Question about Whirlpool WFC7500VW Washer
FIRST...Were can I find a FULL PARTS diagram for this model? Whirlpool Front-Loading Automatic Washer ~WFC7500VW~ Washer turns on... Fills with water... When it should start to rotate the drum (START WASHING) a Failure Code (F06) pops up. I have done everything I can do so far but to be sure I am checking the right part(s) I need to know what part is what? ( I NEED A DIAGRAM) And PART NUMBERS would be great too! I am working with the SERVICE TECHNICIAN DIAGNOSTIC GUIDE (STDG) and have run all tests that list the following (tests it dose) when the falt comes up... (F06) Problem.. it lists all these problem with the (F06) Falt... Reversing Relay Safety Relay Motor Thermistor Tachometer Signal As you read on in the (STGD) it says the F06 ERROR.... "If the control is unable to properly detect motor speed, the mechine shuts down" Now if I am right...? all of the following (are parts of) or (the whole unit) in the MOTOR CONTROL UNIT (MCU) Reversing Relay Safety Relay Motor Thermistor Tachometer Signal So now you see why I need a (PARTS DIAGRAM) The only other switch that ties into the MCU is the Door Switch and nothing would happen ~AT ALL~ if this switch was not closed...
    President:
  • 3,113 Answers
I need the part number for the plastic button assembly on a whirlpool wfc7500vw washer
Here's the parts diagram. You should be able to find it and order it here. https://www.searspartsdirect.com/model-number/wfc7500vw1/1198/0153200.html?sid=ps:GOOGLE:Dynamic%20Search%20Campaign%20-%20Categories:whirlpool:&k_clickID=bc276823-c73d-402e-8108-8dca92f89665&gclid=CjwKCAiAnabTBRA6EiwAemvBd9ZcgjLmZK2G078ABQNcyGMj1_hA2h07z9UCh0fNoaGyjVBYHsWyyRoCLgEQAvD_BwE&kenibpid=p.590.bc276823-c73d-402e-8108-8dca92f89665.cr368030
Jan 23, 2018 | Whirlpool Washing Machines
Front knob for whirlpool washer wfc7500vw broken?
Hi,most washing machines open from the top,a couple of screws at the back and slide the top back and lift,then you should be able to see the part number,I hope this is the same for your machine.
all the best.
Sep 10, 2012 | Whirlpool WFC7500VW Washer
Whirlpool front-loading automatic washer problem
yea replace the ccu and the mcu more than likeley the mcu will do it tho
Jul 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
About 1-2 times a month, my front loading washer fills up with water (sometimes a little and sometimes about half full) without being turned on ... any ideas?
Leaking water inlet valve. Turn hot water valve off one night n see wether any water in drum in morning. Then try turning cold valve off at hose as well to see which one is letting the water in. Either way its only a $5 dollar bit thats passing water
Nov 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loasding automatic washer
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@!@
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Apr 09, 2009 | Whirlpool WFC7500VW Washer
Whirlpool WFC7500VW Washer Logo
553 people viewed this question
Dan Webster
Dan Webster
Sal De
