Question about E-Machines eMachines Refurbished EMA eMachines PC Desktop
Emachines T2482 hit the power button to turn cpu on and everything sounded right but on monitor got a red green blue box flashing says somthing about check pc and some cable. I cant get a picture
  • 45 Answers
Could be a video card failure or a cable problem. This could also happen because the motherboard failed if you have integrated video. Unfortunately your going to have a tech onsite to repair the issue. That is, unless you want to install your own video card which would probably fix the issue.
Posted on Jul 08, 2008
Samsung s24b300a 24" monitor: powers on and then powers off, with just a flash on the screen. Does it make a difference if I don't have a computer connected to it?
yes it does make a difference if it not connected but a box should pop up and say somthing like no video input or somthing along those lines
or just a box red blue and yellow for a second or 2 and then go black.
hope this helps and answers your question?
Feb 02, 2013 | Samsung Computers & Internet
Green power light comes on goes off then on again stays solid, moniter says no signal, mouse lights up, and three red lights on key board flash then nothing why?
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Nov 21, 2012 | eMachines EL1852G-52W
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
My EMachines T2482 will not power up properly. The fan comes on, but the monitor remains in the sleep mode, and as far as I can tell, no POST is occurring. The ring around the power button remains dark. It...
Did you remove the CMOS battery and move the jumper on the systemboard to clear the CMOS? After a few minutes or so, put the jumper back and power on the machine. If it powers on fine, you can turn it off and put the CMOS battery back in.
Jun 06, 2009 | E-Machines eMachines Desktop PC
E machine t2482
Try changeing the RAM and if that dosent work try the processor
Jun 02, 2009 | E-Machines eMachines Desktop PC
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
Samsung lcd
First It is not your monitor problem the problem is in your CPU
Open the Cabinet (CPU) door Took out RAM (Random Access Memory) after 5 miniuts Connect it
Thank U
Apr 15, 2008 | Samsung SyncMaster 203B LCD Monitor
Monitor won't turn on
The inverter power supply logic board has probably goe out. You can get it here or have it fixed.
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
Mar 30, 2008 | Dell E176FP 17" LCD Monitor
Flashing power button - no keyboard nor mouse. But PC works... ??
Yes, it may be that the +5v supply from the PSU is faulty, as the PS/2 ports run on 5v and USB runs on 9-12v. Replace the PSU with another of the same form factor and same power rating or better (>=230W). They come at ~£30, so not too expensive. For a little more. Try this:
http://www.quietpc.com/gb-en-gbp/products/psus-300-500/x-red-psus
Jan 28, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
90 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
