Question about GE DVL223GB Gas Dryer
GE Gas Dryer Replace the belt Model # DDG8280G
I am trying to treplace the dryer belt and can't remember how I did it last time
    Scholar:
  • 170 Answers
Usually there are one or two panel in the front that are held by some screws. Once removed the top panel is usually attached to the front panel and you can get a screwdriver and release the plastic push in retainers. Prop the top up and the drum is exposed. The belt usually goes around the drum down to a drive pulley on the bottom of the machine. You will need to route the belt around the drum in the front or back to get it routed correctly.
Posted on Jul 08, 2008
My GE DSXH43EA2WW Dryer is making a squeaking sound when running. Tends to get less noisey as the dryer continues to run
Hello
You will need to replace the dryer belt and inspect the belt rollers while you have it apart. If you go to the web link below it explains how to take apart the dryer to replace the belt, it has additional links to pictures and diagrams within the instructions. The first link is for replacement parts with diagrams of the dryer. Here is that link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130504&diagram_id=21844825#d21844825
The next link is the Do It Yourself Article on replacing the dryer drum belt. while you have it apart remember clean the lint and dirt out of the cabinet interior. Here is the repair link:
http://www.applianceaid.com/ge-dryers.html#belt
Jan 14, 2011 | Dryers
How to replace belt on Ge dryer # DNXR473GW0WW
dryer was working ,when wife checked on it , the dryer had stopped with 20 min. left. now it's as though there is no power to the mach. I have checked and there is power at the location.
Feb 02, 2010 | GE DBSR453GBWW Gas Dryer
The dryer does not turn on. I replaced the start switch and still no action. The dryer has power to the unit, I say that because the dryer light goes on, but I get nothing when I flick the switch. The last...
This is a GAS dryer, correct? That's what the model number you gave me referenced to. There is a thermal fuse on your dryer that you need to check. It should read a short (0 ohms) if good. Unfortunately, you will need to remove the drum to access it. Appliancepartspros.com has an excellent exploded view diagram of your dryer. Just type in the model number you provided and look under the "Drum" section for item 530. The thermal fuse detects an overheat condition and will trip like a fuse. You may have overheated the dryer when you were drying your comforter. When was the last time you had the exhaust ventilation ducting checked? If you can't remember, it may be a good time to inspect the ducting and dryer interior to ensure you have no clogs. Poor airflow is the number one cause of dryer failures. Just something else you may want to consider before replacing any components.
Another thing to check for is a broken belt. Your dryer is equipped with a broken belt interlock switch. If the belt snaps, the interlock stops the drum from turning to prevent the belt from wrapping around the motor shaft (a real bear to remove when this happens). A picture of the interlock can be viewed under the "Backsplash, Blower and Motor Assembly" section as item number 803. If you open the dryer and notice a broken belt, this may be your only problem. A new belt is listed as item 213. The key again, is the comforter. The heavy weight could have taken its toll on an old belt and it finally broke.
If you don't know how to route the dryer belt, repairclinic.com has dryer belt diagrams under their "Repair Help" section.
If my diagnosis is incorrect, please post back and elaborate a bit more on your symptoms.
If you have questions, please let me know. I hope this helps you.
May 03, 2009 | GE Dryers
Clicking noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
vbmvc
Jan 29, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Fixing a gas dryer belt
That I believe is an older model GE with the idler bar instead of the short bar. I believe there is also a rear panel that you can remove to gain access to it. I dont remember for sure if it keeps tension up or down. Loop your belt around the motor pully, then find out which way it keeps tension on the belt, then loop the belt around the idler pully and release so that it keep tension on the belt itself. Let me know if you need further information.
Feb 06, 2008 | Dryers
GE DVL223GB Gas Dryer Logo
231 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
