Question about Uniden BC72XLT Handheld Scanner
I'm looking for a battery for my scanner. battery #BP200. scanner is probably 20 ytrs old.
    President:
  • 2,761 Answers
You didn't mention the make or model of your scanner, but the only BP200 I can find is for a variety of Icom units. If yours is an Icom, you can pick up the battery on eBay. Follow this link for an example:
http://shop.ebay.com/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A4026&rt=nc&_nkw=BP200+battery&_sticky=1&_trksid=p3286.c0.m14&_sop=15&_sc=1
Bill B.
Listening in since the 60's
Posted on Dec 31, 2010
How do I make smoke alram stop going off when there is no smoke or fire.
If it does not have a battery backup there is a good chance it is over 20 years old and needs to be replaced.
Feb 21, 2015 | Home
I have a primefilm 2700 scanner and I'm looking for drivers for this scanner for windows 7, can you help out?
Scanners are often not supported when a new operating system comes along.
The simplest solution would be to run an old computer with the correct drivers for the scanner, I'm afraid. You can probably get an old computer for around £30.00, which is far cheaper than buying a new film scanner.
Jan 20, 2015 | Office Equipment & Supplies
How do I replace the internal battery? I ordered and have the battery, I do not know where the battery is located?
To replace the battery in the MS9535 Scanner, you need to remove three phillips head screws. First remove the rubber surround at the front of the scanner to reveal two screws underneath. Just pull the cover forward and it will slip right off. The third screw is located underneath the small round sticker near the bottom of the handle. Either poke through it or peel it off. Once all three screws are removed, carefully separate the top and bottom halves of the scanner. Make sure to note how the battery is positioned in the handle as it needs to be orientated correctly when replaced. Carefully pull the battery wires out of the socket on the circuit board, noting the orientation of the plug, and remove the old battery. Plug the new battery in. Be sure to place the new battery in the same position as the old one and place the circuit board in its spot. The red lens probably fell out of the front of the scanner, so replace it and bring the two halves of the scanner back together carefully. It may take some fiddling to get everything to settle in place. Replace the screws and rubber surround. There should be enough charge on the battery to power it up for a test. Charge scanner over night and you're good to go.
Jun 09, 2014 | Metrologic Instruments MS9535 VoyagerBT...
I tried to plug in a digitech bp200 pedal and then my amp went on the fritz and starterd buzzing loudly. I attempted using the effects loop section on the back of the amp with my bass direct into the amp,...
DO NOT try a guitar pedal as an effects insert via the back jacks... they are for an external line level EQ/Effects type unit. Your guitar pedal should NOT have caused any damage. Check the power adapter you are using with the BP200. The BP200 takes a 9 VAC adapter, NOT a 9VDC type common to most pedals. You cannot use one of the Pedal Train type supplies with the BP200. Also check that you have the in's and out's correct on the pedal... backwards and they will cause what you are observing.. Verify your cables are good. The output of the pedal goes in the FRONT jacks of the amp. ONLY line level drives go to the back jacks.
Jun 05, 2011 | Hartke Lh1000 Bass Amp Head 1100 Watts...
Have a bc2500xlt that battery pack is gone. were do i buy one?
The battery pack (BP2500) and power supply/charger (AD70U) for your scanner have both been discontinued by Uniden, but I did locate a battery pack on eBay. You can check it out here:
http://cgi.ebay.com/BP2500-Battery-Pack-Uniden-BC2500XLT-BC3000XLT-Scanner-/180531979744?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item2a088b65e0
Considering the fact that your scanner is about 15 years old, and the price of the battery pack is $56.99, you would probably be better off donating the scanner to a museum and buying a new one.
My apologies for being the bearer of bad news.
Bill B.
Aug 03, 2010 | Uniden BC60XLT-1 Handheld Scanner
Software for Canon LiDE 20 scanner (Vista compatible)
did you install the drivers? they were probably downloaded compressed- you need to look at your download list and install from there. don't know if vista refers to it as install wizard, as xp does, but check that the download was actually opened and installed. otherwise, it's sitting on your hdd doing nothing useful. i'm not familiar with vista, know a lot of people who tried it and switched back to xp. still waiting for the user reports for w7. supposed to be a great improvement on vista! so we wait and watch!
anyway, check out whether your patch for your scanner actually was installed!
good luck!
Sep 29, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
My old all-in-one won't scan with my new Vista computer. I am scanning old photographs. I found a fix by scanning through the Paint function. However, I cannot resize the JPEG image I get. It is about...
It sounds like a driver issue. So go to the HP website and look up your printer model under support. I have an HP aio printer/scanner and when I upgraded my Mac operating system, I had problems scanning photos. I went to the HP website, looked up the model number and reviewed support/driver topics, and found the appropriate solution. You'll probably have to uninstall your current printer software and then reinstall with a download from the website. Hope this helps.
Aug 06, 2009 | Computers & Internet
Old Kalimar binoc. pair won't run on
Try cleaning the connectors with a scotchbrite pad, then blow it out with a dustblaster
Mar 24, 2009 | Ultra Super Zoom Binocular (20 to 125x27...
How to attach outdated hardware cable to computer w/usb ports?
Hi!
I'm not really sure what you're asking. If your problem is that your scanner has an "outdated" connector and you want to try to connect it to your PC via USB ports, the only sensible answer, given the prices of scanners, is to buy a new scanner. Your old scanner, if it is not USB, is probably a SCSI connector device. Do a Google search exactly like this "USB to SCSI adapter cable" and you'll see a lot of results. Cables generally seem to range from $20 to $100. Even if you get the scanner connected, there is a very high probability that there will not be any drivers available that will work with the new computer and cable. All-in-all, a new scanner, even a cheap one, is the way to go IMO, and will give you better scans to boot.
Good luck and please let me know if this helps!
Bob
Oct 09, 2008 | HP ScanJet 3200C Flatbed Scanner
Bearcat scanner 210xl program manual
Here Is A Users Manual For The Uniden Bearcat 210XL 18 Channel Programmable Scanner.
Just Follow This Link And Save or Print It Out In .pdf Format.........
I Myself Used My Dell Laserjet And Printed It As (2) two Sided Pages And Have A Nice Looking Manual. It Is A Complete Instruction Manual That Tells You How To Set It Up!
http://www.repeater-builder.com/uniden/pdf/uniden-bearcat-bc210xl-owners-man.pdf
Jan 24, 2008 | Uniden TRUNKTRACKER III
Uniden BC72XLT Handheld Scanner Logo
46 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
