Question about Black & Decker Toaster Ovens
Need bake/broil knob. It just cracked in half.
  • 4,323 Answers
Hi
You can buy the parts from this link. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 30, 2010
The toast part works but the bake and broil does not work , the blue light does not come on and no heat is produced
We've got the same problem and I just took ours apart.
Bad news: I'm pretty sure it's the circuit board. It's not the timer knob, and I'm almost positive it's not the upper selector knob. Most of the components on the circuit board are only used for the "bake" mode to regulate temperature. The board is marked, "128301 Timer PCB". I looked into whether one can buy a replacement board from Kitchenaid, but it's not on their parts list. If I had to guess, I'd say it's the relay on the board, but it's only a guess. Shoddy components, plus it gets hot in there and "bakes" the board. The little fan in the side isn't part of the "convection." It's for cooling off the circuit board. Don't laugh.
Even worse, next to the thermostat on ours, there's a little rubber insulator that's burnt to a crisp. The connection under this insulator was also loose. It hasn't affected functionality, but it doesn't instill confidence in the design. Kind of scary. Unplug this unit when not in use!
Only a one year warranty. I think we now have an expensive toaster.
Jul 24, 2011 | KitchenAid KCO1005OB 1400 Watts Toaster...
The middle black knob on my toaster has been lost which then prohibits me from switching the setting from broil to bake etc. How do I got about getting a replacement knob for my toaster oven?
Try this web address for a list of websites that sell oven parts. Hopefully you will find one that carries it.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Mar 13, 2011 | Euro-Pro EuroPro 6Slice Toaster Oven with...
I need to purchase a replacement for my toaster over #6233 - I need a new Baking Pan & Broiling Tray. Mine is very soiled and will not clean
FYI Oster Toaster Oven: about 18 months ago after careful consideration we purchased a counter top toaster oven for the RV from WalMart. I have a 20+ year old Oster Kitchen Center and found easy access to repair parts a couple of years ago, very pleased.
Last trip out in the RV the timer knob stripped out after what I would describe as a couple of months of light use. Google'd the model in search of a replacement knob only to find many others had "been there, done that". The model is obsolete and no service parts are available.
The Oster customer service rep seemed finished at this point and asked if there was anything else she could do for me. I asked what I, a long time Oster customer, should do with the useless oven. After repeating the question rephrased several different ways she put me on hold.
She returned several minutes later to inform me that as a "one time" courtesy Oster would replace our out of warranty oven with a current model. The replacement unit would have no warranty or support from Oster.
She supplied the model number and gave us an Order #. Looking up the model number and checking reviews I have very low expectations for the replacement. Most comment as to the poor quality and reliability of this current model.
A perfect example of a manufacturer who once produced a quality produce but now sells cheap imported disposable products.
YMMV
Nov 07, 2010 | Oster 6232 / 6233 1500 Watts Toaster Oven...
The broil element and bake element both come on set for Bake.
You are correct in your diagnosis. The selection switch has 2 sets of contacts that should only make one when on bake. The contacts internal to that fuse are most likely fused together, the other thing that could be going on is a short circuit in the wires to the selection switch causing the same problem. Typically a repair unless under warranty would be costly unless you are up for the challenge of replacing the switch and checking the wiring yourself.
Apr 20, 2010 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
I bought a kenmore toaster oven. There were no instructions.
This controls the heating elements in the oven Briol// Bake// and Toast
Dec 16, 2008 | Toaster Ovens
Rotissere Toaster Oven Just Stopped Working
the problem is internal and it might be the fuse or the thermostat
Dec 05, 2008 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Blown fuse
You need to go to your local Harbor Freight Tools and pick up a security tool kit for $9.99 so you'll get the bits required to remove the special screws. You need to remove all the screws around the outer edge of rear and then pull the white rubber plugs out of feet and remove the screws from feet. Then the entire cover lifts off of unit. That exposes where the power cord enters the back of unit. You'll see a smaller black wire leaving that area going over to the timer knob. Before the wire gets to the timer knob, there is a sleve covering the wire. If you'll cut the zip tie holding all the wires together, you can slide the sleve (mine is red) backwards toward where the power wire comes into unit. That will expose the inline fuse that is blown. You will need to call Delonghi to order the wire. It is pressure fitted on. You should be able to pull the connectors lose by hand on each end. Simple fix!!
Dec 28, 2007 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
Toaster Ovens Logo
131 people viewed this question
Top Black & Decker Toaster Ovens Experts
Dave
Dave
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
