Question about Whirlpool Dishwashers
Just bought a whirlpool dishwasher & unshure how to wire it in ????
    Scholar:
  • 170 Answers
There is a connection box at the bottom of the dishwasher that you can run an electric connection to. You will have to get some electrical nuts to connect the wires. The other end of the wire you will have to attach to an existing source (electrical outlet, or directly to a fusebox. You will need to consult some Home wiring books, like from Home Depot or Reader's Digest to make sure you do it exactly right and are in code. Good Luck!
Posted on Jul 08, 2008
I just bought a replacement inlet supply valve for Whirlpool dishwasher (model GU2400XTPB6, ser. FS4716995 and can not remember which wires went to which post. I took them off a while back & did not...
Hi, Welcome to FixYa. There is no difference which wire goes where on a 2 wire component...most times, at least when dealing in alternating current as this is. Thanks for choosing FixYa today and good luck. Please take moment to accept and rate my solution and your experience here today. Regards, Macmarkus :)
Sep 14, 2011 | Whirlpool Dishwashers
I have no power to the dishwasher. I tried the circuit breaker, flipped it. No lights on, nothing. It must have been running when the power might have gone off, may be the power surged or something and it...
first check and make sure that the units not on a switched receptacle(and is wired into this circuit(i know the dishwasher is "hard-wired",as in the unit doesn't have a plug on it,but it could have been wired into this switched circuit by mistake) under the sink,there are homes wired this way for garbage disposals and these switches can get shut off by accidental bumping by items stored under the sink especially the rocker style switches,normally these units don't just completely die,unless the fuse on the control panel in the unit opens
Nov 18, 2010 | Whirlpool Dishwashers
How do i change the door spring on my whirlpool dishwasher? i don't know model # as the label on door is gone but it's about 3 yrs old. no manual as bought at dent & ding store.
normally the door springs depending on what side has to be changed by pulling out the unit ,the spring runs underneath along the lower side to the back ,its a bit technical to do but if you go to searspartsdirect you can see the image of the whirlpool unit .you can even get parts that willbe shipped to you.hope this helps,to get you started.
Mar 03, 2010 | Dishwashers
Coffee mugs have stains
Does you dishwasher have a rinse aid fill? Most newer dishwashers will have this feature and really helps with water spots. Hope this helps.
Jul 24, 2009 | Whirlpool 24 in. DU915PWP Built-in...
I have a Whirlpool Dishwasher and it is locked and I don't know how to unlock it
I have a Whirlpool dishwasher & locked mine by pushing the "Air Dry" button for about 5 seconds. To unlock it, I pushed it in again another 5 seconds and the unlock light went out & it worked fine. Whatever button you locked it with originally (if you know), should unlock it when held in again.
Jul 16, 2009 | Whirlpool Dishwashers
We just purchased a whirlpool dishwasher & while taking it out of the box I noticed a gray piece in the lower back with a red electrical part in the middle with a wire connected hanging down. I looked...
You just got it. call for service or take it back for a replacement. If that piece was damaged, what else was jarred and soon to fail. I would return it for a replacement.
Eric
Jun 28, 2009 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Dishwasher does not spray water
The pump has had it, & it is not presurising the water enough, also before u replace the pump, remove the inlet pipe, & check that the little gauze filter in the inlet valve is clean, when they block they dont let the water in fast enough to be pumped high enough.
Jul 30, 2017 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
