Question about Dryers
Hello. My dryer is not heating up. Are there some home troubleshooting things I can do before I call a repairman?
  • Barrett Palumbo
    Barrett Palumbo Dec 30, 2010
    not at all or slow drying
  • 32 Answers
A common problem with your dryer not heating up could be that the thermostat may need a reset. Depending on the model and make of your dryer, the thermostat is normally located inside the rear cover of your driver. You may need to undo a few screws to get to it. Once you have located it, look for a switch/button on the thermostat and press it. This should get your element heating again.
Posted on Dec 30, 2010
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
Hello- I have a Kenmore dryer #60952990 and the dryer turns but there is not heat. By reserarching other comments, I am assuming it is the heating element. So to be knowledgeable when the repairman comes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 08, 2010 | Kenmore 60172 Electric Commercial Dryer
Hello, Im getting no flame from the ignitor. Does that need it needs to be replaced
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 21, 2010 | Dryers
My dryer was working fine. I had professional mover move it to mynew home. Now just the air-only works and there is no heat. Is it easily fixable?
Yes, the ignitor broke it is very fragile... and that is very fixable...
heatman101
Aug 16, 2010 | Kenmore Dryers
Wed5300VWO dryer only dries clothes occasionally. Some times takes 1 1/2 hrs for small load. waist bands on pants damp etc, All thermostats have been replaced by repairman
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Aug 11, 2010 | Whirlpool Dryers
Our dryer is not heating up the air coming in. So our dryer is spinning, but cool air is being used. Help!
You don't mention whether this is a gas or electric dryer. If electric, your problem is most likely a bad heting element, or a bad thermostat. Both require some mechanical and electrical knowledge to troubleshoot and fix. Dangerous voltages are involved, so if you don't have the expertise, best to have a repairman look at it.
If gas, there could be any number of problems. Gas valve, ignitor, flame sensor, thermostat, etc. Again, natural gas system troubleshooting is best left to experts.
Dec 15, 2009 | Roper Dryers
Dryer will not heat; it runs but just does not get hot dryer is a Whirlpool LER3624EQ1 model
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
Good Luck,
Hope this helps
Oct 08, 2009 | Whirlpool Dryers
Dryer is spinning and working fine, just no heat to dry the clothes?
Hello Could be sevral things the motor that sopins the dryer and the control are 110 volt the heal element is 220 volt if you blew half the breaker you can get spin and no heat. If it is not the breaker it could be a bad element or a senso which would require a repairman
Jun 23, 2009 | GE Dryers
Electric dryer will not heat. Just bought off of craigs list
Chances are thermal protection switch has been tripped.
If you cannot trouble shoot electrical circuits you will need a repairman. Also good be heating element but doubt it.
Switch runs $20.00 to $45.00. Labor you can go to home depot Or lowes & replace dryer cheaper usually.
Hope who you bought from did not know it was broken. :-(
Mar 08, 2009 | Dryers
Kenmore Dry Model Number 110-70602990
Sorry I found it.Ok check 2 things first.#1 Heating Igniter (coil) #2 thermal fuse .
Jun 14, 2008 | Dryers
Dryers Logo
Top Dryers Experts
