the existing shower arm down to the hand held option.  Some units come with attachment points on the shower arm, but I believe that you are looking for a unit that has a hook that you can mount where ever is comfortable for you.
Oct 16, 2008 | Home
Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER Logo
49 people viewed this question
Top Ace Hardware Home Experts
Donni Steen
Are you an Ace Hardware Home Expert? Answer questions, earn points and help others
