My moms electric furnace turns on and off repeatedly. We have cleaned the filters and installed a new thermostat. Any suggestions.
  • 102 Answers
It is short cycling is the main blower motor running?
Posted on Dec 30, 2010
The unit is on Heat, Fan Auto it's 36 degrees outside, Thermostate set on 73 Actual temp inside 70. Unit runs continuously. How can I get more heat. I tried Emergency heat and that doesn't help.
Have you cleaned the air return filters ? Wash them, don't vacuum or brush them. It damages the filter screen. Sometimes a thermostat will be out by a few degrees. If the filters are clean, try turning the temp down a bit to 65 degrees and see if the air con shuts down. ( If your room temp is showing 70, it should switch off the machine) If it doesn't turn off, keep reducing the temp by 5 degrees at a time and wait a few minutes each movement to see if and when it shuts down. If the machine keeps running, I would suggest your thermostat is shot and you will need a new one.
Jan 04, 2016 | Heating & Cooling
My furnace will not reach the desired house temperature in one cycle. It will run for several minutes, shut off, and repeat. It eventually reaches the desired temp but it take a long time and I feel it...
There are a few different reasons for short cycling of a furnace.
1. Inadequate air flow. Not enough air moving through the furnace can cause it to overheat and trip the high temperature limit switch.
check to see that all registers are open and returns are not blocked.
2 Improper heat anticipator setting on thermostat. Some thermostats have a heat anticipator and too low of a setting can cause short cycling.
4 Partially blocked drain hoses. If the condensate backs up into the furnace it can shut the flame off and then when the condensate drains the furnace starts again. Check all drain hoses to make sure they are clear.
These are just some of the possible reasons for short cycling .
Hope this helps.
Dec 26, 2013 | Heating & Cooling
Installed the Honeywell RTH2300/RTH221 but the old thermostat was removed by someone else. Since the original wires were not labeled, I simply attached them to the new thermostat by following the letters...
This appears to be a thermostat installation that was made without regard to wire code. The Honeywell material I have suggests it may be necessary to check connections at the furnace end and work back to the thermostat. There may be compatibility problems between the number of wires in the old installation and terminal connections in the new thermostat. Honeywell may be able to help at 1-800-468-1502.
Oct 29, 2013 | Heating & Cooling
Auto fan does not start electric furnace
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked.
If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide).
If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports.
If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
Oct 08, 2012 | Coleman Mobile Modular Home Electric...
I'm not sure of the exact model of my Goodman furnace, but here is the problem. The new furnace was installed this summer (2010) and it is mounted in the space under the house in Big Bear Lake, CA....
I suppose this furnace is fueled by Natural Gas?
(Or is it Propane-- Bottled gas?)
Did the Service company leave you any manual, with your new furnace?
and I would think there was a warranty, for assuring you (the customer) satisfaction, no?
Have you called the people who sold/installed it?
What do they say?
If they did leave a manual-- what does it suggest for narrowing down your possible problems?
Like: Low Fuel-- Low Voltage- Filter Changes, Fan switch problems- or ignition failure problems?
For a new furnace, someone should be right there to do a start-up for you!
Let me know what you learn--
Mack B
Jan 14, 2011 | Goodman GMS80903BNA Heater
Wiring heat only thermostat to inter therm central electric furnace had to replace fuze block, limiter, and sequencer thermostat only has one red wire and one white wire
I am trying to install a Honeywell VisionPro 8000 thermostat for my Intertherm Central Electric Furnace but I am having trouble getting to work any suggestions?
Oct 06, 2010 | Heating & Cooling
Our aprilaire humidifier is only 4 years old and it does not seem to be working. We have static in the house and when I did test mode it never drained water like it was supposed to. Any ideas what I can do...
Hope this helps, check and see if humidistat is set to 35% humidity and that bypass damper on humidifier is in the open position or winter position.(humidistat is usually located on cold air return duct near furnace). Next, replace humidifier media pad, remember to replace media pad (filter) annually, you also may want to clean any lime deposit out of humidifier housing with a solution of warm water and white vinegar before installing your new media filter.Remember to turn power off at side of furnace when cleaning humidifier and replacing media. Before installing new media turn power back on to furnace, set humidistat to the on position, turn furnace thermostat above room temp., and inspect humidifier to see if water is running from top,(you may want to have a bucket under humidifier when checking for water), if you see water running, turn power back off to furnace, properly install new media filter, reconnect humidifier cover & set humidistat to 35%. If you do not see water present, check water supply valve to humidifier and make sure its turned on. If water supply valve is open, then check water supply tubing for blockage.And the last things to check is to make sure all registers through out your home are open and not blocked by any objects, also make sure furnace filter is cleaned, if none of this works refer to installation manual to see if humidifier was sized and installed properly, Good luck.
Mar 03, 2010 | Aprilaire 600 Humidifier
I have the following home thermostat Honeywell-YRTH230B1009-Thermostat My husband changed the filter last night and the heat has not been on since. The gas in on and the pilot is lit but still no heat. We...
If your furnace has a filter or fan compartment door, be sure it closed tightly and that the filter is installed correctly - there could be an interlock switch that is preventing the thermostat from operating. Also, if you haven't already turned off the power to the furnace, do that, wait a minute and then turn it back on.
Obviously, make sure the thermostat is on, is set to heat and calling.
Dec 07, 2009 | Kitchen Appliances - Others
Heater furnace doesn't want to turn on'
Did the fan turn on, if it did when was the last time you cleaned the filter.
Mar 14, 2009 | LG L1004R Air Conditioner
Furnace blower not working how it should
first off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Jan 19, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
226 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
