Question about Vtech Lands Phones
I do not have any messages on my machine however the red light will not go out . I tried pushing and holding the Chan/Remove button to clear the phone but that did not work. Please advise
  • phyllis326 Jan 03, 2011
    Working fine. Thanks for your help.
  • 2,069 Answers
Power off, unplug base from wall unit for about 10 minutes, and plug it back this should reset your unit and error will clear.
Posted on Dec 31, 2010
How do I turn off protocol monitor on sharp fax model fo-235
Had exact same problem on UX 177. You need to clear the memory. On the UX 177 unplug machine, press and hold down the COPY button then press and hold down the STOP button. Keeping these two buttons pressed plug machine in. It should display message "clear memory ?" let go of the COPY and STOP buttons and press the START button. Will then display message "memory cleared". This will also wipe out all other programming but it is the only way to stop protocol report. Then reprogram all your settings.
That stopped protocol report printing after each fax. On some machines it may be the stop and start button the need to be held down on startup. It also seems to make a difference which button you push first even though machine is unplugged.
This problem returns after a power failure so if you have a lot of numbers programmed in you might want to get an inexpensive uninterruptible power supply or plug fax into UPS for computer if you have one.
Mar 03, 2011 | Sharp Office Equipment & Supplies
When I try to send a fax I get a redo message and no pages are sent...i have sent many faxes to this number....a message appeared after one page was scanned that said to prress clear and srop...i could not...
Please reset the Printer by following these steps:
Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
Release "Stop/Reset" while holding down the "Power" button.
Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
Push the "Power" button, then lift the MX310 cover open.
Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Feb 27, 2011 | Canon MX310 Office All-In-One Printer
Parental lock code has been lost how can i unlock and reset code
Without a model number I'll have to list several solutions.
Push Vol Down and Chan Up on the set at the same time, Then go to password screen and enter 0000.
Reduce Vol to minimum and hold Vol Down on set and Vol Down on remote.
Hold Vol Down on TV while pushing "TV" button on remote for 3 seconds.
With TV OFF, press and hold Vol Down on TV and "Clear" on remote for five (5) seconds.
Press "Menu" button on TV and "TV" button on remote for 3 seconds.
Some models use the Vol Down button on remote instead of "TV" button on remote.
With Remote go to Parental Menu and enter 2211 for code.
Go to parental Menu and press Mute, Display, Clear, Reset in sequence on the Remote.
Press "Menu" button on the set and Vol Down on Remote for 3 to 5 seconds.
With remote go to parental screen and press Chan Up and Vol Up on the front of set for 3 to 5 seconds.
Jun 05, 2010 | RCA DRD485RG DirecTV DTV Receiver
Don't know how to light the pilot light in the oven.It is a Garland ten burner two ovens. It is about 11 years old. Where is the pilot light and how do I light it.
Most commercial ovens have a manually lit pilot. There will be a button somewhere on the range that you will need to push in so gas will come out of the pilot assembly. While holding this button you will the light the pilot and will need to hold the button in for about a minute or two until the pilot stays on after you release the button. Look around the bottom panel,top panel or side panels(you may need to remove one) to find the button. they are usually red and may not look like a button. If you find the button and the pilot does not stay lit then the thermocouple might be bad. If you push the button and do not get any gas coming out of the pilot then there might be debris in the pilot assembly causing the gas not to come out. In that case you could try and tap the assembly or blow with compressed air to clear it. But in most cases you will need to remove the pilot assembly and use a really fine wire(like a metal tie-strap minus the coating) to clear the pilot orfice.
Sep 30, 2009 | Garland Ovens
Trying to program my guesTVision CL034 remote to control a Mitsubishi tv.
Turn on tv. On the remote, hold down 'Code Search' button until red light comes on remote. Press 'Chan +' button (on remote) repeatedly until the channel changes. Be patient, this could take lots of pushes. Once the channel changes on the tv, push the 'mute' button on the remote. You're set!
Apr 18, 2009 | Philips Televison & Video
My Saeco Giro keeps flashing red, what's wrong?
Hold the water button in for about 15 seconds.
Mar 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Error code on electrolux
Haven't tried your solution but I'm keeping it in mind. I talked to a repairman and he suggested I remove the panel at the bottom of the dishwasher (left side). There I will see a red button which is the control board processor reset button.
This worked but if the problem reoccurs I will try your solution as it is easier than removing a panel.
Dec 28, 2008 | Dishwashers
Blinking red light for "new message" will not turn off (model DECT2085)
Try pressing and holding the "find handset" or "page" button on the basestation until the phone stops beeping. This should clear the new message LED indicator.
Nov 07, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Trying to reset "message number" back to 00
that is the number of messages you have on your machine. If you don't like having messages, then you can delete them by pressing and holding the Play/pause button (blue button below the red answering machine light) until messages start to play. once they do, hit the remove button for each message you want to remove. Kepeech?
if you don't like having a message number higher than zero, then you probably shouldn't have an answering machine! :)
May 19, 2008 | AT&T 1855 Phone
Lands Phones Logo
522 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
