Question about Canon PowerShot SD1000 Digital Camera
Every time I switch on my Canon SD 1100 IS is asks me to set date and time. I set date and time and then it lets me take pictures. Next time I switch it on again it asks to set date and time. How could I get rid of this.
  • Canon Master
  • 4,738 Answers
The camera's clock battery has worn out. Unfortunately, on most Canon SD series, this battery is not user serviceable. Recommend contacting Canon to see if they'll replace it, hopefully at a reasonable cost. 1-800-OK-CANON
Posted on Dec 30, 2010
How do i turn on the date and time stamp on my canon powershot SD 300
Set the Postcard Date Imprint. See page 74 of the manual: http://gdlp01.c-wss.com/gds/0/0900001380/01/PSSD300200CUG-EN.pdf
However, this mode reduces the resolution so that you won't be able to make prints much larger than postcard size. If you want to set a higher resolution so you can make larger prints, then the camera won't deface your photos by scrawling a string of numbers across them.
All is not lost, though. The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Aug 17, 2012 | Canon Cameras
Camera Canon A710 IS started to ask set time date when turned on
When the camera is left without power for an extended period of time, the time and date settings are gone. You need to reset them and when you're finished, click the set/ok button twice.
Feb 25, 2010 | Canon PowerShot A710 IS Digital Camera
How do i turn on the date stamp on my Canon Powershot SD750 so that the date prints on all my pictures?
Move top selector all the way to right,
1.put in auto mode
2. Hit Function set button
3. Where it lets use choose sizefrom L, M1, M2...scroll to Post Card 1600x 1200
4. hit function set again
5. Hit Menu, now you can select time date stamp
6. took me awhile to figure it out
Jan 31, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Taking the date off the pictures I take with my Canon Ixus 80 IS
Go to www.canonUSA.com, you can download the manual for the american version of the camera - the POWERSHOT SD 1100 IS
Instruction to turn on and off the date function are there.
Jan 20, 2010 | Canon IXUS 80 IS Digital Camera
I received a canon powershot as a gift last year and am just now really starting to use it. The pictures seem fine, but the it seems like I am frequently requested to put in the date and time (i.e. about...
There is a button battery in your camera (CR1220) that remembers the date and other settings when you remove the main batteries. It probably needs to be replaced. It's in a slide-out holder next to the AA batteries (see page 184 in the manual).
You turn on the date stamp by using the photo size settings. Press the Function key and scroll down to the bottom item (usually L). Then scroll over to the Date Stamp icon (to the right of the L, M1, M2, M3, S options). Press the Function/Set key again.
Nov 15, 2009 | Canon PowerShot A590 IS Digital Camera
Canon SD1200 IS won't save pictures to the memory card.
This Canon uses an SD memory card (previous Canon used CF cards).
The SD memory card has a "slide switch" that locks the card.
Look at the SD memory card and move the switch back and forth, then switch it all the way to the UNLOCK position. Put back in the camera and format the card, then use it.
Since this is a 10Megapixel camera, use at least a 2GB SD memory card. A 2GB SD card will hold 700 pictures, or so, in the best setting.
Hope this helps!
Sep 03, 2009 | Nikon COOLPIX S60 Digital Camera
Setting date on Canon elph Jr.
To set the date:
1. Press the Date button (rear left button on top of the camera)
2. Press the Select button (small round button up and to right of date button, may need pen point to press), display may show 97 1 1, with the 97 blinking.
3. Press the Set button (below the Select button) to change the value of the blinking character.
4. Press the Select button again to change to the next character. Use Set again to change. Repeat until date is set.
5. Press the Select button when all characters are set.
To set time, press the Date button again and the display should change to time (24 hour mode). Use the Select and Set buttons as above to set the correct time.
C, H, and P indicate the type of picture you want to take. C stands for Classic, and the picture will be in a standard aspect ratio. H is the wide angle setting, and the printed picture will be printed wide angle. P is panoramic, and the printed picture will be even wider angle than H. All this depends on the processor who develops your pictures for you. Ask if their equipment can read and process according to the instructions your camera will automatically put on each exposure on your film.
The three buttons on the left side are:
Top -- Flash setting. On (lightning bolt) or Off (lightning bolt with line through it).
Middle -- Film rewind button. Film should rewind automatically when fully exposed, but you can rewind before the film is fully exposed by using this button.
Bottom -- Self timer. Pressing this button puts a clock symbol on the display. When this is set, the shutter will delay 10 seconds after the shutter button is pressed. Press this button a second time to turn off the self timer.
Mar 17, 2009 | Canon Elph Jr. APS Point and Shoot Camera
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
huetrichard@gmail.com
Feb 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Sd600
press the function button and change the picture size to postcard-there is only one setting that allows you to do date and time stamp-once you have rigth pic size setting-pretty sure it says postcard-go back to menu and you will see date and time highlighted on menu
Sep 06, 2008 | Canon PowerShot SD600 Digital Camera
Date stamp
To get the date/time to be on your photos while taking the picture so you don't have to use the software later do this:
When in the mode to take pictures, press the round "Function Set" button and change the recording pixels to "Postcard 1600 X 1200". "Postcard" is the only setting that will allow the time/date stamp to be recorded on the picture.
Then press the "Menu" button and scroll down to "Date Stamp". You can select "Date", "Date & Time" or "Off". You can only do this when your pictures are set to the "Postcard" mode.
Dec 16, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD1000 Digital Camera Logo
159 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
