Question about Mitsubishi WD-65735 Television
Hello there, I have the mitsubishi wd-65735 dlp Problem with Mitsubishi WD-65735 Television Hello there, I have the mitsubishi wd-65735 dlp tv.Last night where I live we had numerous power outages last night and thats when the problems started.Anyways when i turn it on the red light comes on after the timer light blinks for 15-20 sec.I get sound but no picture so I moved tv from wall and where the lamp module is there is black on the wall so my lamps are most likely bad.After I took back panel off the lamp light on front of tv blinks yellow now and when i turn it on the fan does nt run in the back.Is this normal since the lamps are you? David
  • 17 more comments
  • David Heyd Dec 30, 2010
    Wow kinda what I thought,and power goes out here alot.I need to find a backup power source then for future outages.
    Okay I did like you said.Did not hear the normal arcing sound.Took lamp out and really does nt look bad.Bulb looks normal except at the base of bulb the stem at the base its sorta bulged out and bubbled.Other wise looks fine.The wire from side is intact and glass is clear not white or blackened.
  • David Heyd Dec 31, 2010
    Well the bulb actually looks good.The lens is not white or blackened.Just the base stem is a litlle bubbled,or maybe deformed.and the wire from side going to the til is intact
    How do I send you a image?no chassis number but serial number is 107136.
    David
    How do I send a photo to you? And no chassis number just serial number.
    David
    http://my.imageshack.us/v_images.php
    Did I send the right one this time,sorry about that.
    http://img146.imageshack.us/i/1061399.jp...http://img825.imageshack.us/i/1061398.jp...http://img153.imageshack.us/i/1061397.jp...http://img811.imageshack.us/i/1061396.jp...http://img408.imageshack.us/i/1061395.jp...
    sorry did nt know what I needed to paste here.
    David
    Ya well when i turn it on before i took the lamp out I did not hear the usual crackling sound of the ballast so maybe its that but ill put lamp back in and see what the error codes says.
    Very Helpful
  • David Heyd Jan 01, 2011
    I have nt yet,its 2 am here,Ill do it in the morning.Thanks for all your help
    Ok sorry for the delay,was new years here so had to party a bit.I get a error code of 12 and its the green timer light that flashes that.
    David
    Do you mean the menu and input buttons?There is no device button on tv
    Also do you know where I can find a manual online for this tv? I have one somewhere but I just moved a few months ago and cant find it right now.Somewhere in all them boxes in the garage.I have to figure this out soon cause I ordered a lamp the other day for it and it will ship monday so if its not the lamp I can cancel the order.
    Okay this thing is just confusing me now.You know when i plug it in to power it turns on by itself and the green timer light blinks for 20 sec maybe then stops.I have done the error code thing 4 times now like you told me to do.twice when i plug it in when the timer light is still blinking and twice when i wait till it stops and i get the same 12 everytime.Also I have waited till the timer light stops blinking and hit the power button.The tv comes on and I have sound but after 20-30 seconds it turns itself off.Its got to be the bulb.What do you think?
    so the lamp then?
    Alrighty.Ill do that when it gets here,might not be till thursday or friday.Ill let you know what happens and thanks for all the help.
    David
  • David Heyd Jan 11, 2011
    Ok changed lamp and everything is good.Wwo lamp must have been going bad for a while.TV never looked better,very bright and vivid now.Thanks for all your help and patience.Ill leave ya a good comment.
    David
  • 4,889 Answers
If the lamp light blinks yellow, then the first thing I would check would be the filament of the lamp. It is not completely blown into shrads, but it sounds like the filaments is fried. Please check it and let me know.
Sai.
Posted on Dec 31, 2010
  • 12 more comments
  • eagle338
    eagle338 Dec 31, 2010
    What about the filament? Its inside the bulb? Can you get me an image please? Also please get me the chassis number of the tv. Its on the label at the back below the model number.
    Sai.
  • eagle338
    Don't worry about the chassis . I got it. Its V39. You can upload the image to imageshack.us and get me the link to the image
  • eagle338
    Please get me the direct links to the images.
  • eagle338
    No click on the image and then copy the link. It should end with JPG like this
    http://img233.imageshack.us/img233/1129/...
  • eagle338
    Ok. The lamp looks good to me but lets see. Unplug the tv from the power supply and re-plug it
    Pressing the front panel "DEVICE" and "MENU" buttons on the front panel of the tv at the same time, and holding for 5 seconds,
    activates the Error Code Mode. The LED blinks an x number of times, followed by a short pause(1/2 second) and another y number of times. You should count these to determine the error code. For example: If it blinks three times followed by a short pause and 4 times then the error code is 34
    Get me this info so that I can confirm the source of the problem.
