Our LG Heat Pump S24AWN-N56 does not appear to have a facility that allows me to have pump coming on every morning at a given time & off at a given time.
2 Suggested Answers
SOURCE: Air conditioner is turning on
Hello Naeva
Plesae visit the link provided below :
http://www.mylg.co.uk/data%20for%20site/Multi%20F_dx_%20Fault%20Codes%20-%20Nov%2007.pdf
http://www.abacusairconditioning.co.uk/lg%20split%20codes.pdf
http://www.ehow.com/info_7983149_lg-air-conditioner-error-codes.html
Posted on May 01, 2011
Why doesn't the compressor start in the heat mode
Is it a heat pump? Is it a heat pump stat? Is ambient temp high enough to allow heat pump to run?
Sep 11, 2014 | LG LP153HD3A - 14,300 BTU, R410A, 9.4 EER,...
Will a th5000 work with a ruud dual fuel
Are you talking about a pro 5000 Thermostat??? if so then NO it will not work.With this stat you do not have a temperature lock on the heat pump. Say you don't want the heat pump to run below 25 degrees. it won't shut the heat pump. And you don't want the heat pump to run at the same time as the furnace. With the Pro 8000 3 heat and 2 cool thermostat you can lock out the heat pump at 25 degrees outside an turn the furnace on. You will have to install an outdoor thermostat hooked up to the pro 8000 it usually comes with the stat. Honeywell products.
Nov 29, 2013 | Rheem 3.5 Ton 14 Seer / Ruud 100K Btu 80%...
Aux keeps coming on on regular heat is there something wrong with heat
See if it happens only when your temperature of the room is more than 3 degrees of your setpoint temperature. Since you have a heat pump, the auxiliary (electric heat strips) is use for backup of the heat pump when it can't keep up. The heat pump will run by itself if it can maintain temperature within a couple degrees. If it is too cold outside to handle the load or you set the temperature more than 2 degrees past room temperature, the auxiliary will turn on. The thermostat has a memory of how long it takes to reach desired temperature. If it goes into auxiliary mode trying to satisfy setpoint during the last call for heat, it will start the next call for heat in both aux & heat pump mode until the thermostats algorithm (timed program) allows only the heat pump to run. Not sure if you have an air to air, or geothermal heat pump. The outside air temperature will affect only the air to air system ie. when the temps drop outside, the heat coming out of your vents will be cooler...the air to air systems drops efficiency when the outdoor air drops.
Nov 08, 2013 | Honeywell TH3210D1004 PRO 3000...
Heat does not start first time ONLY early in thE MORNING
when you start heat it should be temp. diff, between outdoor & indoor at least 5 C to start , check control
Nov 08, 2013 | Amana PTH123B25AJ Heat Pump Air...
This is the 2nd B60 that appears to have a pump
I unplugged mine and it fixed the problem.
Jun 03, 2010 | Keurig B60 Coffee Maker
Will Pentair Intelliflo pump save me enough money to justify cost
Here are a couple of thoughts. If you install an intelliflo pump and run it for the same amount of time and at the same rpm as your current pump, you will still have a savings. If you drop the rpms by 1k, you will have an exponential savings. Go to the pentair website and use the program to estimate your actual savings. You can still run the heater at a reduced flow setting but there is a limit, you have to check with the heater manufacturer to see what the minimum is.
If you are running a conventional pump 24/7 you are using a ton of energy. You should be able to run the pump for 8 hours a day and achieve the same results. For instance, running the pump from 4am to noon should give you a good window to maintain the heat and not run it all the time. It also depends on if you have a cover on your pool when it's not in use. If you don't, you will lose significant heat when it's not running, however, running it early morning should give it a chance to heat back up before you want to use it again. You will have to experiment with timer settings, etc..
I really do think the intelliflo pump is a great pump. The rare earth magnet design allows it to be way more efficient than the conventional pump. It is so much more efficient that when it's running, you can hold your hand on the motor and it is just warm. Your pump motor probably runs very hot, heat is a by product of inefficiency. I hope this helps.
Jan 19, 2010 | Pentair Intelliflo Pump 4x160
Installed new LG 18000 btu mini split heat pump, started it in heating mode, the unit first appears to run fine but continues to cycle in and off without reaching temp. have already changed indoor board...
a heat pump is a finely tuned machine that can be very efficient yet very frustrating at times. I could give you better advice if I were looking at the unit but hear are some things that may help. The unit has a defrost mode that cycles every 30,60,or 90 minutes. If you take the cover off of the condensing unit and near the top you will see the adjustor. unless you live in arctic or very humid cilimates, it should not be set to 30 min. Also the unit may be low on refrigerant. you can check this with a thermometer. put the therm. on the hot gas line(big one) and it should be 110 degrees hotter than the outside temp. Insulate the point of contact around the therm. and gas line. Also, your aux. heat may not be coming on to supplement the heat from the pump. i.e. the fusable link could have burned up and the heating element wouldnt be coming on(elec. models). there are too many variables and combinations of problems that could cause this.
Dec 24, 2009 | Heating & Cooling
Digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Jul 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Ran out of gas last week and know the check engine lite comes on 1 & while but the prop. is when going 45 and trying to speed up it sputters until i kick in the passing gear
Possible fuel filter, but it could possibly be that when you ran the tank down to nothing you ruined the electric fuel pump in the gas tank. Given the age of the vehicle it's very possible. The fuel that the pump sits in basically cools the motor. If you run it really low all the time allowing the motor to heat up, it will eventually fail. If pump replacement is necessary, replace the fuel filter and the fuel sock all at the same time.
Jul 12, 2009 | 1994 Pontiac Grand Am
No heat new thermostat
you have a short in the wireing.disconnect at air handler and hook-up short t-stat wire to t-stat,ifok chk wire to condenser
Jan 10, 2009 | Heating & Cooling
Heating & Cooling Logo
195 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
