Question about Microsoft Windows Vista Home Basic for PC
Hi we are tryingto put vista on to our computer but it says to put product code and we have not got one is there anything i can do
Hi i have a Windows Vista Upgrade disc but has no product code on disc or box .please help
Your best bet is to contact the person or company you purchased this software from. Contacting Microsoft about this issue will not resolve anything, as Microsoft didn't sell you the item. You can install Windows Vista using this Upgrade disc without a product key but you will not be able to login after 30 days of no product key.
Feb 27, 2011 | Computers & Internet
HP 3650 wont reinstall from disk. Disk is for XP, my computer is a Vista. How it was installed in the first place I dont know. Worked fine for a year. Help.
according to the HP website, Vista has the correct driver already installed for this printer. Go here for more info:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01655752&lc=en&dlc=en&cc=au&product=304535&sw_lang=&os=2093#N1418
From HP website:
Introduction The driver solution for this product is included in your Windows Vista operating system and is already on your computer. There is no need to download anything. Follow the steps below to quickly and easily get your product working with Windows Vista. The pre-installed (in-OS) Windows Vista driver supports basic printing features.With the basic print driver, the buttons on the product do not function and some of the advanced product features are not available. However, using the workaround procedures in this document, you can still print from a software program. You can also import and view images on a memory card, if your product has a memory card slot.Use the following instructions to install the basic print driver in Windows Vista, and then review the workaround procedures to use the available features for your product. Installing the print driver The method that you use to install the basic Vista print driver depends on whether you use a USB cable or a parallel cable to connect the product to the computer. Use the method for your type of cable .
Method one: USB cable connection When you connect the product to the computer, Windows Vista detects the hardware and automatically installs the correct print driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the product and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Good luck,
Steve
PS please vote for me or give a testimonial if I have helped.
Aug 06, 2010 | HP DeskJet 3650 InkJet Printer
My windows vista home premium will only boot in safe mode i want to reinstall but product code sticker on my laptop is damaged so am worried that i will not be able to activate is ther another way to...
If you download this program http://www.nirsoft.net/utils/product_cd_key_viewer.html (produkey) install it you should be able to extract your product key that is installed on your computer. Although the current Produkey v1.06 is not officially declared to support Windows Vista, it’s working fine to extract product ID and product key of a 32-bit OEM Windows Vista Ultimate edition.
Nov 03, 2009 | Microsoft Windows Vista Ultimate Edition
I need a product key for windows vista basic sp1 but i cant see the sticker and cannot find the manual please help
It is a violation of the EULA (end user license agreement) to share a product key. What you can do is contact Acer at 800-816-2237 or Microsoft at 1-800-892-5234. They may be able to assist in recovering the product key.
Oct 07, 2009 | Computers & Internet
I want to change my ultimate vista product key how can i change it?
Start > right-click Computer > Properties > Change product key (at the bottom)
nLinked
Computer Support Services
Jun 09, 2009 | Microsoft Windows Vista Ultimate Edition
I WANT THE PRODUCT KEY OF WINDOWS VISTA HOME basic to start my computer
If you have a legitimate copy of Vista, the product key is located on a sticker attached to their funky packaging. If you bought a downloadable copy, you should have received a confirmation e-mail that contains your product key. Otherwise, you will need to contact Microsoft to have them help you straighen out the situation.
May 31, 2009 | Microsoft Windows Vista Ultimate Edition
you have to re-install the windows vista software with the origional key no.
May 30, 2009 | Microsoft Windows Vista Ultimate Edition
I'm tryingto uninstall System Suite 8
on the unistaller screen select the program
try to unistall it them remove the entry
them go to your (hard drive)=(C:\) and open the folder name (program files) select the folder containing the program you try to uninstall and delete the folder containing that particular program
Note: be carefull not to delete the folder name (program files) make sure the folder your deleting is the one containing (the system suite 8)
Jan 11, 2009 | Avanquest System Suite 8: Windows
Actovaion code windows vista
Sorry, you must buy the product in order to receive an activation code. Just handing you a code is PIRATING. No one here can help you with that.
Feb 23, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Home Basic for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
