Question about Toshiba Televison & Video
Older toshiba tv/ cx35d81/ color and sound problems
Color changes from good to reds blues or greens. when i tap lightly on the upper left corner of circuit board at end of crt, color pops back to normal good color. if i leave cabinet back off, color seems to stay good and when i put cabinet back on, colors drift again. sound problem: sound is audible at a low level and is not affected by volume control, no amplification. I'd appreciate any repair advice you can give me. although i'm no pro, i've played in electronics since being trained in usaf in the 50's. thanks, jim
    Problem Solver:
  • 12 Answers
Sound like a dry joint
Posted on Jul 08, 2008
  • wilddacotah Nov 29, 2010
    had same problem. They missed a solder joint. Had to solder the little white square ceramic component ( capacitor) on the curcuit board that's on the picture tube yoke. its at the bottom middle of the board if I remember. Remove the wire harnesses and then pull the board off the yoke. Its pressed onto the yoke. Check it over and you should see were they totally missed soldering. Our color kept going crazy and the picture was horrible. Wants I fixed it its like a new tv again. Must be a common problem with these but easy to fix. hope this helps.
    My sound even turned all the way up is still low. I haven't figured out the problem yet.
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
PT-47wx42 color problems
This could be a heater-cathode (H-K) short in the CRT, a failure of a component in the chroma circuits or video output (driver board), or bad connections there or elsewhere. Don't panic - heater-cathode shorts in CRTs can often be worked around.
Note: before proceeding, it is a good idea to make sure that the screen is degaussed - else you could be attempting to track down problems with the wrong color!
Some simple tests can confirm or rule out other possibilities.
  • Compare the voltages for the video drive signals to the CRT on the little board on the neck of the CRT with the CRT both connected and unplugged. A schematic will help greatly in locating these signals.
    • If there is a significant difference especially on the bad color, then the CRT is a likely candidate. Try tapping the neck of the CRT GENTLY (with it plugged in and while viewing a picture) to see if it is an intermittent problem.
    • If there is no significant difference, you may have a bad driver or a problem in the chroma circuits.
  • Look for bad connection/cold solder joints, probably on the little board on the neck of the CRT. Use an insulated stick to gently prod the board and its components in an effort to induce/cure the problem. Look carefully for hairline cracks around the component leads.
  • You can swap components between two colors and/or test with an ohmmeter on that driver board to determine what is bad. The nice thing about color monitors and TVs is that there three copies of each of these components. Swapping and/or comparisons between these is an excellent diagnostic technique.
  • Another simple test: Disconnect the cathode for the full-on color from its drive. If it is still full-on, there is probably an H-K short in the CRT since the only way to get each color on the screen is via the cathode connection to the CRT neck board. If it is removed and there is still that color, the current must be taking another path inside the CRT.
  • Alternatively, interchange the outputs of the bad color with a good one by jumpering on the video driver board (on the CRT neck). If the bad color changes, then the problem is in the circuitry and not the CRT.
So you have to get a tech if the above method doesn't solve your problem and get it fixed..
Goodluck,
Please don't forget tor ate me as fixya..
Feb 09, 2008 | Panasonic PT-47WX42 47" Rear Projection...
HCL4715W Green Color intermittently projecting
It sounds like the common problem with this set. It is an intermittant picture tube, or there is a loose connection on the green drive board on the green picture tube. Try lightly tapping all around on the green drive board while the set is on and see if you have any change. BUT BE VERY CAREFUL! Lots of high voltage on the board. Also use a plastic or wooden device to do the tapping. If you do great, you know you need to resolder the connections on the board or clean the CRT socket on the green drive board. If there is no change, I would bet the green CRT is on its way out. But try tapping the green drive board all over as I said before, that is a very very common fault with these types of TV sets. Good Luck
Aug 16, 2007 | Samsung HCL4715W 47" Rear Projection...
Our tv keeps changing colours to blue red and green
Your television have color problem.That symptom is cause of loose connection or cold solder in chroma section and color output driver transistor of CRT board of your television.You can fix that problem by resoldering the chroma section and crt socket section of your TV.first thing to do is open or remove the back cover of your TV,then you can see the crt board connected to picture tube.Resolder that parts,specially the color output transistor the red,green and blue driver.Resolder also the chroma section.You can see the jungle ic,thats the color ic.Make sure that there's no short circuit when soldering the PCB board.After the resoldering turn on the TV and check if color is normal.Thanks..
Aug 26, 2011 | Televison & Video
Shows different color complete blue or red scrren at connection
shake vga cable at different places & observe.........if colours becomes normal or it comes & again it goes...then vga cable is deffective.......either you have to change full vga cable or you have to repair that cable itself................after shaking cable also if no improvement then......hit your monitor lightly on left side or righr side or on top & observe ...........if colours becomes normal or it comes & again it goes...then following is the situation...............after 4 or 5 yrs in some monitors on main board at some soldering joints crack develops....then due to loose contact colour problem comes (1 of the sympton) ...........when we hit that lightly then those loose contacts joins temporarly & again colour comes nomally for some time............so solution is ......monitor main board & crt circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no improvement then..following is the situation.....................on CRT circuit board ( circuit board that is fixed to tube) ''red green blue'' - video output IC ( some thing like LM2469TA ) will be there - it should be replaced - usually it will be fixed to heat sink ------- before changing IC all the components on CRT circuit board should be checked ( after switching off monitor ).........this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )
Apr 11, 2011 | SAMTRON 55V 15" CRT Monitor
Yellow circle in center of screen & blue shading to side
Hello, This will require you opening the back cover of the television. This could be a heater-cathode (H-K) short in the CRT, a failure of a component in the chroma circuits or video output (driver board), or bad connections there or elsewhere. Note: before proceeding, it is a good idea to make sure that the screen is degaussed - else you could be attempting to track down problems with the wrong color!
To identify if the fault is in the CRT or a control problem try this (WITH SET OFF):
On the CRT board, lift the output end of the green cathode final resistor. Do the same with the offending red cathode's resistor. Use short insulated jumpers to 'swap' drive signals - drive the red cathode with the green drive and the green cathode with red drive. (Note that if this problem only occurs after a warmup period, color at turn on will be - well - wierd, but it is just a test.)
If instead the symptom becomes 'goes green' then the red drive leg has the fault and the CRT is probably good. (In this case, there may be bad connections or a bad component on the CRT drive board. Also it involve a technical skilled personnel to handle this..
May 20, 2010 | Sony Grand WEGA KFWE42S1 TV
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
Color issue
Replace 120k resistor on the blue video output module. Resistor is located next to the blue video output transistor (has heat sink). If you replace it with a 1/2 watt carbon type, it will probably never happen again. I recomend the same resistor on the red and green video boards at the same time.
Jun 17, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Jun 04, 2008 | Zenith A36B41W 36" TV
AKAI PT4298HD
If you have a good picture except for a missing color all the various circuits are working OK. Most likely you have a bad solder joint or component in the red circuit. This would also be indicated by the fact that ocassionaly the red pops in. If you have the experience remove the boards and inspect for cracked or cold solder joints. Resolder anything that looks suspicious. If this does not fix it you will have to troubleshoot the red drive circuits from the CRT back to the video IC. Another possibility is that you have a bad/intermitant red crt. I doubt that you have the equipment to check this but you can test it by moving the green crt board to the red crt. If it now works the red crt is OK. If all this fails you will need to find a reputable repair shop to look at it. If the unit is more than 5 years old it may not be worth fixing. Good luck.
Jun 02, 2007 | Akai PT4298HD Rear Projection Television
Televison & Video Logo
200 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
