Hi.my phillips micro theatre MCD288/98 ,when I insert any cd or dvd it displays the word "close" on the lcd panel and ejects the disc.have you got any idea what the problem might be?do you think it needs a lazer replacement and is it worth repairing?may thanks Waa-iz
SOURCE: DVD detection problem. No disc is the error
Hi SparkGap,
I used Lens clearner cd of Phillips (worth 150/- Rs) and solution worked. It started playing all DVDs/ re-writable discs, which earlier was giving error " no disc".
Many Many thanks to you and all those  who tried to think about my solution even.
Regards,
Prakash
Posted on Oct 15, 2007
  • 10 Answers
SOURCE: xbox 360
you need to send it off to get repaired
Posted on Aug 26, 2008
SOURCE: Phillips DVD Player / Recorder
The DVDR 3355 at my home had the same problem and thanks God I found the solution. It's on this same forum at this address http://www.fixya.com/support/t353456-dvd_player
Posted on Oct 08, 2008
SOURCE: dvd-r/cd-rom automatically ejects
My Dvd-r/cd-rom automatically ejects. Please help!
Justis
Posted on Nov 30, 2008
SOURCE: ER appears on panel, can't eject discs, #4 disc doesn't appear on the panel, all others flash. 4-7 have discs, cannot eject. I turned player off and on per manuel troobleshooting, no change.
I shook the cd player until the disc which must have been stuck slide back into its tray.
Posted on Apr 20, 2009
Dvd player immediately ejects all disks
the fault is with its disc loading mechanism. Replace the loading belt first. It it do not help you, replace the loading mechanism as a unit.
Jul 15, 2012 | Insignia NS-LDVD26Q-10A 26 in. HD-Ready...
Dvd player
hey, have you tried to unplug the dvd player for a while, also hold down the eject button on the player, if there is a small hole in the tray use a needle or other small object to eject the tray,
Sep 03, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
My sony Home Theatre DAV-DZ290K, is not functioning properly. The DVD drive opens back again immediately after closing it with a CD or DVD. The display would show us "CLOSE" and then instantly...
okay just plug it out from the current outlet let it stand for one hour then plug back in if that does not remedy problem then your motor is bad or the ic that controls the open and close circuit.have a tech look if my remedy does not work..sometimes plug in and out do the fix cause all the set wants is to reset itself.
Sep 13, 2011 | Audio Players & Recorders
I've recently bought a Sony DVD/ CD player DVP-SR650P. Its accessoies includes a remote RMT-D187P. The remote does not have an open/close/eject button. How to eject the disc tray with the above DVD player...
There is no eject etc button on the remote control because what use would it be? To insert or change a disc, the operator would have to be in reach of the drawer with a disc to hand.
Mar 06, 2011 | Televison & Video
The cd/dvd writer constantly open and close once a disc is inserted. On insertion of a disc, cd/dvd player will read the data on the disc. Windows Media player will display realtime image of the movie,...
Hi Charles,
The issue is due to the driver corruption. You need not worry, there is a simple solution for this.
Go to device manage --> right click on your CD/DVD drive and then click uninstall and then restart your computer. Do not keep any CDs while you do this. Just try this out.
Oct 25, 2010 | Dell Dimension E520 PC Desktop
Hi- I've just inserted a CD into my MacBook Pro
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 13, 2009 | Apple MacBook Pro Laptop Computer with...
Dvd wont eject when you try to open it. or dvd wont play
i think the cd or dcd disc inside stuck-up you have to insert the tiny hole located at the dvd rom and insert a needle or something that is similiar or smaller of the hole size of that locted in your dvd rom.usually its new the LED blinking when opening or inserting the disc. and now you can now eject your disc manually regarding your question about it won't play a dvd try first to clean your DVD disc with a micro fiber cloth, avoid you'll scratch it, if still the same i think you're dvd room is defective.
Oct 08, 2009 | Bose (321GS) System
Need to multi region Phillips Soundbar
HI Ian,
Have also just purchased a Philips HTS8140 with Philips LCD screen.
Found a result on web as follows:
1.Turn on TV
2.Turn on Sound Bar System.
3.Press eject.
4.Press 9 9 9 0 (0 being Region Free or place the desired region #)
(a message displaying "region 0",or the region you chose, will appear on the screen.)
5.Switch soundbar off to soundby.
6.Turn player back on and it should be either region free or the region you selected.
So far I have not been able to check with anyother disc exept region 4.
Hope this is of help for you!
Xtopher
Jan 10, 2009 | Philips SoundBar DVD Home Theater with...
Samsung sh-s182 not read cd's and dvd's
So you mean each time you insert the disc it ejects automatically?or you have a problem reading with the disc?
May 09, 2008 | Computers & Internet
 Grubhead
Grubhead
