Question about D-Link DCS-6620G Network Camera
I am looking for someone to repair 4 DCS-6620 cameras. It isn't a sofware problem it is hardware that needs to be fixed. Example camera came off base.
Any luck?
I have 7 of these that need service for one reason or another. They began to fail shortly after the warranty ran out, and have recently begun to fail much more quickly.
Next time, before I buy 62 cameras, I'll make sure I'm dealing with a company who services their product...D-Link tells me they simply don't and that these are $900 DISPOSABLE units.
Please let me know, too, if you can fix these (various problems depending on camera include include motors not working, no image produced, etc)...I can send them wherever they need to go.
clipalong at yahoo dot com
Posted on Jan 10, 2011
I have a dcs-6620 camera and streaming video stopped
this might help...http://support.dlink.com/Emulators/dcs6620/
Sep 02, 2014 | Computers & Internet
Change ip address
Is your ip is static or dynamic?If it is dynamic,then you have to reset your modem or else if it is static,then ask your ISP to change your ip.To know your network ip address visit Ip-Details.com .
Apr 07, 2013 | D-Link DCS-6620 Internet Camera
Explain how to go about using a static or dynamic link to access a remote computer that has an ethernet PTZ camera from d-link install so that the camera can be viewed remotly.
you need to do some port forwarding and possibly use a static address assigned to your camera.
remotely is this context means being able to access the camera feed when the camera is behind a router. in essence what you are trying to do is this:
camera ------ (private) router (public) ---------- internet ------- remote user.
the private side or your router is the one that you control, the private side is what is known as being "behind the router"
your router requires to be able to forward traffic from the public side for this you need to do some port forwarding.
a practical example that you can follow can be found in this website if you look into the Support Resources>FAQ section under the title "How do I remotely view DCS-6620 or DCS-6620G series cameras that are behind a router or gateway?"
the article from dlink goes like this:
For each camera that resides behind a router or gateway, three ports must be forwarded by the router to obtain both audio and video. If audio is not desired, only the HTTP port will need to be forwarded. The three default ports are as follows:
  • 80 (TCP) HTTP Port (allows access to web-configuration and transmits video if other ports are not forwarded)
  • 5002 (TCP/UDP) Audio Channel Port (transmits synchronized audio)
  • 5003 (TCP/UDP) Video Channel Port (transmits synchronized video)
These port numbers will need to be changed in the camera configuration on each additional camera that is added behind the router. Port numbers can be changed from the Advanced > Network screen.
please look in to the section described within the link to see how camera and router need to be configured.
I hope this helps!
Apr 07, 2010 | Computers & Internet
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
DCS-S40 White LCD screen whats up?
i posted a pic i edited.
this is a hardware issue that really has no perm fix. but is easily fixable with my pic.
Oct 01, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Web cam
You need to NAT first. Just NAT internal ip :internal port with External IP :external port.
May 11, 2008 | D-Link DCS-6620 Network Camera
D-link dcs 6620 Camera
If you are using Trend Micro Virus protection It will cause the video to be blank.
Sep 14, 2007 | D-Link DCS-6620 Network Camera
DCS-6620 locks up and will not Pan and Tilt
From wat ya say it seems to me that you are loosing ya signal sometimes? perhaps a "Better" antenna on the Base unit may help, one with a "High Gain" Also perhaps ya need to check and clean any connections etc. Hope that helps.
Jul 01, 2007 | D-Link DCS-6620 Network Camera
D-Link DCS-6620G Network Camera Logo
212 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
