Question about Bose Companion 3 Computer Speakers
Whenever I turn the system on, I get very loud "white noise", even when the computer is not connected.
  • thewolfy669 Dec 30, 2010
    I do not use a USB port, it has a stereo jack connection! Is it normal to get white noise when the system is not connected to anything at all???
    Thanks for the help - I suspect that the problem is indeed the coil - the sytem was received as a gift in 2005!
    Thanks for the help!
    President:
  • 4,070 Answers
Hi and welcome to FixYa!
You may want to connect the speaker on a different usb port. This can help eliminate the white noise.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Dec 30, 2010
  • dj_relly999
    dj_relly999 Dec 30, 2010
    Not really, not unless that the coil inside is grounded or worn out. But if it's near a magnetic field, it's possible.
My oil light keeps coming on and when i shift white smoke comes out the exhaust pipe. Also a loud whining noise when i accelerate.
Could be too late but change the filter and oil for the correct grade. If that doesn't fix it, a new engine will.
Dec 16, 2017 | Cars & Trucks
Loud clunking noise when i turn a corner both sides rear
check the sway bar kinks for play both rear wheels will have to even ramps work good if you have them if the is any play in the links it wil rattle also check for play in the bushings that the bar goes threw tis will also give you the noise you complain of
May 28, 2009 | 1998 Lincoln Town Car
98 gs300 loud screeching noise that last for about 5-10 seconds
The only four rotating items under the hood are
engine
power steering pump
A/C compressor
and smog emission pump.
==== I would check the fluid level on the power steering first. Check for pink fluid leak on the ground,
==== Check the A/C system with the wheel turn to one side and APPLY ALL LOADS.
Example: high beam on,A/C max,radio on and deforster on.
This will give you system a stress test.
All eyes on the pully and locate to part that generate the loud screeching noise.
My bet is on the power steering pump.
Please post more info on the comment window.
I will follow up on it.
Feb 12, 2009 | 1998 Lexus Gs 400
Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Sep 25, 2008 | Logitech Z-5300 Computer Speakers
V3x problems
Try to update the firmware. you need to flash it using RSD lite software and you can download this for free on forums related to motorola and even firmware is available there.
Hope this info helps
Jul 21, 2008 | Motorola Mobility RAZR V3x Cellular Phone
V3x problem
take it to a store and see whats wrong if you sont want to check inside your phone and see if the sim card is broke or if theres a wire or something
thanx Elise
Jul 17, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Bose Companion 3 Computer Speakers Logo
438 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
