Question about Cameras
My 4GB Gigaware SDHC memory card won't work on my camera. It used to work but then I tried it recently then the camera just takes out the lens and freezes. My other memory card works so it has to be the memory card. Can I do anything to fix it? If I can keep the photos in it I would prefer that but if it needs to be erased it is fine. I tried to access and format it on my computer but neither works. I can't access it at all.
SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Posted on Dec 27, 2007
  • 3 Answers
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Posted on May 21, 2008
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
SOURCE: SD card won't format
I just bought a Xacti HD800 and had the same problem.
The solution was :
- Turn on the Xacti with NO SD card inside
- It will ask you to enter informations like the date.
- Then at some point he will tell you it needs a card to store information and while expect you to insert a SD card
- Insert the SD cart, the formatting process will start automatically and last like half a second.
- Enjoy your new toy !
I hope this will help you.
La même en français.
La solution afin que l'appareil formate bien la carte SD est de suivre les étapes suivantes :
- allumer le Xacti sans la carte SD à l'intérieur
- saisir les info demandées comme la date etc
- il vous demandera d'insérer la carte SD à un moment afin de pouvoir enregistrer les info
- Mettez la carte, il formatera automatiquement (en même pas une seconde ...)
- C'est bon !!!!
Posted on Mar 26, 2009
  • 11967 Answers
SOURCE: sandisk sdhc 4gb memory card wont work with my
You need to format the card in the camera to optimize it.
Posted on Sep 24, 2009
I can not get our memory card to format. it says card error. we are using a microSDHC Ccard with adapter 4gb
Is the camera compatible with SDHC? If it can only handle SD memory cards this card is not readable in the device. It will show on the camera whether it is compatible with SDHC. If it doesn't have the logo, take it as the card won't work and you'll need to get a normal SD card.
There is a theoretical maximum of 2GB for SD memory cards, SDHC start at 4GB and go up to 32GB.
Simply put, if your camera is quite old, it won't support SDHC and therefore is limited to a maximum of 2GB memory card.
Jul 26, 2011 | Cameras
Hello I currently have a 2 GB memory card in my canon SD 1000, camera i want to upgrade to 4GB memory card, what is the best brand or type? Will 4GB SDHC memory card work with my canon camera? ...
The Canon SD1000 will work with SDHC cards, up to 32GB in size. Stick with any of the major brands and you won't have problems.
The HP 7350 will NOT work with SDHC cards, limited to SD cards 2GB and smaller.
Mar 26, 2011 | HP PhotoSmart 7350 InkJet Printer
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
Both memory cards show "THIS
Are both cards 4GB or larger SDHC cards, and is your camera more than a few years old? There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 29, 2010 | Cameras
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Cameras
Would not format memory csrd gigaware 4gb
The M425 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
May 15, 2010 | HP Photosmart M425 Digital Camera
I bought a 4GB Memory Card for my Samsung Digimax D53. I put it the camera and Try to format it, but it says CHECK SD CARD. I tried another 1GB memory card and it worked. I know that the problem is with my...
Your problem is that your camera only takes standard SD cards up to a maximum of 2GB. The card you have bought is likely to be a 4GB SDHC model. SDHC is a later development of SD; SDHC compliant devices can still use older SD cards, but SD-only devices cannot use SDHC. This is a hardware limitation so there is no way at all to use an SDHC card in your camera.
Note that if your 4GB card is definitely an SD and not an SDHC then it's still incompatible with your camera: very few standard SD devices were ever made with the firmware and hardware to handle the different memory addressing architecture used by the larger capacity card. Some cameras did have firmware updates to allow the larger SD card to be used, but yours is not one of them.
Your only fix is to sell your card (or keep it for another device) and to buy a regular SD card no larger than 2GB maximum capacity.
I trust that my reply has answered your question fully, please take a moment to rate my answer.
Mar 23, 2010 | Samsung Digimax D53 Digital Camera
Recently purchased an Aiptek IS-DV. It has
Your problem has a very simple fix. The camera which you have is not compatible with SDHC cards. It will only work with regular SD cards.
Your camera is incompatible with the later SDHC specification at the basic hardware level and so cannot format the card which you have purchased.
Note that SD cards are available up to and including 4GB and SDHC start at 4GB so you're not the only person to have made this mistake. In practice there are very few devices designed to use regular SD cards which will work correctly with 4GB SD; Aiptek only designed and tested the IS-DV up to 1GB SD capacity (see page 48 of the user manual), so this is the effective limit to the largest capacity memory card which you can use, if you try larger capacity cards they will either not work at all or will make the camera operations sluggish and you also risk damaging the card itself so that it will no longer correctly format. Aiptek never released any firmware updates to improve the SD compatibility on your camera.
I'm sorry not to be able to offer any way to use your current SDHC card but at least I may have prevented you making another purchasing mistake. Please return the favour by rating my answer.
Nov 02, 2009 | Aiptek Pocket DV2 Digital Camera
Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Cameras Logo
74 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
