Question about Danby 7,000 BTU Portable Air Conditioner - Euro Gray
Water Resorvoir was empty out of Friday and Monday we had to empty the resorvoir again waht could be causing this problem.
I call the company and they explain the problem step by step. So please take my name off of your email list. Thanks
Mrs. Cutino
Posted on Jul 15, 2008
Bubbling in resorvoir, and spills out, new thermostat and hose new, fan is running, what can it be?
Hi Bubbles in the resorvoir Usually is a head gasket fault ( the gasket is allowing compression pressure to enter the coolant system )
Unfortunately its a big job and exspensive
The only other thing is if the water is boiling ( like when a kettle boils ) But because you have
changed the thermostat and the fan is running i don`t think this is the problem
Good luck with this problem, Hope i have helped you
John ( South Wales UK )
Jul 05, 2011 | 2000 Ford Contour
I didn't see the washer pump under the shroud on my 1997 jeep cherokee? I saw the motor (wipers work fine) and the washer reserve signal switch. Where is the washer pump located?
Your washer pump and resorvoir are located inside the drivers fender. You may need to take off the wheel to have better acces but, you will need to remove the plastic fender trim and you will see the resorvoir located inside. The pumps are attached to the resorvoir.
Jan 15, 2011 | 1997 Jeep Cherokee
I lost my steering power
did you chek the serpentin belt? or the power steering fluid level, look for a leaks and finally power steering pump damage,
Nov 24, 2009 | 2003 Chevrolet Impala
The coolant container is leaking again i had the water pump, radiator , thermostat changed and its still leaking ? can the container be fill to much and this is causing to much pressure, causing the...
no. ithe coolant resorvoir cancrack when hot fluid goes into it. i recommend changing the tank.try autozone to see if they can get it for you
Nov 22, 2009 | 1999 Ford Taurus
NEW RADIATOR,1 YEAR WATER PUMP, NEW THERMOSTAT, STILL OVERHEATS,SENSOR OK, ERRATIC READINGS ON HEAT GAUGE WHEN DRIVING A SHORT TIME GAUGE GOES UP TO HOT AND ENGINE IS HOT. PARK FOR SHORT TIME AND THEN TURN...
Check first if the fan is running, you can do this by pulling out the temp sensor at the lower radiator hose. You should see the fan go on. If the mechanics has checked out everything, I suggest to see if there are added load on the engine such as busted bearing on the pulleys for the serpentine belt. Observe the coolant if it is boiling hard when you notice the temp go up. It might be a problem withe the sensor which triggers the ECU to shut the engine.
Aug 08, 2009 | 1996 Dodge Dakota
Ford van a/c stops blowing when going up hill
ther is a vacuum in the engine compartment going to a resorvoir(could look like a ball or can) vacuum or resorvoir could have a hole in it
Jun 28, 2009 | 2000 Mitsubishi Galant
My 98 contour has been parked for a year and now brakes not worki
You have a leak which has put alot of air in the system, was the bleeding done by a shop? Check all 4 wheels for signs of fluid leakage, most likely the back wheels. If no leakage at the wheels suspect the master cylinder leaking from the back side, if so you will see evidence of fluid leaking from under the master cylinder.
Jun 18, 2009 | 1998 Ford Contour
I dont know what goes in this resovior under my hood..
Look and follow hoses from it and see if they travel to the radiator and the motor block..If so its radiator coolant..
Apr 05, 2009 | 1999 Kia Sephia
Coffee pot keeps stopping if I turn it off and on it starts again for a few minutes and same again?
That has been my problem also. I noticed that the tube in the resorvoir was clogged, so I ran straight vinegar through it about 5 times. Put a filter in your basket to catch all the gunk that comes out. I then ran clean water through 2 or 3 times.
Mar 09, 2009 | GE 106591 Coffee Maker
Water dispenser keeps freezing!
it sounds as though there is an cold airflow problem in the fridge and as science states the cold air will drop down to the bottom of the fridge. check that any circulation fans are not jammed with ice or faulty. if not sure where to go do a defrost for 36 hours and check on all the functions after that. tone.
Jun 04, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Danby 7,000 BTU Portable Air Conditioner - Euro Gray Logo
182 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
