Question about Fantom Titanium Hard Drive
My fantom hd tfd500u16 is no longer recognized by my computer. I get a blue light and I hear the hd spinning. I uninstalled/reinstalled the drivers, replaced usb cord and tried connecting to other computers but no luck. I would like to put the hd in another enclosure to see if I can retrieve the data but the connection is neither a SATA nor IDE. Any info on the type of enclosure needed would be appreciated
  • vslusarz Dec 30, 2010
    its an external hd. I did try to connect to other computers
    Sergeant:
    Champion:
  • 217 Answers
Is this an inbuilt drive or an external drive? If you're using USB, it needs a USB connection. It shouldn't need drivers as the computer will automatically detect a hard drive.
Have you tried connecting to a completely different computer to see if that recognised it?
Posted on Dec 30, 2010
  • Martyn01202
    Martyn01202 Dec 30, 2010
    You can buy enclosures that accept all types of connections. Once you open the external drive you'll see that the connection is one that will fit into the enclosure.
    It's either the drive is faulty or the circuit board that sits inside the unit. I've had both problems before.
Fantom tfd500u16
Customer Service: 800-980-3463 (at MicroNet/Fantom) most of
their adapters run from $18-$28.00
The 4-5 pin connector on your drive might show the power (output)
from adapter to (input) for external drive.
Apr 15, 2014 | Fantom Computers & Internet
I have an external TFD500U16 and it has been running fine for the last 3 years now all of a sudden my desktop no longer sees it. I get a blue light and hear the drive spin but my disktop doesn't see it...
Either the hard drive inside the case is bad, or the board the controls the drive is bad. The only way you can find out if the drive is good is to open up the case and remove the hard drive, then plug it into another case you buy at your local computer supply store. However depending on the case this might break the case, it should be used as a last resort for saving your data.
Mar 11, 2011 | Fantom Titanium Hard Drive
Have a Fantom TFD500U16 HD. It was working properly for last 2 years and in one night I did take the backup but in the morning it does not get recognized. Though the laptop that was doing it got rebuilt...
My computer does not recognize the Fanton titanium drive. It was working properly for last 2 years and contains and all of a sudden I cannot see it's drive location once I connect it to multiple computers in my household.
I suspect that one of my teenagers "moved" a file instead of copying it and somehow corrupted the file structure. By the way, I have already tried to see if it is a problem that can be fixed by assigning a drive using Disk MGMT. It is not recognized there either.
Feb 10, 2011 | Fantom Titanium Hard Drive
Fantom GF1000EU Hard drive: When I turn the drive on my computer recognizes something is plugged into the USB, but it is unable to locate the drivers. The drive also does not show up in my computer.It does...
there is extra port of power and data attach in hdd and also use cable join this port. some time this port and usb cable loose and damage so we can not look hdd in computer. once atime change another case to check hd. (nepal)
Oct 13, 2009 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
Computer not recognizing external HD
1st try a different computers make sure its not your Hard drive!
2nd if that works then go to the hard drive maker and download a software driver for it that should fix the problem
Aug 10, 2009 | SmartDisk FireLite 40 GB Hard Drive
Fantom external drive 1T runs but not recognized
are u using the usb cable for connecting the drive? use usb ver2.0.
May 17, 2009 | Computers & Internet
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Drive Being Recognized as Removable Disk
Same issue with my 500 GB TFD500U16. A little more description is that my PC is detecting the power when turning on the drive and the HDD itself is spinning up. Also the Blue light that normally indicates HDD activity by turning Red no longer shows activity but just stays Blue. This indicates that the data side of the HDD is not seated properly. Since mine is out of Warranty, I took it apart and found this to be the exact case.
! ! ! ! Please perform this at your own risk ! ! ! ! Especially if your warranty is still in effect! ! ! By loosening the HDD mounting screws inside that will allow the connection to seat properly and data to be seen.
Dec 16, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
Drive NOT being recognized by WinXP
Put your ear to the drive and verify if it is making any strange low level sounds. Check to make sure the usb connection wasnt affected. YOu wont need a driver as it appears to be hardware related. Either the enclosure or drive may be failing.
Oct 24, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom Titanium Hard Drive Logo
571 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
