Question about Motorola Mobility H500 Wireless Headset
I cant connect it to my sony erricson w580i.
Do i need to press some pairing button? it says it cant locate the bluetooth when i turn it on.
  • 426 Answers
Hold the power button until it is solid
Posted on Jul 16, 2008
Trying to bluetooth pair a Cowan s9 to a jbl charge
Bluetooth connection should be in Settings menu. From there, choose Bluetooth then turn on the Bluetooth transmitter by touching the second option from the left at the bottom of the screen (Bluetooth symbol). After that, press the locate Bluetooth button (the leftmost choice). Make sure your headset is turned on. The player should list your headset once it finds it. There might be a button on headset that needs to be pressed in order to pair it with a device. Once the headset is located it should ask you for the pairing code (usually 0000). If the code is different for your headset, press the rightmost button at the bottom of the screen and enter the code.
Nov 07, 2013 | JBL Charge Portable Wireless Bluetooth...
I have sony erricson ds220 bluetooth headset. It was paired to Nokia E5 phone and it was working fine. I lost E5 phone and have bought a new LG phone and headset is not able to connect (discover when i...
Phone: Turn on Bluetooth and Bluetooth visibility. Keep it close to the headset (20 cm).2. Headset: Switch it off. Press and hold down the on/off key until the pairing icon appears on the display.3. Phone: If your phone supports auto pairing, press YES when Add device? appears to complete the procedure. If not, continue with the next step.4. Phone: Follow the applicable User guide to pair with a Bluetooth headset. You may need to enter a headset passcode (0000).
Oct 25, 2017 | Sony Ericsson HBH-DS220 Wireless Headset
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Not able to pair bluetooth to my Nokia 6233 model.
some phone asks for the codes while pairin.......u cant reset the code........all u can do both of them should press 1 or 0 while pairin......1 is most used....this will aceept the pairin
Oct 31, 2009 | Nokia 6233 Cellular Phone
Connecting bluetooth head set
>Paraphrasing from the manual:
>1. Turn off headset.
>2. Press & hold the Multi-function button for 8 seconds, until >the lower half is lit up blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
>3. Set your 'phone to discover bluetooth devices.
>4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you want to pair with it. Confirm by pressing "Yes" or >"OK".
>5. Enter passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
Mar 11, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
My sony erricson won't turn on all i see is a red light
Try this.
  1. remove the battery
  2. press and hold the power-on button for 15 seconds
  3. release the power-on button
  4. connect the power supply
  5. with the battery still out, try turning the phone one
  6. if it works, disconnect the power supply
  7. reinstall the battery
  8. connect the power supply
  9. turn phone on
  10. allow phone to charge battery
If that works, you should be okay from that point on.
Jan 12, 2009 | Sony Ericsson w580i Cellular Phone
Sending phone book from sony ericsson w580i to bluetooth mirror
Not 100% on this, but your Sony may only work with Sony bluetooth for this. I know they do such things to promote their sales. Since the actual Bluetooth communications protocol is the same for all phones, you'll be able to pair, but you may not be able to transfer your contacts.
Nov 13, 2008 | Sony Ericsson w580i Cellular Phone
Connecting my Samsung D500 to a Sony Ericsson Bluetooth HCB120 Handsfree Kit
Sony Erricson and some Samsungs depend on what software doesnt pair sorry.
Dec 20, 2007 | Samsung SGH-D500 Cellular Phone
Pairing motorola h350 with sony ericsson w580i
All you have to do is-------- hold the call button on the bluetooth (make sure the bluetooth is off at first) hold it untill the light turns on steadily not flashing but steadily. now it is in pairing mode go to the phone turn on bluetooth, and go to handfree. now press add and it will search and hopefully pick it up.
P.S i had the same problem until i tried holding it longer :D
Dec 16, 2007 | Motorola Mobility H350 Wireless Headset
Answering Calls with Motorola HS850 on Sony Erricson T630
i think rapid connect should work with moto phone only, isn't it?
Jan 28, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility H500 Wireless Headset Logo
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
