Question about Nerf Maverick Blaster
I **** it back and then hit the trigger and it won't fire... it rotates the barrel and after about a minute or so of pulling the trigger rapidly it will fire. i want to be able to shoot normally and i did not do anything to it... this is the way it was when i opened it
    Problem Solver:
  • 11 Answers
The factory must have left out a certain spring I could only explain to you if you've modded it.
Well, I'm going to explain anyway-
When you pull the trigger there is a mechanism is triggers that releases the plunger system, therefore compressing the air and firing the dart out of the turret. The factory (as I said before) left out the spring that makes the part move up or down as the trigger is operated, therefore making the gun malfunction.
My best suggestion- get a spring and add it in (if this is the case). Open up the shells/casing of the gun by unscrewing it apart and find the orange part next to the trigger.
Please email me at dluzzio@gmail.com a picture of the inside of your gun so I can analyze it.
If all else fails, take it back to the store.
Posted on Feb 27, 2011
Would the serial number be four digits 4425? ALSO TRIGGER WORKS TWO STOPS AND HAMMER ALSO BUT WILL NOT FIRE WHEN TRIGGER PULLED WITH HAMMER BACK.MORE LATER LIKE BARRELL WILL NOT LOCK
Yes to the serial number.
If you want to fire this weapon take it to a gunsmith for inspection and appraisal. The hammer should drop for full ****, as long as the safety is off if it has one.
Make, Model and Calibre is useful in such questions. :>)
Feb 24, 2017 | The Optics
How do I load the ****** Marksman 177 cal repeater
hold in right hand, depress cocking release with thumb, pull back cocking slide (takes some effort) till it locks out, push in on the lower front of barrel to rotate loading port to the up position (this won't move unless the cocking slide is pulled back), load BB in the top hole that is exposed (or a pellet in the lower hole), push loading port back down flush with barrel, push cocking slide forward. Marksman is now loaded. push safety button in so it is engaged. When in an appropriate place to shoot a target, push safety button back with your right finger (safety is off) and squeeze trigger.
Oct 17, 2014 | Optics
This is the izh 513m .177 rifle. It's brand new. I am not sure as of what to do and the hammer want budge and the trigger won't pull. The barrel has no tension and it won't go up like its supposed to.
This could be a factory safety that the hammer and trigger do not move while in the cocked position. The barrel may be locking down purposely. Look near the spring or in the path of the barrel where it folds back up and look for a release button. What do you see?
Jan 26, 2013 | Sport & Outdoor - Others
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Pneumatic stapler trigger stuck
The click sound indicates that the headvalve opened to fire piston down the barrel, however piston is already down or is stuck in-place. If the piston/driver is not broken or stuck, push piston to top of cylinder to reset. If only one shot and piston stays down, most likely the check band is broken. Check band is on the outside of cylinder (lower part) is is usually an oring or band of rubber covering small holes drilled into cylinder. Check valve /band is what causes the piston to return to top. If check band is good, most likely piston is bent or oring is too tight. If you open the gun, lube all parts with white grease or silicone paste lube. Good luck
Nov 03, 2012 | Air Tools & Compressors
Crossman Phantom break barrell air rifle will not **** after breaking the barrell open. Any suggestions as to the problem?
The barrel pushes the piston back when you **** it.
The seer grabs the piston to hold it.
It sounds like you have an engagement issue between your seer and piston.
Often there are springs which hold the triger paul and seers in place. You may have lost a spring which isnt allowing your trigger mechanism to reset after the trigger is pulled. This results in the trigger being permanitly in the fired position.
Good luck and hope this gives you something to look for
Mar 10, 2009 | BSA Air Gun Scopes
Nail Gun Problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Nail Gun Problem
Aug 27, 2008 | Dewalt DW073KD 1/4 Inch At 100 Feet Manual...
Nerf Maverick Blaster Logo
391 people viewed this question
Top Nerf Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Nerf Toy Expert? Answer questions, earn points and help others
