My daughter is unable to connect to my broadband. I rang my provider, non UK, all he told was 192.168.1.1. I gleened from our lengthy conversation that i need to change my forgotten password.
    Genius:
  • 1,288 Answers
Type the address he has given you into your internet address bar.
This will bring up the router settings page
Navigate to wireless settings and disable security for WPA and WEP
Navigate to security and change or delete the password
Save settings
See if your daughter can now connect wirelessly
Go back into the router as described above and set a new wireless WEP or WPA key
save / exit and check it works
Posted on Dec 30, 2010
How do I access the internet
hi chris.
If you want to access the internet at home, you'll need an Internet Service Provider (ISP) and a router to connect to the ISP. ISPs often provide a router with their service. This means more than one computer or device in your house can use the broadband connection at the same time.
Internet access and broadband ' nidirect
https://www.nidirect.gov.uk/articles/internet-access-and-broadband..
or you can click on this link and have a read up.
How do access the internet Google Search
Nov 01, 2017 | Internet Computers & Internet
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
I have a Broadband connection and i play online games and my ping is to high please help mee ..!
the faster your broadband connection the lower your ping will be.
broadband speed, is affected by company,area, how far you house is from the telephone exchange, could also be a problem with your line.
things to do to begin with is www.speedtest.net speed test
then if you are in the uk, use this site http://freeola.com/broadband/broadband-speed-availability-check.php
should tell you what speed your broadband should be.
Jun 17, 2012 | Video Game Consoles & Games
Cant connect to internet with an elonex one+
for support call (0871 90 296 90) or email support@elonex.co.uk info from: http://www.elonex.com/support/contacts.shtm
Jan 17, 2010 | Computers & Internet
I get the bluetooth symbol on the Nokia E63 handset but unable to receive calls.
are you using a bluetooth headset? if yes then check whether u have switched on your bluetooth headset & also your phone & bluetooth headset must be reachable, that is, both should be within range as mentioned in your bluetooth headset manual.
Oct 28, 2009 | Nokia E63 Cell Phone
Cannot connect to the remote server using Dreamweaver
It's a nice sharing.
I built my website from the site http://www.tucktail.com/
It has the best features and solutions.
Try this and gain solutions.
Dec 28, 2008 | Macromedia Dreamweaver MX 2004
Configure gigaset SE587 for BSNL broadband
If this is router is gifted to you by a friend of yours who is from UK, Please check if this is locked. Most of the times these would be locked by the ISP. This is a router provide by tiscali UK. Please select the dialing number to 0,38 this is the dialing code for india.
If you use this should work and use 192.168.1.1 as default DNS.
Oct 30, 2008 | Siemens SpeedStream 2624 (SS2624) Wireless...
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
