Question about Sony Handycam DCR-SR200 Camcorder
Connection hi there, i am just trying to find the usb slot on the camera if is does have one...
  • 752 Answers
Posted on Aug 05, 2008
How can i retrieve photos off my camera when my computer wont pick it up
Hi, are you using a USB connection or a camera dock? You don't say if it is the internal memory or a card. I try never to use the internal memory if a card slot is available. If using USB try updating to the latest driver or see if there is a specific driver for your camera.
One more thing if using USB try to connect camera with a cable to the MOBO USB headers, and not the ones on the case. I have also found connecting the camera first then powering on or vice versa sometimes helps with my older cams. Hope this helps.-
Mtlgod
Dec 15, 2015 | Cameras
I need the driver for my kubik evo 8g mp3 player. The driver disappeared off my computer and now doesn't recognize my player.
You should not need drivers for this device as it ought to be picked up automatically by your computer (assuming that it's Windows, what version are you running?). If you have an expansion card in the player, then try removing this and then re-connecting the Kubik to your PC to make sure that the expansion card is not faulty.
Another quick test is to check the cable, both in a different USB slot if you have one available and / or by connecting another USB device that uses the same connection (in my case, a digital SLR camera has the same USB adapater so I can use the cable for either). If, doing this, the second device also is not recognised then try swapping the cable for a new one (but again, if possible test the cable and connection to other USB device in another USB slot as well).
One other quick question - does the Kubik device work still when unplugged from he PC?
Feb 17, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
I have a no connection error on the printer. There is no computer connection. Refer to device documentation to troubleshoot. I am trying to save photos from camera to computer.
You camera came with either a USB cable and/or a memory card.
If you have the camera software installed, when you plug the USB cable into the camera & computer and turn on the camera, your software will open up and help you save the photos to your computer. If you have a memory card, you can remove it from the camera and insert it into the slot in the computer. Some printers also have slots and should be able to transfer the pics from those slots.
But--either way, the devices have to be on and installed properly
Mar 08, 2011 | Computers & Internet
Why the camera does'nt appear?
1. the USB port on your computer does not work -- try some other USB device (such as a USB memory-stick) in that slot, to see if any device in that slot is recognized
2. the camera does not work -- try connecting it to some other computer to check.
3. your computer is missing the device-drivers for the USB ports -- try some other USB device, and/or look in "Device Manager" for "unknown" device, or a yellow question-mark on some device.
4. you need to install the software from the CD-ROM that came with the camera.
Dec 15, 2010 | Logitech Webcam
I recently lost my USB Connection for this and I bought a new USB Connection for it , but now when I connect my camera into my Computers USB slot It doesn't recognize it.
Try with other USB ports in computer . If it works then it is fine . Else the cable which you got one is faulty ,you need to replace it .
Hope this helps .
Mar 20, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Cannon PowerShot SD870 IS Digital Camera
Hi
I don't know what operating system you are using, and I don't know how to make it work with a MAC sorry.
If your camera won't connect when plugged in via USB cable, then try a different USB port, and a different cable if you can. I have a USB mouse that quits on me sometimes, then I unplug it and plug it back in a few times and it works again.
If that doesn't work, your computer may need a driver for the camera (if you have an older version of windows) or your USB might not even be working... try another USB device in that same slot, does it work?
This could be a computer problem.... hard to say without testing a lot of different things sorry, hope the information above helps.
Good luck from Darntoothysam com (a digital camera repair business)
Thomas
Sep 13, 2008 | Canon PowerShot SD870 IS Digital Camera
Maxtor and vista
Try some other USB device (memory-stick, printer, camera) in the USB slot in the Vista computer, just to "prove" that Vista will recognize _any_ USB device connected to that slot.
May 31, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Downloading from SD550 to Dell
Try to use another USB slot and it would be preferrable if you use the USB slot at the back of the computer. If that did not work, use another computer.
May 02, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Casio Exilim ex-z40 won't down load
Try reinstalling your camera drivers. You need to uninstall it first while docking station is removed. Then reinstall your camera software through the cd that comes with it then try plugging it in again either on the same usb slot or a different usb slot. Then try docking the camera again if theirs any interruptions. Usually if you transfer the docking stations usb cord plug to a different usb slot, the transfer goes haywire. Try transferring to a different usb slot...
If all else fails, get a card reader for your cameras memory card, it is way faster...
Feb 08, 2008 | Casio Exilim EX-Z40 Digital Camera
Sony Handycam  DCR-SR200 Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