    Sai.
  • eagle338
    Also its 2:16 Am here in India and I am feeling sleepy. I will respond to you first thing in the morning.
  • eagle338
    eagle338 Jan 01, 2011
    Yes sure. Did you check? WHat did the error code say?
  • eagle338
    Ok. No proble. Update me once you do it in the morning. :) I wish you a happy and prosperous new year :)
  • eagle338
    12 means no error. Its the defualt error code. You should unplug and re-plug the tv and then try it. Please give it another shot and let me know. Just a confirmation so that we can rule out the DMD module.
  • eagle338
    Yes I forgot. Some models have a device button instead of input. so its a mistake. It is the input button.
  • eagle338
    Yes more so coz you have already mentioned that the ballast does not "strike" the lamp on.
  • eagle338
    Yep. All signs point to a faulty lamp. Replace it and the issue will be resolved.
  • eagle338
    Ok. Good luck with the repair. And here's the user manual you have asked for . Sorry I missed that comment
    http://www.mitsubishi-tv.com/pdf/ownersg...
  • eagle338
    eagle338 Jan 11, 2011
    Great! If you can just accept my solution, so that I can get the credit for it. Thank you for using Fixya!
    President:
  • Mitsubishi Master
  • 1,779 Answers
Hi David, If you were watching it prior to the outages each time then your lamp is definitely bad. As you may know, the lamp fan will run after you shut the set off during normal conditions. This cools down the lamp so it is not damaged. If the outages happened when you were watching it, this is very very detrimental to the life expectancy of the lamp and most of the time fatal the first time. The fans will not come on if you have the lamp door off the set. The set has a safety switch activated by the door being attached or off, so you must always have the door screwed back onto the set for the set to operate correctly providing nothing else is wrong. Is it possible with the black on the wall, might be from just the dust on the filter that blows the hot air out and that just accumulated on the wall. at this point I would unplug the set for 10 minutes and put the lamp door on then plug the set in and tun it on, listen for the ballast trying to start the lamp. This sound will be like an arcing sound, this is normal. Bottom line is,I would replace the Lamp.
Posted on Dec 30, 2010
  • Jim Krause Dec 30, 2010
    APC makes a nice one. Excellent for a PC also.
Need a replacement screen for a Mitsubishi Wd 65735..........
Contact Mitsubishi Directly for a part number (set has two screens at least) to see if it is available and at what cost.
Apr 03, 2012 | Mitsubishi WD-65735 Television
How do I repair white dots/dead pixels on my 3 year old Mitsubishi WD-65735 DLP TV?
You have a bad light engine. It is available at encompassparts.com for retail price of $749.10. Call 1-800-638-3328. Consumer not in business could be higher price.
Oct 23, 2011 | Mitsubishi WD-65735 Television
I just replaced my bulb on my mitsubishi wd-65736 but picture is still dark looking and the bulb stays lit up after we cut the TV off. Could I have hooked the two wires up wrong?
This site lists your service manual for $7.99
https://www.completeservicemanuals.com/mitsubishi/dlp-projection-television/wd-65736-service-manual/prod_1408.html
This site claims to have a free PDF download, but the "free download" link throws you to www.tradebit.com, which sells the service manual (as a downloadable PDF file) for $7.99
http://www.promanuals.com/serviceparts/mitsubishi-wd-60735-wd-65735-wd-73735-wd-65835-wd-73835-wd-60c8-wd-65c8-wd-73c8-wd-65736-wd-73736-service-manual/
This site sells your TV service manual for $5 as a .PDF sent to your email:
http://tv-part.com/index.php?target=products&product_id=1369
If you can read/use a service manual, $5+tax is a lot better than $hundreds for a new television. Or- buy the downloadable manual, and give it to your favorite electronics friend to peruse. The darkness coming from the new lamp might bespeak of a power supply problem, or a poor connection between the lamp and the power supply. The fact that the lamp module stays on after it should go out also says power supply problem.
In the worst case, keep both your lamp modules (they're probably both good), and sell them online to help defray the cost of a new television.
Sep 30, 2011 | Mitsubishi WD-65736 Television
When the tv goes out can you purchase just a bulb or do you need to buy the lamp
you can't buy just the bulb
http://www.discount-merchant.com/Mitsubishi-915B403001-Lamp-DLP-TV-lamp-p/mitsubishi-915b403001-lamp.htm?1=1&CartID=0
Jan 25, 2011 | Mitsubishi WD-65735 Television
Mitsubishi wd 65735 - blinking green LED on front panel, TV won't turn on
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck..
May 25, 2010 | Mitsubishi WD-65735 Television
Mitsubishi WD-65735 Television Logo
382 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
