Question about Maytag Dryers
How do I replace the idler pulley on my pye2300ayw model maytag dryer?
SOURCE: Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Posted on Jun 12, 2008
rickzilla
  • 706 Answers
SOURCE: how to install the belt on a Maytag Dryer modek MDE9420AYW
This should give you a few ideas on how it works.. Hope this helps...
Posted on Sep 13, 2008
SOURCE: how to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Posted on Dec 04, 2008
  • 3 Answers
SOURCE: How to route belt around pulley and idler
repairclinic.com
Posted on Jan 28, 2009
Maytag317
  • 1136 Answers
SOURCE: Maytag model PYE2300AYW won't do anything at all
Hi, Did you check the safety fuse on the right side of the heater housing? Little fuse with two white wires going to it?
Please let me know if I can assist you further.
Vic
Posted on May 23, 2009
I need to know where the idler pulleys go on the motor
Dryer Repair- Replacing Idler Pulley Wheel (Whirlpool Part ...
? 13:58
www.youtube.com/watch?v=WX0KjiQJWpY
Apr 7, 2011 - Uploaded by PartSelect Dryer Repair- Replacing Idler Pulley Wheel (Whirlpool Part# 6-3700340) ... Kenmore, KitchenAid, Roper, Maytag, Crosley, Jenn-Air, Hardwick, ...
Sep 15, 2015 | Dryers
Does a kenmoore 80 series have glides
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-PYE2300AYW/3048/0151200?pathTaken=&prst=0&shdMod=PYE2300AYW
go here and you can see the parts in your dryer,if the model isn't a maytag pye2300ay then just put your model number in there and it will show you,kenmore doesn't make anything,you go by the model number if it starts with 110. it's a whirlpool,if say 417. it's frigidaire made but the maytag model you sent has rollers and i would say if you have a kenmore 80 series it has rollers,you can buy a kit that comes with the rollers,belt and belt pulley
Nov 14, 2013 | Maytag PYE2300AY Electric Dryer
I have a Maytag SE-1000 stacking washer dryer setup. I am trying to replace a broken dryer belt, and have the disassembly done, and the replacement belt in place. My problem is trying to understand how the...
Most dryers are tension idler pulley directed but must first go around the grooved pulley on the motor shaft. make sure the idler goes on the smooth side of the belt and the grooved side of the belt is in the grooves on the motor shaft.
Oct 13, 2013 | Maytag Dryers
Re~attaching spring on Maytag Dryer PYE2300AYW While replacing the belt the spring slipped off and I don't know where to attach it to, one end is on the idler, where does the other end go?
If I am not mistaken, your spring called a Idler spring should mount to the motor mount and the other end to the idler arm. But if you do not remove the drum from the dryer it will be hard to see how to re-install the spring. Remove the drum to make your task easier for your self.
Good Luck
Oct 11, 2011 | Maytag PYE2300AY Electric Dryer
How do you replace a heating element on model # PYE2300AYW electric dryer
Unplug itthemobilian_181.jpgthemobilian_182.jpgGo ahead and take the front off, clean and inspect the dryer for lint. Check the blower wheel for looseness.themobilian_183.jpgthemobilian_184.jpgthemobilian_185.jpgthemobilian_186.jpguse some zoomoil to lube the rollers and idlerthemobilian_187.jpg
Don't forget to check the glides. MORE GOOD STUFF HERE
Nov 17, 2010 | Maytag Dryers
Maytag DE303 dryer installing the drum belt
No don't lube the idler pulley replace it. There are videos at www.appliancehelponline.com/servicemanual.html that can walk you thru the disassembly and also on replacing the belt. You can also enter in your model # for diagrams and illustrations.
Apr 09, 2010 | Maytag Dryers
How do I replace the dryer belt on a maytag dryer model #pye2300ayw. How do you connect to the pulley and get the belt around the drum?
lift the hood by pushing in clip on either side. remove two screw at top inside to remove front. unplug first. thats as far as we go there. remove belt out of dryer. take new belt and put on drum groove side down, get it uniform around drum. putting belt on pulley might be easier to do from behind for you. two screws to remove small access panel.take belt under pulley and over and around motor pulley. turn drum slowiy to make sure belt is not twisted. this belt can only go on a couple ways and one is obviously wrong. good luck.
Jan 30, 2010 | Maytag Dryers
How do I change a drive belt on maytag model pye2300ayw
remove the back inspection panel, take the old belt off and put the new one over the series of pulleys and tensioners as you took it off, about 15 minutes work
Aug 15, 2009 | Maytag PYE4558A Electric Dryer
Drum belt tension
I found a dryer manual on the web that showed how the drum belt wrapped around the pulleys.
Problem solved.
May 11, 2009 | Maytag Dryers
Dryer belt slack
Start from the motor threaded shaft. Then pull out the Idler pulley so that the back of the belt will lying on the Idler pulley in upright position. that is all.
Mar 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
81 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
