Maytag performa washing machine brake stuck on -cannot turn by hand - wash finished - motor turns
  • Anonymous Aug 09, 2008
    I HAVE THE SMAE PROBLEM WITH MY MAYTAG PERFORMA MODEL #PAV2300AWW. I shifted to drain and the motor spun the drum and pumped the water out so I could remove the load. I refilled and when it shifted to agitate the drum or aggitator wuld not move. I think it could be the transmission or a thrust bearing I have read aout but not sure. Any ideas.
SOURCE: washing machine maytag performa
This problem is normally attributed to a combination of two things: A worn out snubber ring, and a worn brake assembly.
The snubber ring assembly is a white teflon ring that sits under the wash tub at the base (called the milk stool, because it looks like an upside down milk stool).  The entire wash tub assembly will rest on the snubber as it helps get rid of vibration while the tub agitates and spins.  When the snubber starts to wear down, you will notice an increase in tub vibration during the spin cycle and it will sometimes begin to squeak. NOTE: YOU CANNOT OIL THE SNUBBER! DOING SO CAN CAUSE MORE DAMAGE.
The brake assembly is mounted between the pulley wheel and transmission under the washer.  As the brake assembly ages, the pad (which is mounted along the rim of a metal disc) begins to glaze over.  As it glazes, it will also squeak and cause the sudden "slamming" to a stop.  The glazing, coupled with humidity in the air can make this condition worse.
Both problems occur normally with this model washer and can be attributed to normal wear and tear.  I recommend replacing the brake assembly and snubber at the same time.  You will need, however, a special Maytag brake removal tool and spring removal tool if you decide to attempt this repair yourself (it is possible to accomplish this without the aid of a repairman).  Let me know if you need further assistance.  CAUTION: THERE IS A 200 LB COMPRESSED SPRING UNDER THE BRAKE HOUSING.  ATTEMPTING TO REMOVE THE COVER WITHOUT THE BRAKE REMOVAL TOOL CAN BE DANGEROUS.
Posted on Oct 30, 2007
  • 1294 Answers
SOURCE: Maytag Performa Washing Machine
To drain out water press the 'spin only' option, if it does not work drain out the water with a tube, ie, siphon it out of the tub.
Posted on Jun 25, 2007
hattonhall
  • 349 Answers
Before you do anything else..UNPLUG it from the 240volt supply ! Read ALL of this before attempting the fix. After draining out the water, lay the machine down to expose the inner workings. You'll need to find the pressure switch which is connected by an thin rubber or plastic tube from the wash tub. Check that it is is properly connected.(YOu may have to cut off a little of each and to give you a an "as new" airtight sealed fitting. A little smear of quikgrip glue around the nozzle at each end will ensure a longlife airtight fit of the tubing.) BUT before you do the final glueing and fitting of the tube. Just have the tube at the pressure switch nozzle connected and BLOW into it. You should hear an audible click when blowing and relesing the air. Even if you hear this, it only confirms that the diaphragm in the pressure switch is ok. It does not tell you if the two way switch inside it of good integrity. By integrity I mean the condition of the switching CONTACTS, As they carry high current, they eventually burn and pit and can become of such HIGH resistance to the flow of current that there is none when the switch is in fact physically in the on position. Further advice from me can be had by accessing the PAYG "Let our Experts Solve YOur Problem" FixYa Link.
Posted on Aug 30, 2007
Lumpy816
  • 246 Answers
SOURCE: location of filter on maytag performa heavy duty washing machine
I'm sorry Hilda, most washers that have been put out over the last several years don't have a filter per se. When the wash cycle agitates and lint is released from the clothes, the outside of the basket (the area where you put your clothes) is very sharp where the holes are. Lint collects on these holes as the linty water flows through them. When the rinse and spin cycles dis-lodges it and send it down the drain.
There are some availibkle aftermarket kits availible at some appliance parts stores. They are generics and not produced by the manufactues, but if you wanted a lint catcher n a washer, it would be an option.
I hope this helps with you questions. If you have any other quiestions or concerns, please feel free to write me back.
Posted on Jul 23, 2008
I have a similar problem---that is, the water flows very slowly into the tub ----I think tha something is "plugged-up"---
What to do??
Many thanks., Georgia
Posted on Nov 18, 2008
Same problem on same washer
you may havce a piece of clothing stuck between the outer and inner tub
Jan 16, 2013 | Maytag Performa PAV2200
Hi maytag performa pav3200 failing to do spin cycle - is draining all water out still - any ideas, thanks tim
you may have a stuck tub bearing.tilt machine at a 45 degree angle take off belt and turn transmission pulley both ways. One way will be easy for the wash cycle and other more resistant but should be able to turn i nner tub or else their is your problem. To change this bearing need special tools.
Jul 03, 2011 | Maytag Performa PAV3200
Screeching noise when agitating and spinning. abrupt stop when turned off. I have a performa model # pav2300ww
you will need a tech tool from your local appliance parts distributor called a brake tool and a brake
Jan 23, 2011 | Maytag Performa PAV2200
Maytag Performa PAV1000AWW. Motor buzzes but does not turn.
Your motor has gone bad...
If
you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 13, 2010 | Maytag Washing Machines
My Performa PAVT920AWW washer will fill with water, but won't agitate. It will spin but has a funny burning smell.
might b motor fault or jammed gearbox.when motor turns one way it drains and spins, when it turns other way it agitates,might b jamming when it turns for agitate.try looking under unit and remove belt, then turn main drive pulley by hand clockwise then anticlock to see if it is jamming. turn power off first dont want any accidents.please reply to see how u go.good luck
Apr 08, 2010 | Maytag Performa PAV2200
Maytag Performa PAVT920AWW washer makes a squealing sound
i am sorry but i had this problem happen before with my customer maytag performa, what i found out is that the brakes become crystallized, causeing a squeaking noise, remember in agitation, the brakes stops the the drum from spinning, what i advise you to do is change out the breaks or take the brake pads and rub them with sand paper
thanks
Aug 23, 2009 | Washing Machines
Machine will not agitate or spin. Have replaced broken drive belt but machine only washed one load and now the motor just hums
hello it sounds like you have a frozen motor have you tryed spinning the pully by hand to see if you can spin the motor ? if your able to spin the motor pully by hand and it still is'nt turning when powerd on then your have a bad motor
Apr 05, 2009 | Maytag Performa PAV3200
Performa washing machine not spinning
take the back panel off and turn the wash on and check if the belt isnt spinning or the motor
Feb 21, 2009 | Maytag Performa PAV2200
Washing machine not spinning
You may very well have a frozen brake located at the bottom of the transmission. Take the belt off and turn the large wheel in both directions. The wheel should turn easy in one direction and tight in the other. We are concerned with the tight rotation. Turn the wheel by hand. Directly above the wheel is the brake. Watch to see if the brake lifts up and turns. If not then the brake will need serviced.
Jan 12, 2008 | Maytag Performa PAV2200
Maytag performa
Sounds like your motor brushes are very worn.(Its a bit like grinding metal when a cars brake pads are worn.)Should only cost 10 or so pounds for new ones,access to the motor will be required.Unplug washer b4 changing.
Aug 24, 2007 | Maytag Performa PAV2200
Washing Machines Logo
462 people viewed this question
Top Washing Machines Experts
