Question about HP Pavilion a1340n (EL470AA) PC Desktop
I am trying to hook up a UltraSpeed wireless router to my computer and can't seem to get it to work. Do I need something eles beside the router?
  • debbie_mcw Dec 30, 2010
    There are no drivers for this router.
    Brigadier General:
  • 8,909 Answers
You will need to download drivers for it and they must be compatible with your OS of course then once installed, plug the router in and the pc should be able to find it.
Posted on Dec 30, 2010
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
I have a WRT54G2 Wireless router. Works okay with
yes mke sure wep is correct code. make sure you home security level is the same as your laptop. have tried hooking up your laptop to the home with a cat 5 cable. we had to do this with 2 dell vista laptops. then disconnect lan and we hooked up wirless just fine. something in vista firewall settings.
Dec 31, 2009 | Linksys WRT54G2 Wireless Router
I am not really havein problems with the router i have 1 computer working and a laptop working now i need to get the other computer to run off wireless do i need to hook something up to the other computer...
You can go with a USB or PCI Wireless card. Wired is the fastest connection though, if you can run a cable from the router to the computer. Wireless is shared bandwidth so if you get to many systems going at the same time everyone gets a little less
Nov 29, 2009 | Belkin (F5D7633UK4A) Wireless Router
Dimension e520 - disconnected computer to get it repaired. Now trying to hook everything back up. Have wireless in the house, but can't get on the internet. Says needs to be hooked up to local area...
components of a home network include some kind of service (broadband or dial up) a modem, a router (wire or wireless) and computers.
If the computers are wireless, you use a wireless router. You can mix wire and wireless, obviously..
If you do this, the routers should be peer to peer (dont use the up link on the downstream device. ) One device must be plugged into the modem ... on that device, use the uplink.
If you are looking for a software package to manage your network magic, free to download and evaluate, After the free period you pay $ or continue to use the package but with fewer features.
NM is excellent with diagonostics, device sharing, security and tacking intruders as well as a lot of other things. I use the paid pro version.
Thanks for posting your question on FixYa.com
Nov 03, 2009 | Dell Dimension E520 PC Desktop
All plugged in and was working, just stopped. line into home is working-this computer is hooked up to it. will not work on any of our laptops---says that something is unplugged
hi,
it seems that the wireless network connection is not working.
you will need to check the wireless connection settings on the router, you will need to access the router set up interface.
Also you wil need to check the wireless connection on the laptops.
It is very simple . Click Here for more info
Oct 17, 2009 | Cnet Wireless-G CAR-854 Router (CAR854)
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Hooking up a wireless router
read this guide:
http://www.microsoft.com/windowsxp/using/networking/setup/adhoc.mspx
http://resnet.uci.edu/routersetup.asp
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Mar 20, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless set-up
Did you try to check if the cord is properly connected to the router? Check if you can connect to another LAN port. If the router is working on the another computer it means that there is something on part of your computer that is not working properly, Check also the Ethernet cable if working properly? or try to use another Ethernet cable to connect with the computer.
Mar 17, 2009 | Linksys WRT54GL Wireless-G 54Mbps...
SMC Barricade wireless router needs to be reset constantly
Maybe it is an electricity problem, or it's nearing the end of it's life. I bought 2 routers till now.each one worked fine for 2 years and then never worked.You should buy a new one or check if there's something with the electricity . Maybe a higher voltage
Feb 18, 2009 | SMC (SMCWBR14-G2) Router
Connecting a router
To connect more than one computer to same network, you need to use a router. Two modems will not work on same network.
My suggestion:
Buy a wireless modem router for cable broadband (and eventually a wireless network card for the other computer.
Here is an example: Linksys BEFW11S4 Wireless-B 4-Port Cable/DSL
Ask retailer to get right model for your broadband.
Connect the remote computer with wireless.
Apr 22, 2008 | Computers & Internet
HP Pavilion a1340n (EL470AA) PC Desktop Logo
197 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
