Question about Sony Audio Players & Recorders
My sony receiver wont power up blows the fuse
  • Sony Master
  • 6,771 Answers
If the main fuse is blowing it is a power supply problem, or it is more than likely the audio output ic's are the issue. This is where a professional would be invaluable at this stage of the game because this a situation where cost could be a factor.
Posted on Dec 30, 2010
SONY RECEIVER MODEL STR - D315 keeps blowing a fuse
When the main fuse blows on a sony, it is usually caused by shorted output transistors. You would have to replace these transistors before the unit will not blow the fuse and power up correctly.
May 23, 2013 | Audio Players & Recorders
Sony receiver clicks but wont turn
Either your main power fuse is blown, or your power transformer is bad. If it's the fuse, then most likely you have shorted output transistors that are causing the fuse to blow.
May 21, 2013 | Audio Players & Recorders
Sony receiver keeps blowing 5 amp fuses
You have shorted output transistors in the amp that need to be replaced.
Feb 14, 2013 | Sony STR-DE425 Receiver
Working on for friend. Unit does not power up, no fuses blown
The most obvious place to check is anything to do with the power supply, such as the transformer. A fuse will only blow if an overload occurs, caused by something acting like it was just a piece of wire. However if something acts like a broken wire, everything justs stops dead and the fuse doesn't blow!
Jun 14, 2010 | Sony STR-DE698 Receiver
I have a Sony STR DB930. Something happend and it
The fuse blowing is a symptom of something seriously shorted internally. What preceded the initial problem? Smoke is bad. Fire would be soon to follow without the fuse blowing. Take it to a tech.
Feb 08, 2010 | Sony STR-DB930 Receiver
My sony receiver tuner wont turn on. It was working fine yesterday now it wont power up. The fuse near the plug wire inside is good. Any suggestions
Fuses almost never go bad something causes them to blow. Even when a blown fuse is found in electronics just t replacing it can cause more damage if something caused it to blow, a repair person looks for bad parts before replacing a fuse. Only microwaves are known to blow fuses and replacing the fuse fixes it. About the only thing that people can do is unplug a short time and try it again. And need i say is the power outlet ok.
Nov 03, 2009 | Audio Players & Recorders
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
Sony STR-D565 fuse continues to blow
You could have a shorted winding in the power transformer. The diodes in the power supply can be shorted. Filter capacitors can short and send power to ground which will blow the fuse.
Apr 16, 2017 | Sony STR-D565 Receiver
I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Apr 04, 2009 | Sony STR-D565 Receiver
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
906 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
