Question about Samsung Syncmaster 192N 19" LCD Monitor
My monitor stays on for approx. and goes off. Taking the power off for a few minutes, it goes back on for a few minutes then goes off agoin. What is the problem?
    Genius:
  • 1,288 Answers
Seen a spate of these issues of late, I'd think its caused by failing Power capacitors, either bulging or blowing or leaking. You need to get this checked by a technician or TV repairman
Posted on Dec 30, 2010
While i am on my computer my hp w1907 monitor goes black. if i shut the monitor off and wait a few minutes it will come back on but then it only stays on for a couple minutes and goes black again.
This sounds like a power board problem. Could be failing power capacitors, which are allowing the charge to leak ( stripping the screen, not recommended) will show bulging or leaking capacitors). Or it could be an issue with the PCB. The fact it will restart once it has "cooled down" points to this.
I'm assuming you have tried the monitor on a different computer, just to eliminate the graphics card (unlikely but worth a go)
Solution..get it checked by a qualified TV repairman, it may a be a simple fix.
Jul 13, 2011 | HP w1907 LCD Monitor
Viewsonic monitor stays on for only 3-5 minutes and goes off . Then I turn it off an wait and it comes back on!!! what is going on??
I guessing that when you say "goes off" you mean it goes into power-saving mode? Assuming that you're working on the computer at the time (so it's not actually going to power saving mode from inactivity), this might indicate one of two things:
a) the VGA cable to the computer is not in a good contact with the monitor. This might happen if you haven't used the screws to fix it in place, just try to plug it fully in on both ends (computer and monitor). If the monitor sees to VGA signal, it goes into power saving mode automatically.
b) there's a problem with the monitor that builds up after a few minutes. When you turn it off, it "cools down" and can be used again. If that's the case, you should take it to a dealer's shop and have it checked (or replaced if it's still under warranty).
Mar 13, 2011 | ViewSonic Computers & Internet
Monitor shuts off after approx 2 min when i start. i turn monitor switch off and turn on again and stays on approx 2 min and shuts off again
Go to control panel > Power options and check the power settings there. Are the settings for "Turn off monitor" set to 2 minutes? Increase the time and see if there is any changes.
If the above does not solve it, it's quite likely that your monitor's power supply is giving problems. Turn it in for warranty/repair.
Mar 07, 2011 | HP 2009M Monitor
I have a Dell Ultrasharp 1907FPV, it's a few years old. Whenever I start my computer, the moniter stays dark and the green power button does these quick flickers. Eash flicker cycle takes less then a...
You don't have a short-circuit. That would have blown the protections or even the monitor. Refer to the manual, that flashing light may be a code that tells you the problem. I don't think the repair would be expensive...
Nov 29, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
I have a Dell 1707fp monitor. When I power the monitor on it powers on normally. After a few miniutes, even though the power button is still green the display goes blank. I have tested this on other known...
I just fixed my for less then 1 minute. Here was the problem, when turn on the PC with the monitor connected. The screen appear like normal for about 2 seconds then shut off black but the GREEN power LED stay on, if i press the power off and turn it back on the screen act the same thing.
Here how to fix it, turn off the PC, unplug the monitor power cable then plug it back. The power LED will stay amber. Hold down both brights minus - and plus + same time, turn on the PC, keep hold the - and + buttons press the power button turn on the monitor.
You will see the screen back on, just hold for about 10 more seconds till you see the screen seem to stay on fine then realse them. That's it how i fixed my.....GOOD LUCK
Oct 27, 2009 | Dell E173FP 17" LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Turning the power on causes the screen to display ENVISION for approx. 1sec.and it goes out and stays out. Switching a display signal on through an A-B switch gives approx. a 1sec. display time that does...
Your power supply has burnt out which unfortunately is extremely common in new devices. I do agree that it may be worth fixing if it is only couple years old.
Jun 11, 2009 | Envision EN-7220 17" Flat Panel LCD...
Emachine Monitor comes on a few minutes and cuts back off
I have the same problem and I think its the circuit board on the power on button and blue led. I unplug the board when the monitor is on and then the monitor stays on and works OK.
It don't make any sence it is only 3 parts switch led connector
anybody else run into the problem
Mar 29, 2009 | E-Machines eMachines Monitor E15T4
Monitor loses power randomly.
Is your monitor a CRT or LCD type. For CRT type information follows. In most cases your simptoms indicate a problem with the High Voltage or blanking circuits. Caution the High voltage can be as much as 40,000 volts and even unplugged from the wall the picture tube can continue to hold voltage (enough to hurt you). Do you here a snapping sound from the back of the crt. If you do the high voltage is shorting out and the protection circuit is turning off the high voltage. If you do not here sparking another possible cause is a faulty capacitor in the protection circuit or the flyback (high voltage transformer). Unless you are educated in electronic circuit repair this one is probable beyond your curren knowledge level. You can try taking the back off and cleaning out all the dust, but remember to stay away from the red wire that goes to the picture tube. Use only non metal cleaning tools. Good Luck
Nssms
Jul 21, 2008 | Gateway FPD2275W LCD Monitor
Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
Nov 04, 2007 | Gateway FPD1760 17" LCD Monitor
Samsung Syncmaster 192N 19" LCD Monitor Logo
233 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
