Question about Canon PowerShot SD1000 Digital Camera
Camera stopped working in the middle of taking a picture. Lens is still in the out position. Bought a new battery hoping that would fix the problem and it did not. Haven't been able to turn it on again since.
  • Canon Master
  • 2,385 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Posted on Dec 30, 2010
How do you fix a stuck lens that will not retract when camera is turned off?
Hello, Remove batteries from camera, try pushing the lens back GENTLY with the palm of your hand, Notice I said "GENTLY" or you will cause more damage than good. If this won't work than take it for service / repair.
Best Regards, Russell
Jan 25, 2013 | GE X500 Digital Camera
Nikon Coolpix E 5600 will not take picture
your problem suggests that you either have a bad connection on your power side(battery not making good contact,or you have a bad connection to your apeture(shutter)if you feel comfortable doing this ,take the back plate off the camera and see if there is a loose conection to the internal circiutry on the battery side. also check to make sure there is no jam to the shutter and that there is no loose connection from your button to the shutter. please rate this. and post the results
Sep 23, 2008 | Nikon Coolpix 5700 Digital Camera
The lens will not retract on my Sony Cybershot DSC-S90 camera.
Hi there i like to inform you that its a lens guide pin problem. It is damaged or out of lens guide line. Thats why its stuck. The solution is only replacing the lens. But before that if you want to take a risk then on the camera and give a twist on the lens. Be careful. not much twist, just little. After that turn off / on the camera. If its working then fine. Other wise only the solution is contact with the service center and replace the lens.i am sure your camera lens position like a below mentioned picture.. before all this try to follow those step for luck.
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
May 06, 2010 | Sony Cyber-Shot DSC-S90 Digital Camera
Camera will not stay booted up
It seems that the Milli Amps on your rechargeable batteries are to low you will notice on each battery it will show the amplitude purchase a higher amplitude.
May 12, 2009 | Kodak EasyShare DX4330 Digital Camera
Error Code FE E
Make sure the F-stop ring on the lens is turned to the minimum aperture setting. Usually 22 or 32. The camera won't allow you to shoot unless it is. It will try to warn you by flashing the FEE code.
CameraRepairs
Aug 03, 2008 | Nikon N75 35mm SLR Camera
Picture won't take on auto
snoopytwo, jmv23 & guests,
Sounds like you have been taking photos in both auto & manual modes, make sure your f-stop is set at the range it needs to be to allow enough light for the camera to take the photo. Since the lens and the camera communicate, if the lens is closed down & not allowing enough light the camera will not take the photo - does that make sense - Look at the metering in auto mode and see what the camera says the conditions are for a specific lighting condition check to see if the lens has a aperture position for Auto, usually a dot on the lens ring to align with a setting in red or green (likely a F-22) depending on the make of lens, that has been moved to some place in the middle and not returned while trying other manual settings so the shutter won't release because the camera is told by the lens there is not enough light or slow enough shutter to take this picture.
randy320sgi
May 21, 2008 | Nikon N65 35mm SLR Camera
Camera wobn't turn on & lens stuck in out position
My camera stopped working during a wedding. The lens is stuch out, it will power on, but right after turning on, it beeps 3 times, then turns off.
Hope we find a solution!
May 14, 2008 | Samsung Digimax A7 Digital Camera
Casio Exilim EX-S500 Diaphragm Problem
Well, on mine the problem was inside the lens assembly. There is a ribbon wire that runs along the inside wall of the lens housing (that powers the diaphragm motor) and, as the lens is retractable and there is a zoom mechanism, it forms a loop, so it can extend and retract along with the housing. In my camera, this wire formed a crack right in the middle of that loop. The crack does not extend along the whole width yet, so in certain zoom positions there actually is an intermediate contact, so that the diaphragm actually works if you use the intermediate zoom, but does not work in max or min zoom positions.
As for fixing it, the only thing you can pretty much do is to replace the whole lens assembly. That wire is a branch of a bigger one that powers other motors in the lens, so you can't really remove it easily, and besides, no one carries it by itself. The new lens assembly is $380 from the parts supplier. So I just bought a broken camera off ebay for 9 bucks, with a functional lens. When it comes in, I'll just replace it. The replacement part is actually pretty straight forward. The lens assembly is held by 3 snap tabs, so just disconnect the wires for the CCD and the motors and remove the assembly.
Feb 18, 2008 | Casio Exilim EX-S500 Digital Camera
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
