Question about Weather King 10PJA4301AH Air Conditioner
Continuing running, Ice on outside unit - Weather King 10PJA4301AH Air Conditioner
  • 2,133 Answers
Every unit has to take rest to re boost. That's why thermostat for heat or cold fixed, If your unit is not cutting off @ setting temp check room sensor. If defective replace it.
If unit continuously running but no cool inside room means gas leak. Find leak and do gas charging.
Posted on Dec 31, 2010
How we repair LG ac showing C1
try switch the unit off till ice melts and try running the unit again after. if the ice is till coming back check the filters are clean and outside coil clean. sounds like a restriction in piping,possibly a blockage.
c1 err caused by the indoor pipe sensor being out of spec, possibly due to the ice buildup.
Apr 24, 2016 | LG Heating & Cooling
Comfort star
Make sure the indoor filters are clean. The outside unit will continue to run until the indoor reaches the temperature you have selected. Dirty filters can throw the temperature out. Its common for outdoor units to freeze up when on heating mode if the ambient air temperature is below 5 degrees Celcius.. The machine should however, defrost itself. There could be a problem with one of the pipe or air sensors on the outdoor unit.
Feb 23, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
Have ice build up on line leading into outside unit and ice buidup on inside units on my goodman air conditioner
Turn the system off on the thermostat and set the fan to "ON", this will thaw the ice faster if it hasn't already. When the system has completely thawed, which could take hours sometimes, depending on how bad it's frozen, then turn system back to "Cool" and start these checks>
1. Make sure filters are clean!
2. Make sure there is proper airflow through vents.
3. Make sure outside condenser fan motor is running.
If you have either no or minimal airflow, check the indoor blower to make sure it's working, if it is, the evaporator coil is dirty restricting the airflow. Be sure the system is thawed because the ice will also block the airflow!
If the condenser fan motor is not running, either the capacitor or the fan motor will need to be replaced.
If your filters are clean, you have good airflow through the house, and everything comes on like it should, it will most likely be the charge of refrigerant in the system is too low and you have a leak somewhere. If you have to have it charged, be sure the system is thawed before the technician gets there, he will not be able to do anything while it's froze.
Hope this helps and good luck!
Jun 08, 2012 | Goodman Heating & Cooling
Carrier outside Unit will not power on. Every 45 sec's to a 1min it will make a humming sounds like its trying to power on but wont. The fan unit inside will come on but will not disburse cold air
You probably have a bad run capacitor in your outside unit. You will need to cal a service tech to test and replace it, until then turn your system off until it is repaired. Continuing to try to run it will over heat the compressor and fan motor and cause them damage.
Jun 16, 2011 | Carrier Heating & Cooling
1. what are reasons why refrigerant compressor burn-out? 2. ice build up on suction line. 3. Insuffecient cooling. 4.Outdoor unit not running, but indoor is operational.
On the split system 1. Can burnout from defect, lightening, etc .. 2. Only way ice will buildup back to outside unit is LOW LOAD.. either from dirty filter, dirty coil or fan blades caked up with dirt. 3.. Poor airflow will cause the poor cooling $ Outdoor unit most likely has a low pressure switch causing the outside unit to shutoff until pressure rises.. Has this helped ?
Sep 03, 2010 | Heating & Cooling
Outside unit iced up how do de-ice
As with the simplest way to thaw ice is with heat.
If you are running this unit in cooling and have ice outside, then you most likely have a freeze up inside as well. If this is a heat pump unit, then frost is normal during operation, however, ice build-up is an indication of a problem.
There are 2 effective ways to remove the ice build-up. The first is the simplest. Get your water hose and hose it down. Be sure to turn off the breakers to the unit and avoid spraying the electrical compartment. If you have the ability to hook the hose into a hot water line, then this process with be extremely fast. Let the unit sit for about 20 minutes to dry out and turn it back on.
The second can be a little more complicated if your not tech savoy. You can turn the system on in the cooling mode. This will make the outdoor coil the condenser section. Then, either block the airflow through the coils with an object, put an object over the fan to increase pressure, or if you can, disconnect the fan so it does not run. This method is essentially the same as a defrost cycle.
As with any failure, you can fix the problem at hand, but it will return. After you get past this, your real challenge will be determining what caused the freeze-up.
If you were running your system in cooling already, then you will need to ensure the system has de-iced on the inside as well.
Jan 12, 2010 | Heating & Cooling
Why is ice continuing to form at the bottom of our GE frig?
these units have a defrost drain that gets plugged.
you need to remove the ice from the freezer section and try to use a "turkey baster" to force water into the drain hole. it may be frozen and need to run hot water to get water to flow thru the drain.
sometimes you have to remove the drain from the back underside of the unit to clear the line. try the hot water inside first and if you cant clear the drain, then go to the back and remove the restriction from the drain line.
Jan 08, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Nordyne AC unit works at first but later provided cool air. Thermostat set to 65. Power running to unit outside. Noticed ice around line outside and can send a picture. Chipped ice away. Want to know what...
If the inside fan motor is running OK you are low on refrigerant. If the inside fan motor is not running, repair the inside fan motor. Could also possibly be dirty inside coils.
Jul 20, 2009 | Heating & Cooling
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Weather King 10PJA4301AH Air Conditioner Logo
57 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
