Question about HP EW192AA Webcam
I cannot find an icon to turn it on and use it I was much happier with the XL program. . I have had this computor for about 7 months
How do I add app icons to my home screen computor
Using windows explorer locate the .exe file for your program and right click on mouse for options. Choose "shortcut to desktop"
Oct 05, 2016 | Computers & Internet
How to remove "RealPlayerCloud" under computor icon?
Uninstall Realplayer and it will go. Reinstall Realplayer and tick the box saying No Cloud.
Dec 07, 2014 | Toshiba Satellite Computers & Internet
2004 Suzuki Gran Vitara Keyless entry
Try this
2004 XL7
1. Remove key from ignition switch.
2. Close all doors.
3. Open drivers door
4. Insert key and turn to ON position and within 10 seconds turn
key off and remove key.
5. Within 20 seconds Close and open drivers door 3 times.
6. Insert key and turn to ON position and within 10 seconds turn
7. Locks should now lock and unlock automatically to confirm you
have entered programming mode.
8. Press the UNLOCK button on remote and locks should cycle to
confirm programming.
9. Repeat step 8 on each additional remote.
10. Exit vehicle with keys and remote, close door test remote(s)
Jun 01, 2014 | 2007 Suzuki XL-7
How do i fix the editing options on the Windows 8 Start Screen?
If you are happier with the win 7 desktop and menu bar you can install a program to make win 8 look like win 7
http://www.iobit.com/iobitstartmenu8.php
May 07, 2014 | Computers & Internet
My computor does not delete files from the hard drive even though it says it does. May hard drive keeps building up used space and I have deleted lots of programs, but the space is still occupied with the...
your computor may have been infected with a virusshutdown computorpower on while tapping the F8 key until you see advance boot optionchoose safe mode with networkingobtain HijackThis from trendmicro.comrun and kill all HJT tells youreboot computor
Jan 24, 2012 | Microsoft Windows 7 Home Premium Family...
Please inforem me the way to remove NERO 7 software compleately from my computor
What OS are you running? Windows XP/Vista/7?
Usually its
START > Control Panel > Add/Remove Programs (Vista - Program and Features) > Find Nero and uninstall "FULL"
Dec 15, 2010 | Ahead Software Nero 7 Essentials Suite...
My starter on my 2002 Suzuki XL 7 died today in my garage. At first I thought it was my battery...battery is fine. I was told it sounds like my starter since there is not juice or sound when I turn the key...
The first thing is to make sure the battery terminals and connectors are clean and free of corrosion so the starter can getr enough power to operate. To find your starter follow the large red wire that goes to the bottom side area of the engine. It will be held on by two bolts.
Mar 26, 2010 | 2002 Suzuki XL-7
Reprogram remote
xl-7 programming instructions first you need to stuff your head up under the dash and locate your module drivers side upper corner under dash does it say programmable transmitter (the first models had no programable modules) if it says that then......
1 confirm all doors are shut and key is out of ignition
2 open drivers door insert key and turn to on within 10 sec
3 turn ignition switch to off in 10 sec
4 push and release drivers door switch 3 times in 20 sec
5 turn ign. switch to on in 10 sec
6 turn ign. switch to off in 10 sec
7 press and hold lock and unlock button on transmitter for 5 sec within 20 sec of step 6 alldoors will lock/unlockto confirm correct process
8 press lock unlock buttons on second remote within 5 sec after step 7 once again all doors will lock/unlock to confirm
9 to add another remote up to a max of four repeat steps 1 through 8 this was taken directly out of an owners manual supplement that comes with a new keyless entry kit (part number for a xl-7 or grand vitara can't remember which one it goes to but it works on either one is 84900-67810) which you would have to purchase if yours is not programable these instructions are the same for vitara, grand vitara, xl-7 and the esteem hope this helps
Jul 05, 2008 | 2002 Suzuki Grand Vitara
Product won't download to my computor
Mine's doing the same thing. I have tried loading it onto two different computers. I was going to format it and try just using it as a USB storage device, but i don't think it would display the pics then. I'll probably be returning it.
Dec 25, 2007 | Innovage Mini Flip Phone 1510255
HP EW192AA Webcam Logo
20 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
