Question about Royal 150MX Cross-Cut Shredder
Royal 150MX When you put paper in it does not
Royal 150MX When you put paper in it does not feed or shred but makes a buzzing noise.. Prior to this it made a big noise and now won't shred. Tried to clean out all jams of paper. Thank you for any help you can give.
    Genius:
  • 1,218 Answers
If the cutting blades do not turn when it is running then you have likely boken a plastic gear inside.
You will have to open it up to see which one...then you can contact Royal at 1-800-524-0799 for parts assistance and pricing.
Posted on Jan 01, 2011
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
ROYAL 150 MX WILL ONLY TAKE 2 SHEETS
Have you ever "oiled" the machine.
ALL cross-cut shredders need to be oiled to help clear out the paper dust and debris generated during the shredding process.
Pour some shredder oil across the cutting shafts while it is running and occassionaly put some oil onto a sheet of paper as you shred it.
May 09, 2011 | Royal 150MX Cross-Cut Shredder
Need to empty, how do you open it?
The bin just pulls out but if you cant open it then it is probably "overful" with shredded paper...in extreme cases I have heard people say thay turning the machine "upside down" let them get the bin out.....be aware of the mess this will make.
Nov 20, 2010 | Royal 150MX Cross-Cut Shredder
There is paper stuck in the shredder. I've tried shredder oil and a tweezer.
Alternate reverse and forward several times. Graphite powder or pencil lead along the engaged gear teeth may help. There is probably a "wad of paper" underneath where you can't see it. Be brave and take the shred head apart - pay careful attention so you'll know how to put it back together.
Sep 02, 2010 | Royal 150MX Cross-Cut Shredder
How to clean
As this is a "consumer" shredder, it should only need occasional lubrication.....Put some lightweight shredder oil onto a piece of paper and shred the paper......the more you shred the more you should lubricate.
Aug 24, 2010 | Royal 150MX Cross-Cut Shredder
I have a Royal VF1000MF shredder. While shredding
Try running the shredder in reverse and oiling the blades. More assistance with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder back to good condition it looks like you might have to get a new paper shredder. Great place to learn about new paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF1000MX Shredder
I have a Royal RL170MX shredder. It has started
Try putting some oil on a sheet of paper and then shredding the paper with oil on it.
If that dosn't fix it....take cover off....(with the unit unplugged.) and check plastic gears in drive train.
May 20, 2010 | Royal RL170MX Shredder
Royal 150MX bumping noise when paper is inserted
Sounds like you may have a gear problem; unplug unit open the top to see whats broken/stripped then call Royal at 1-800-524-0799 for parts and prices.
Apr 20, 2009 | Royal 150MX Cross-Cut Shredder
Replacement plastic gear for a Royal 150MX shredder
For parts call Royal at 1-800-524-0799; they should be able to help.
Don't forget to lubricate the cutting shafts on x-cut shredders.
Apr 02, 2009 | Royal 150MX Cross-Cut Shredder
Royal 150MX shredder won't auto shut off. When powered on, always runs until powered off, even after all paper is shredded. Is this also a reset problem or something fouling a switch?
Prob could be the "eyes" in the middle where you put the paper in. They just might need cleaning with a soft cloth( unplug machine first.) If that dos'nt fix it the eyes could be faulty or the pcb could be faulty....give Royal a call at 1-800-524-0799 for parts and prices.
Mar 07, 2009 | Royal 150MX Cross-Cut Shredder
Royal 150MX Cross-Cut Shredder Logo
169 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
