Question about Whirlpool Kitchen Ranges
New cooktop. spilled food how to I clean it up
I need more information. Smoothtop? Gas? Electric? Stainless steel? Smoothtop, scrape what you can off with a plastic credit card or something similar. If necessary use a razor blade. Finish cleaning with a liquit polishing top cleaner made for smooth top ranges. Regular use will leave a smooth finish that will make it easier to clean. Us only a plastic pad or other non abrasives. Regular porcelain top. clean up as best you can with a dish rag. scrape with a plastic tool. Use oven cleaner if necessary. Don't get oven cleaner on painted or aluminum items. It will remove numbers, writing etc and badly stain aluminum.
Posted on Jul 08, 2008
How do i clean my cooktop on a whirlpool 465
Light Cleaning
  • Clean your CERAN cooktop after every use. To remove simple spills, wait for the surface to cool before beginning the cleaning process. Pour a small amount of cleaning cream on a damp paper towel and wipe the cooktop surface until the soil and cream are no longer visible. The cleaning cream will leave a protective finish, which will preclude scratches and other types of damage.
  • Heavy Cleaning
  • Wear a heavy oven mitt to remove burnt foods or liquids while the cooktop is still warm. Use the metal razor scraper to remove the substances that are stuck to the cooktop surface. Once the cooktop has cooled, use a damp paper towel to spread a small amount of cleaning cream over the entire cooktop surface and wipe it thoroughly until the cream is no longer visible. Rinse the cooktop with water and dry with a clean paper towel.
  • Cleaning Melted Substances
  • Remove melted plastic, foil or other kitchen products immediately using the metal razor scraper. Spills containing sugar, such as ketchup, tomato sauce, syrup or pudding, must also be removed with the metal scraper at once. It is best to remove these substances while the burner is still hot. Once the melted substance has been removed and the cooktop has cooled, use a damp paper towel and cleaning cream to complete the cleaning process. To protect your hands, remember to wear a thick oven mitt when cleaning the hot cooktop.
  • Tips
  • Scratch marks resulting from daily use will not interfere with the performance of your cooktop. Pots and pans with flat bottoms and those that cover the entire burner surface are recommended for use on your CERAN cooktop.
  • Warnings
  • Spills containing sugar may permanently damage your cooktop unless the substance is removed immediately. Use only the recommended cleaning products on your CERAN cooktop to protect it from damage. Do not use scouring pads, plastic coated sponges or abrasive products of any type. Do not use oven spray or any other type of cleaner containing ammonia or chlorine. Clean all spills thoroughly before using your cooktop again.
  • Nov 07, 2010 | Whirlpool Cooktops
    I have a bosch cooktop 5 burner and one burner lites its very dim and then goes out
    Is this cooktop new? Was it converted to propane or do you use natural gas? If it was converted, I was just thinking they put in the wrong size orifice. If it has been working fine and is just now giving you problems, then check the burner holes and see if they are partially plugged from food spills.
    May 18, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
    Igniter ticks but burner will not light. Gas is flowing
    The gas burner holes near the igniter made be clogged if you've spilled food on them. Use a sewing needle to clean the holes.
    May 12, 2010 | GE 36 in. JGP628 Gas Cooktop
    Liquid spilled on cooktop Ceran schott
    You will have to clean the control area connections .
    Oct 09, 2017 | Cooktops
    Can't get GE profile cooktop clean
    the problem is you didn't clean the unit before you used it the first time w/ the ceramabrite wax. the glass on your cooktop is porous and unless you seal it before ever using whatever went into the pores originally will always be in the pores and no amount of cleaner will get it out.
    Jan 23, 2009 | GE Profile JP930 Electric Cooktop
    Ignitor quit working on GE Monogram ZGU375NSD3SS...gas stovetop
    If it still clicks and tries to spark, get in there with a a toothpick or a pin and clean out any spilled food and / or carbon build up. If the sparker itself doesn't even try, it will need to be replaced.
    Jan 04, 2009 | Jenn-Air 35 in. JGC9536 Gas Cooktop
    Maytag gemini schott ceran stove top
    Sugar spills on a hot surface will 'pit' the glass surface. There is no way to repair. The damage caused to the surface is only cosmetic and will not affect the performance or operation.
    Jun 16, 2008 | Cooktops
    Regular spill stain problems
    We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
    Jun 13, 2007 | Maytag MEC5430 Electric Cooktop
    Kitchen Ranges Logo
    168 people viewed this question
    Top Whirlpool Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
