Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
My fridgidaire upright freezer model #FFU20FC4AW2 will not get below 40 degrees. What can I do?
5 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
  • 172 Answers
SOURCE: Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 28, 2008
diths_kri
  • 67 Answers
SOURCE: Frigidaire Upright freezer FFU20FC4AW2
Sounds like the timer could be getting stuck and not releasing the defrost cycle
Posted on Jan 07, 2009
  • 1252 Answers
SOURCE: I have an older commercial upright Hobart freezer.
In most cases, an evap that freezes up is either an air flow problem or no defrost cycle. Older Hobarts have mechanical defrost time clocks. It could be locked up i.e., not running so no defrost cycle.
It could be coming out of defrost too early because the sensor that monitors the evap temp is not working properly.
The door could not be closing. If left cracked open, it will freeze up every time as unit never hits temp., keeps unit running. Warm air is seeping in and the moisture freezes on evap.
Lastly, the defrost heater(s) may not be working. Burned out, shorted, broken wire, etc.
Good luck and hope this helps.
Posted on Mar 29, 2009
Where is the control knob for Frigidaire upright freezer Model No FFU20FC4AW2
It is on the back wall, about 2/3 of the way to the floor on the right hand side... Knob will look like this: Frigidaire Freezer Control Knob 216707200
You probably have food in front of it!
Jul 31, 2016 | Frigidaire Freezers
Why Frigidaire Upright freezer FFU20FC4AW2 compressor starts and stops
Hello Friend, thank you for your question!
From what you have described it sounds like the compressor is cycling on when cooling is necessary and cycles off when the temperature inside your freezer has reached the set temperature. This is normal. If you feel that there may be some other issue occurring, feel free to go to the manufacturer website where you can easily locate a service provider in your area.
Jul 14, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
DO THR NEWER UPRIGHT FREEZERS NEED A CONTROLLED ENVIROMENT
Hello kk....no. the new freezers do not need a controlled environment as they will adjust on their own. The only exception would be severe cold. Operating them below 40 degrees farenheit is not recommended. Joe
Thanks for choosing Fixya!
Mar 01, 2011 | Freezers
My Fridgidaire freezer is flashing E9 , What does
http://www.frigidaire.com/manuals
go to this web site. It has lots of manuals. I found several for your unit. just enter you model number and it shows up with several choices.
Hope this is what you are looking for.
May 29, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
My Kenmore freezer, model #253.9280212 runs but will not cool below 40 degrees. It runs all the time but I do not hear anything cut on and off. The freezer is 10 years old but looks brand new.
The first thing to check is door gasket< bad corners,gap in side,bottom or top. Close door on a dollar bill and try to slide it top to bottom side to side and if it slides fairly easy then seal is not doing good. If you find dirty area clean it off along with the cabinet side as well.If you find the side is leaking then heat gasket with hair dryer and apply vasoline to gasket to help it move freely. If you find tear or hole then replace it.
Apr 22, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer only cools to 40 degrees
check to see if there is ice built up on the inside back if there is it may have defrost problems or if part of the back has ice it may be low of freon
Apr 20, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Sounds like the timer could be getting stuck and not releasing the defrost cycle. If you have to do it again, you should have the timer checked, or just replace it.
Jan 02, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
105 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
