Question about Dryers
Kenmore elite dryer model 11082826101 will not heat. Replaced the element but still no heat. Help...
  • Barrett Palumbo
    Barrett Palumbo Dec 30, 2010
    how did you figure out the element was bad in the first place
  • Dryers Master
  • 8,220 Answers
The thermistor could be bad or one of the limits on the side of the heater chamber.
Kenmore elite dryer model 11082826101 - themobilian_615.jpgthemobilian_614.jpg
More Here
Posted on Dec 30, 2010
Kenmore dryer he4 elite dryer not heating model #95862402
using multi-meter need to check the heating element and the thermostats for continuity. you are getting a full 240 volts at the outlet right? if only 120 then u will be able to run the appliance but not the heating cycle.
Sep 25, 2014 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore/whirlpool dryer without heat. I checked the thermal cut of and high limit thermo and they are good. The instructions say to test the thermistor i need to check the resistance on the
It's always possible that you heating element itself is OPEN? Use an ohmeter and measure for a VERY LOW resistance across the coils after you've unplugged and gotten into it far enough to do that. Be sure and remove the terminals that go TO the heating element so you won't get a false reading. THEN, I'd go to Repairclinic.com and put in your model number and look for this "thermistor" It's probably listed and if you look close enough, it may tell you where it's located. Nice to know a few folks try to repair before tossing.
Jul 19, 2014 | Kenmore Dryers
Need to replace the heating element in my Kenmore Elite Model 11062942100
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11062942100/0582/0151200/P0103155/00003?blt=06&prst=0&shdMod=11062942100
Hello tarkington, here is a parts diagram to start with. To replace the heating element, all you really need to do is take out the old one, and hook up the new one. It's that easy.Here is a video to help you with disassembly if needed.
http://www.youtube.com/watch?v=2bVoelV7M7Y
And finally a video of a heater element being replaced. It's not exact to your model, but it might help.
http://www.youtube.com/watch?v=_yL-WO_eRic&feature=relmfu
I hope that you find this helpful. I will be more than happy to help if you need any further assistance.
thanks,
Mike
Jul 21, 2011 | Dryers
Kenmore Elite 11063932102 is not working but no heat come out. What may be the problem?
is it coming on like it should but just is not heating if so it can b a number of things like a heat limit switch ,heat selector switch, heating element bad , a wire burnt off heating element or the switch on the motor (on some models)
Jan 24, 2011 | Kenmore Elite HE4 Electric Dryer
No heat in my kenmore elite dryer, model 11085872401(electric)everything else running, tested voltage at 240 ok. pulled the heating element. it looks like a small crack in the middle. Does that have any...
It means your element needs to be replaced, take it to the Kenmore parts store nearest you, and they will confirm that, and you can get a new one there unless they have to order one in.
Be sure to have the make and model and serial number of your dryer with you.
Dec 15, 2009 | Kenmore Dryers
Kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
No heat
Sears Kenmore electric dryer model #110.96320100 will not get hot.
Nov 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
152 people viewed this question
Top Dryers Experts
