Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Lost Color after Speaker was too close to TV
I have a Panasonic 27 inch TV. I set an unshielded subwoofer too close to the TV. I removed the speaker after I turned the TV on an notice it had lost its color. The image is not distorted, but the TV is only black and white. Oddly enough, when the menu is pulled up the menu choices are in color. Is this problem fixable?
  • 927 Answers
Good Day, Props123;
It sounds like you may have locked-up the micro, try unplugging TV from wall for 3-4 minutes, then replug. If the TV was magnetized (crt) the osd would also display no color.
Good Luck, Big Irish.
Posted on Jul 08, 2008
How much air space do boss blade 15 need
Subwoofers differ in only one way. You get an "Open Air" and a "Closed air" subwoofer, That being said, you'll have to check on your magnet which one you have to make the boxes for that sub. If it is an "Open air" Subwoofer, you should see a "wire mesh" or "grid" in the centre, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.
If it is a "Open air" sub, your boxes should be sealed with silicone, and no ports are to be cut in your box.
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require.
On a 15 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Enjoy!
Nov 24, 2009 | Boss Blade BL240DVC Subwoofer - 15" Dual 4...
Buzzing on MixSonic Subwoofer
Buzzing sounds in audio equipment can almost always be traced to substandard wiring, bad grounds, or wiring that is run to close to a power source like extension cords or power strips. Unshielded RCA's can do this and RCA's that have a broken lead can also do this. So first try moving it away from your other equipment. Then start checking RCA cables or any other input cables to make sure they are intact. You may have to replace the wires to see if there is a problem as a broken lead may not be noticeable from the outside. If you try all this and still no improvement, it would be likely that the source of the problem is in the MixSonic.
-Dynami
Jan 25, 2009 | SDAT SB-L1006S Subwoofer
My 27 inch orion tv picture looks like hour glass
you have to make sure that if you are using external/additional speakers that you keep them away from console. I had a similar problem when I install a surround sound system in by bar and one of the speakers was very close to the TV. A good friend of mine walked in and said "if you want to get rid of that picture problem and save the life of the TV you had better move that speaker." It has to do with the magnets in the speakers.
Jan 24, 2009 | Orion STV2763 27" TV
27'' RCA appears out of focus on the vertical Edges of the Screen
I've seen this on many computer CRTs as they age past 6 years. I would imagine that the gun alignment is out. Are all the colors (RGB) fuzzy, or is it hard to tell?
1. Sometimes, extreme settings of contrast or color (usually to offset low output from aging CRT) can appear to unfocus your screen. Adjust color/contrast down if they are maxed out or close to highest setting/pot level.
2. A very likely culprit is unshielded speakers are too close to the screen. If this is the cause, the speakers' magnets distort the part of the screen closest to them (sides), and it will get better/worse as you move the speakers away/closer to the TV. If there are not magnets near the TV, and degauss function does not fix problem ('89 TVs have degauss?), see #3.
3. The focus can be set by adjusting the flyback transformer. As an experienced electrician, you should know about the dangers of messing with the insides of the unit.
If this fails, you might have other bigger issues. I'd suggest a nice trip to lead reclaimer if so. I'd say 19 years is quite a life for a CRT.
Nov 12, 2008 | RCA F27440 27" TV
Cannot turn off cc
Yes. one of those six boxes are 'setup' box.
  1. go into setup and you will see cc mode (second from the bottom of the list).
  2. simply select the cc mode and make sure it is set at "off"
  3. exit the menu and you are set.
Regards,
Feb 16, 2008 | Panasonic CT-27G5 27" TV
Sony TV help
sounds like it needs demagnetizing, also make shure you dont have any unshielded speaker close to the set, demagnetizing is performed with a demagnetizing coil, you can purchase one at any tv parts dealer for about 30dollars
Dec 06, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Picture problems
This could be an unshielded cable problem. Also magnetisam from speaker(s)(i.e. subwoofer) could affect signal from satelite antenna, or could affect satelite receiver if it's near.
Oct 01, 2007 | Panasonic SC-HT40 System
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
100 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
