LaCie not connecting to any TV - Computers & Internet
  • 3 more comments
  • hkaratas Dec 31, 2010
    The product is LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
    I am using a A/V connection type to connect to the TV.
    The error message I get after connection the cables to the Lacie and my Samsung TV is: no signal
    I have tried with another set of cables and also on another TV => no signal
    What can be the problem?
    The product is LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive I am using a A/V connection type to connect to the TV. The error message I get after connection the cables to the Lacie and my Samsung TV is: no signal I have tried with another set of cables and also on another TV => no signal What can be the problem?
    Its a mediaplayer actually thats why it can be conected through A/V cables to TV.
    The reference
    Actually its a mediaplayer.
    The product brand and the rest is as follows
    1TB LaCie LACINEMA PREMIER HDD USB 2.0 E
    Its driver is "lacinema_premier_fw.bin" which is no more released obviously by "lacie".
    Hope this helps you identify the possible troubleshooting cause.
    With best regards,
    Halil
  • hkaratas Jan 02, 2011
    As you can imagine, I did all that already several times but it never helped.
    The product is dead for sure.
    Thx anyway
  • 13,433 Answers
Hello, your question is very vague, I need to know atleast the brands and models of the devices involved, how are you connecting them and if any other error messages or problems appear.
Posted on Dec 30, 2010
  • 1 more comment
  • Ekse Dec 31, 2010
    hello,
    I've never heard of a hard drive that could be connected with a a/v cable to a TV, can you tell me the model number of the drive or anything that reads on its label.
  • Ekse Jan 02, 2011
    make sure you got it connected properly and that you have selected the correct input on the tv.
    here is the user manual:
    http://www.lacie.com/download/manual/lac...
    TeChNICAl NOTe: When using the Composite A/V cable, use either the S-Video connector or the yellow Composite RCA jack. Do not use both. You will not receive a signal if both the S-Video connector and the yellow Composite RCA jack are plugged in at the same time.
    and you cannot connect to a computer and a tv at the same time.
    connect the yellow, white and red cables to the hard drive and then to the tv make sure you are connecting them in the right appropriate, same color slots on the tv.
    or if you use component video, do not connect the yellow wire at all, leave it hanging at both ends, the hard drive and the tv.
  • Ekse Jan 02, 2011
    Do not connect composite video (yellow) when using the component video connections
    power button on the remote to turn it on.
    TV out button on the remote to switch to TV mode.
    Cycles through: NTSC Composite > PAL Composite > HDTV480p Component > HDTV720p omponent > HDTV1080i Component
    hit the tv out slowly, wait alteast 20 seconds between presses, keep pressing it around 10 times until you see picture. if you don't see picture something is wrong, Double and triple check that you got everything connected properly to the tv and that you indeed have the right input selected. Try other inputs if you are not sure. until you get picture.
Lacie playhd system folder corrupt
sounds to me(pun intended) that the driver for HD TV is corrupt of missing what is hd unit you have and what pc are you using
May 22, 2012 | LaCie 2TB LaCinema PlayHD Media Player...
Can you get a usb to firewire cable for a lacie hard drive
well, there is this device by LaCie that allows you to connect usb and firewire stuff into the same hub
http://cableorganizer.com/lacie-usb-hub/
Apr 11, 2011 | LaCie d2 (300769) 200 GB Hard Drive
Connect desktop pc with hd tv with a wireless router
If you wish to connect your PC to the TV with a wireless connection,IF your tv does not have a wifi adapter you will need something like a wireless media centre.
These usually have a hard drive to record also.
Take a look at this 1 http://www.nextag.co.uk/LaCie-LaCinema-Mini-HD-1636198065/uk/prices-html?nxtg=212f0a280d15-6C48B4D13369CE23
Sep 08, 2010 | Acer Computers & Internet
When my lacie external hard drive is connected,my
Check your BIOS > StartUp sequence
Maybe the USB boot option has much higher priority that HDD boot. Try exchanging their priority and then reboot, with your external HD connected to pc.
Jan 03, 2010 | LaCie (300951U) 500 GB Hard Drive
How to correct connection problem for two LaCie Desktop Hard Driv
Here is the support website for the LACIE products.  As far as I knowthis site simply answers questions. Sounds like the hard drives are bad to me.
http://www.lacie.com/support/
Jan 07, 2009 | LaCie Computers & Internet
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Silverscreen problems
I reccomend connecting you computer directly to your tv, depending on which mac you have. DVI or vga. I'm sure the manufacterer does as well. The files maybe in a codec your tv does not compute.
Oct 20, 2007 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
