Question about Spinmaster Air Hogs Helix 360 Helicopter
Just bought an air hogs helix 360. Now when i give it throttle and let it go, it flys straight left and hits the ground. Any solutions?
    Problem Solver:
  • 12 Answers
It's common for this copter to lift and drift to the left. Likely caused by weight, so you can add additional weight to the opposite sides landing gear, but ultimately more weight isn't better. Sadly there is no control for this drift, you have to compensate manually to keep it perfect. ~VLAD~
Posted on Feb 21, 2011
I have the Air Hogs Helix X4 Stunt Quad Copter and it flys to one side sometimes. One of the propellers will periodically stop. When I turn the throttle off that same propeller stops spinning earlier then...
I have the same problem, two props spins freely when I spin it by hand in switched OFF position. and in ON position, when I turn down the left control to zero they continue to spin while other propellor stops. I know this info is not a solution but if there was a "how to replace motor or propellor" site. maybe I'd find a clue to why the props drag and get it to spin freely like it suppose to be. I could probably put a video together on that topic but if there is already one out there let us know.
Sep 22, 2013 | Spinmaster Air Hogs Helix 360 Helicopter
My air hogs stinger since day one will not fly straight up.
Look for a trim setting or reference trim the users manual. It is usually a dial on the side of the remote.
Oct 10, 2012 | Air Hogs Glow In Dark Havoc Stinger Rc ...
I dont know what it means when i am flying my helix and the power light on the control starts blinking? can somebody help me?
Weak batteries in the transmitter, or you're losing communication with the helicopters receiver. Check the IR receiver under the heli. it may be pushed in or to one side. ~VLAD~
Feb 20, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
I have a helix 360. after a pretty minor crash landing the flybar is stuck in the forward position, making the helicopter unflyable. what I mean is that as the rotor turns, the flybar is stuck in the...
Probably need a gentle bend back to its original position. Can you look at a friends or a shop one to see exactly what it should look like before a crash? Crashes usually bend something. Good luck.
Feb 13, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
How to fix top propeller of the helix 360. It keeps flying to the right
The top is a balance bar. Assuming it's still intact and the metal pieces are there, you can round the edges with a file and cover the tips with a small piece of clear tape to give it more of an aerodynamic shape. The factory "square" shape actually makes the heli move around slower. This will also give you more movement in all directions... more response. ~VLAD~
Feb 07, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
My Spinmaster Air Hogs Helix 360 4-Channel R/C Helicopter leans and falls to the left as i am tryin to lift it off. i tried the 'trim' but that doesnt solve it.
yes, this little heli does do that. it's likely due to balance and the the transmitter not remembering your trim settings after power off, but it's made that way. You have to steer it up, adjust the trim, land it.. and then it should rise better. You can try adding weight to the other side with a piece of clay to see if it solves the problem. If so, you can add metal or electrical tape to the landing gear on one side. ~VLAD~
Jan 22, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
The little flight stabelizer thingy above the propeller on my helix 360 is not working properly. i can hold it in my fingers and while the propellers are spinning i can see the stabelizer is tipping...
Check for damage to any of the linkage. You may also remove the tiny pin on the stabilizer and take it off. use a nail file or dremel tool to round the edges... giving it a more aerodynamic shape, and you a chance to make it balanced. After you do this, wrap each tip with a small piece of clear tape. This mod is good for any of the "square" AirHog balance bars.... it gives you more response and faster movement in all directions. ~VLAD~
Dec 30, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
Does anyone know where to buy a new main prop blade for the airhog helix 360 r/c helicopter?
Look for places that distribute "Air Hog" Products in your area. They should be able to help you.
Dec 25, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
Spinmaster Air Hogs Helix 360 Helicopter Logo
222 people viewed this question
Top Spinmaster Toys Experts
ray gallant
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
