Question about Nintendo Wii Console
The Wii turns on and will take a disk but nothing shows up on the tv screen.
  • buskogger_35 Dec 30, 2010
    All of the cables are in the right spot and its on the right input.
    President:
  • 1,102 Answers
Make sure that the cord from the console is secure in the Wii and the three colors are plugged into the T.V. in the same color plugs. There is a Yellow for picture, white and red for stereo sound. You probably need to access the TV menu and change the "input" to whatever your Wii is plugged into. For example "A/V 1" or aux.
Posted on Dec 30, 2010
When i turn on my wii it shows a blank screen
do you have it plugged in to the tv? if it is, for some reason red Wiis don't like to work. Mine doesn't read most discs
Jun 16, 2013 | Video Game Consoles & Games
My wii will turn on, but nothing shows up on the screen
Good news i had same problem and what i found out was that the wii bricked up an easy fix is to unplug ur wii from all cables then after 3 minutes plug only the power cable and see if ur wiimote connects but before dat remove sd and usb if the wiimote connects but u getno display then u have t afjust ur screen resolution hope this helps :)
Jul 03, 2012 | Nintendo Wii Console
When i turn my Wii on it does not show up on my screen all the time. Sometimes it does but not always. It usually shows up as a black screen. Everything else on the Wii works and I can eject disks and its...
try changing to a different input on the tv, or a different tv if you can(if you haven't tried that yet). if it stops then you know it's not the game but maybe the tv or the input. they do wear out from things connecting and disconnecting. you could also try a new cable from the wii to the tv. unplug the cables and check the length of the cable carefully to check for cuts or exposed wires (pets can chew them ect...). if you find anything odd, replace the cable right away. if you have ever had you wii modded in any way, that could also be the problem. even if it was a while ago.
hope this helps
Apr 17, 2011 | Nintendo Wii Console
Unit comes on and it takes the disk ok but then thats it
Make sure the drive to the Wii is upside down so its facing the ground and shake the Wii cause there may be loose debris in the drive.
If nothing comes out then the drive is bad. If debris comes out then try to load a game and if it doesn't load then the drive is still bad.
Nov 28, 2009 | Nintendo Wii Console
Power light is on on my wii but nothing is showing on the screen and blue light from disk area off
unplug the power cord from the wii and outlet and wait for a half an hour, then reconnect it
Nov 27, 2009 | Nintendo Wii Console
The wii menu does not appear on the tv screen but have green light on the wii console and i cannot close that wii...someone can help me..
First check your cable connection.
Eject the disk, if you have inside.
Unplug the console at the back
Wait 10 minutes
Plug it back in
Turn it on from the remote
Press reset if it does not show up
Hold the power button to shut it off
Turn it on once more.
If this not help may your Wii need service.
Oct 29, 2009 | Nintendo Wii Console
My wii wont turn on the power does not show a light
Try a different outlet to make sure the outlet you have it on is good or not.
If a different outlet didn't make it turn on then at that point, try another ac adapter for the Wii. If a different adapter doesn't work then you know the main board inside of the Wii is bad.
Aug 08, 2009 | Nintendo Wii Console
Wii wont show on tv screen
Blank white or blank dark screen
  • Is this your first time hooking up the Wii console or have you moved it to another TV or VCR? If so, please click here to review our step-by-step connection guide. Our experience shows that the majority of these issues can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
  • If you have verified the connection is correct, and are still receiving a blank white or blank dark screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please click here for repair options.
  • Sep 25, 2008 | Nintendo Wii Console
    GETTING INTO MY MII
    you dont have to check the cd slot. its not with the cd. its the mii creator screen. I suggest you wait a while before pressing anything
    Jan 15, 2008 | Nintendo Wii Console
    Wii Black Screen
    i put the wii on, powers up but i get a total black screen. wiimote does not connect either. what can i do to resolve this?
    i have already disconnected all wires and connections, left it off for hours and tried putting it on again. no change. Black screen still remains. HELPPPP
    Dec 01, 2007 | Nintendo Wii Console
    Nintendo Wii Console Logo
    289 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
