Question about SYMA Toys industrial Volitatin Radio Control Helicopter With Gyro 3 Channel
SO32 RC helicopter. It swings fore and aft while hovering in the air. If I fly forward and stop it accentuates the swing, hard to control. Same if I fly backwards, when I stop in the air there is a large swing for and aft and the aircraft plunges forward. My landing gear is broken, have fixed it while waiting for a new set. I did it with light wood. Could it be too heavy? seems to me it is not much heavier than the original gear and nowhere near the total weight of the aircraft. Also a very slight wobble in the whole chopper when in the air, but I can not detect a bend in one of the driveshafts. It spins very true when I look from above at idle speed on the ground. Unfortunately during the learning phase we have had some hard crashes. Thanks
  • cjricketson Jan 29, 2011
    I have figured it out. The for and aft swing is due to a balance problem. The aircraft needs to be in balance around the rotor shaft. Suspend it from the roof with 2 loops of fishing line placed equal distances from the centre on the balance arm. Swing the rotors one parallel with the body, one 90 degress to the body. The rod to the tail rotor should be level. I used split shot fishing weights clipped to the tail to level it out. Once you have rough balance hover it without engaging the tail rotor. If it flys forward you need more weight on the tail, if it flys backwards then less weight on the tail. I held the split shot in place with thermal glue, squeezind them onto the fin was not enough.
    The rough vibration was due to the tail rod being loose. I could wiggle it. There is a screw underneath to tighten it, I also used a loop of 24 ga. wire looped around the rod and an the body, twisted tight to stop vibration.
    Both problems fixed.
I have the same problem but unable to figure it out either
Posted on Jan 29, 2011
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Tail rotor blade is bent and helicopter wont fly forward or backwards
Fixing Your RC Helicopter - The Basics + Tips / Tricks ...
? 3:26
https://www.youtube.com/watch?v=Gxst73zE0VY
Jan 16, 2011 - Uploaded by Live2Fly94
i have a heli and the tail rotor will spin right but not left .... im having problems with my silverlit nano copter the tail ...
Frequently Asked Questions - RC Helicopter Wiki
www.rcheliwiki.com/Frequently_Asked_Questions
Probably the best way to learn to fly is to find a group of like minded people locally and ask their advice. ... The tail rotor should rotate so that the blades come 'up' towards the front of the heli. ... My helicopter won't stop spinning! ... still flying awesome but now tail vibrate and it issues backward forward. what should i do ?
Dec 28, 2015 | Toys
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
My Firewolf F+series wont go forward when flying.
Youd tail motor in bad or the wires going to is are faulty. The flight board could be bad but thats unlikely. Good luck.
Mar 19, 2014 | Generic F163 fire wolf 4.5ch rc dual...
Helicopter swerves right at speed
Hang it from a sting attached to the rotor shaft and see if it hangs level. It sounds to me like it is off balance.
Mar 07, 2014 | WL Toys WL V912 MAX 4CH FP RC Helicopter...
My 9116 double horse RC helicopter just spins clockwise in circles, on the ground or in the air. I can hover it, but only spinning. What could be wrong?
Air Hogs remote control aircraft are designed to be easy to fly and use, and rarely have flying issues. However, there are the occasional issues that the company can't really predict. Some Air Hogs helicopters, for example, have a hard time flying forward without some assistance. If you're having this problem with your helicopter, this can be annoying, but it is not the end of the world. There is as solution, and it's easier than you might think.For more information:
http://www.playgroundmats.co.uk/ Playground Mats and Playground Flooring Tiles Soft Play Equipment
Jan 10, 2014 | Toys
My helicopter (SO32 Gyro) having previously worked perfectly now will only hover. I have tried recharging it but it makes no difference. I wonder if I have overcharged the battery and if it is possible to...
Batteries are available online (amazon and many others) and change easily with only small screwdriver. Overcharging is not the issue. Nearly impossible with PCB (overcharge prevention circuit) hard wired into battery AND in charger. Problem is likely UNDERcharging, overDIScharging, or improper battery care. Battery MUST be allowed to cool 10 minutes after flying. Charge until light on charger doesn't get any brighter when helicopter is unplugged... light comes on (dim at first) well before full charge. 10 minute cool-down after charge also a MUST. And, most important, when flying, as soon as you are unable to maintain altitude, land helicopter and power it off. Li/Po batteries should never be fully drained. Even one full discharge can cripple or ruin entirely your helicopter's battery.
hope this helps.. let me know,
r
Feb 27, 2011 | SYMA Toys industrial Syma S032 Ready to...
My rc helicopter wont fly high?
flew at first hit sealing won,t fly now hit the trim button,s but still wont fly
May 13, 2010 | Radio Shack Indoor Micro Mosquito Rc...
How do i fly my spin master air hog rc helicopter all it does is go in circles
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
COLOR AND PLACEMENT OF LIGHTS ON EXTERIOR OF HELICOPTER IE WHAT COLORS GO ON PORT AND STARBOARD, FORE AND AFT.
When the helicopter is facing away or heading away from you, PORT is RED and is on the LEFT side. Starboard is on the Right and is Green.
Aug 14, 2009 | Jumbo RC JUMBO HELICOPTER
SYMA Toys industrial Volitatin Radio Control Helicopter With Gyro 3 Channel Logo
1,032 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
